OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 66 - AVS | Home Theater Discussions And Reviews
Old 03-14-2015, 06:34 AM
castana's Avatar
Liked: 0
Hi All
Sorry to bother you but Could anybody help me with that?
I have a a Samsung Smart TV model UN46ES7500FXZA and I tried both Evolution Kit ( SEK-1000/ZA and SEK-2000/ZA and the TV do not recognize none of them, I am thinking maybe the Firmware (1056 and 1057) is not compatible with these kits, for it, Do anybody have any similar problem?
Please help. I am very confusing....
Thanks in advance
Alejandro
castana is offline
Old 03-14-2015, 09:52 AM
poppagene's Avatar
Quoted: 24 Post(s)
Originally Posted by castana View Post
Hi All
Thanks in advance
Alejandro
I have a UN40ES7500 and can install both of these with firmware 1057. Try this: unplug the TV power cord at the wall and let it sit for a 5 minutes. Insert the evolution kit and make sure that it is properly connected to the port on the back of the TV. If you are using a wired connection, remove the Ethernet cable from the TV and use the adapter that came with either evolution kit to connect the cable directly to the evolution kit. Reconnect the power cord and after 30 seconds or so try turning on the TV
poppagene is offline
Old 03-14-2015, 04:27 PM
AVS Club Gold
Keenan's Avatar
Quoted: 806 Post(s)
Liked: 628
Anyone know if Mubi is available on the PN64F8500 Smart TV? Their site says it's available via Samsung's Smart TV Hub but I don't see the icon for it anywhere.
Keenan is online now
Old 03-17-2015, 03:29 AM
castana's Avatar
Liked: 0
Hi poppagene ,
First , Sorry to delay my answer.
On the other hand I sent the SEK-2000/ZA to Samsung to replace for one new because since that the TV do not recognize the Kit, so I thought that it is defective.
When, I got it again, I will try what you told me.
Thanks for your help
Best Regards
Alejandro
castana is offline
Old 03-25-2015, 11:09 AM
poppagene's Avatar
Quoted: 24 Post(s)
Looks like I won't be ordering the SEK-3000. My es7500 bit the dust. Won;t stay on for more than 15 seconds before turning itself off. It only lasted 2 years. On the plus side, I bought the squaretrade extended warranty and they are going to refund to me the price I paid for the set.
Old 03-28-2015, 10:26 PM
JimSatala77's Avatar
Quoted: 131 Post(s)
Liked: 37
try taking the evolution kit off and restarting the tv without it, I have gone thru 3 e kits on my un65es8000 that would start acting the same way
JimSatala77 is offline
Old 03-28-2015, 10:29 PM
Quoted: 131 Post(s)
Liked: 37
Unhappy
Hi All
Thanks in advance
Alejandro
i had several problems with my UN65ES8000 and the evolution kits i had 2 defective like you are saying and 3 burn out after a couple months...its been very hit or miss with these units imo
Old 03-29-2015, 01:47 AM
Liked: 0
Hi everyone,
I have a question. My TV model : UA65ES8000MPXD, firmware ver 1029.0.
I bought in Indonesia.
I want to buy the evolution kit SEK-2000 for it. is it compatible?
because when i checked on the samsung website, my tv can only support SEK-1000.
there's only sek-1000 in indonesia, So i plan to buy sek-2000 on ebay.
is there any evolution kit model that compatible with my TV? what is /ZA or XC?
Thank you
Giovanno is offline
Old 03-29-2015, 07:28 PM
Quoted: 131 Post(s)
Liked: 37
Yes buy the 2000 the 1000 is the same as what is installed in your tv from the factory.
I have a un65es8000 I'm pretty sure it is the same unit as you and I tried the 1000 and it didn't work
Old Yesterday, 08:09 AM
poppagene's Avatar
Quoted: 24 Post(s)
Already tried that to no avail, but thanks for the suggestion.
Old Yesterday, 09:08 AM
JRWalker's Avatar
Quoted: 24 Post(s)
Liked: 47
The EvoKit is installed in the hottest area on the back of a normally operating set. Those who experience EvoKit failure after successful install should consider that failure may be caused by insufficient cooling air flow around the EvoKit. Wall mounted and cabinet enclosed sets are more likely to have obstructed air flow.
The Service Menu (Mute 7-3-7 Enter) shows Panel Temperature, which is not a direct measure of EvoKit temperature, but it can indicate that a set is running hot.
I installed fans on my F8500 and they keep it close to room temperature. Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk]
JRWalker is offline
Old Yesterday, 11:09 AM
ahro's Avatar
Quoted: 530 Post(s)
Liked: 95
is there an sk-3500 thread? The 2015 OCB for the Samsung.
ahro is online now
Old Yesterday, 11:13 AM
ray0414's Avatar
Quoted: 1307 Post(s)
Liked: 294
no. its not out yet.
TV; SAMSUNG 65 HU9000(current) SAMSUNG 65 8550 4k (30 days) SONY XBR65X850B 4k(owned for 2 weeks), previous was SAMSUNG 65 7100
AVR: Sony 7.2 1040
Blu Ray: Oppo 103D
ray0414 is online now
Old Yesterday, 11:32 AM
Liked: 0
so which sek-2000 should i buy? the /za or /xc?
thanks
Giovanno is offline
Old Yesterday, 11:36 AM
ahro's Avatar
Quoted: 530 Post(s)
Liked: 95
I know, but still there must be people talking about it somewhere on AVS; release date id getting close and there's bound to be some leaks on what it's going to do for the HU9000.
ahro is online now
Old Yesterday, 11:51 AM
elphillips's Avatar
Quoted: 157 Post(s)
Liked: 111
Look through the posts here: OFFICIAL Samsung 4k HU8550 and HU9000 thread
elphillips is offline
Old Yesterday, 12:01 PM
ahro's Avatar
Quoted: 530 Post(s)
Liked: 95
Originally Posted by elphillips View Post
Thanks, been there. The main thread I use is the HU9000 thread.
ahro is online now
Old Yesterday, 08:53 PM
Quoted: 131 Post(s)
Liked: 37
I noticed that the one's that crapped out on me where so hot I couldn't even touch them
Old Today, 10:23 PM
witgit's Avatar
Liked: 0
Hello everyone and ask for help.
I am from the Poland.
I have a Samsung TV UE46ES8000 and I bought SEK-2000 xc.
The tv have the latest firmware 2017.
After connecting sec-2000 tv detects it but after checking, there is a message that there is no usb memory, and nothing happens.
Wifi did not work.
What to do? Please help me.
witgit is online now
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
Gear in this thread - Un75es9000 by PriceGrabber.com
