OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 68 - AVS | Home Theater Discussions And Reviews
post #2011 of 2040 Old 04-19-2015, 09:15 PM
ray0414's Avatar
Quoted: 1658 Post(s)
Liked: 383
Look what I found behind this sticker.
"2013 golf ufv n tv board"
Really wish I could get this black casing off to see what's behind it but it doesn't seem to come off.
ray0414 is online now
post #2012 of 2040 Old 04-19-2015, 09:19 PM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
Originally Posted by ray0414 View Post
Here's another chip of some sort. It says ALTERA cyclone 4. Any guess what that one is?
My biggest question is which board that is that has the black casing on the front. Player, from your blown up diagrams can we figure out what board that is and possible what, if any, chips are on it?
It is a PCB board there are 2 parts 11 and 11A
11 is PCB main board
BN94-07389K
PCB ASSY
$222.22
More on the way, Usually ships within 3-5 business days Specification
UH8T
ASSY PCB MAIN
11a is also PCB main board
Part #: BN94-07675W
Product: TV
Stock: More on the way, Usually ships within 3-5 business days
Price: $218.30
Description:
ASSY PCB MAIN
Specification:
UH8U
So one or other is in set not both...No I think both are in there my mistake
Like I said no golf chip ...That is some serious dedication Ray thanks for opening your panel.
player002 is online now
post #2013 of 2040 Old 04-19-2015, 09:30 PM
ray0414's Avatar
Liked: 383
Did ya see this post?
post #2014 of 2040 Old 04-19-2015, 09:55 PM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
yes I see the post under sticker is part number this is not the golf chip though .
post #2015 of 2040 Old 04-19-2015, 09:59 PM
ray0414's Avatar
Liked: 383
There is a big chip behind the black casing. Trying to see what it is.
post #2016 of 2040 Old 04-19-2015, 10:15 PM
ray0414's Avatar
Liked: 383
Uh oh. Look what I found behind the black casing.
Appears to be a golf chip and an arm chip.
ID:	675377   Click image for larger version
WS65711 likes this.
post #2017 of 2040 Old 04-19-2015, 10:41 PM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
let me see what 1308 does. The 1301 is the same chip in OCB this does the serialization so crunches data .
post #2018 of 2040 Old 04-19-2015, 10:49 PM
ray0414's Avatar
Liked: 383
by the way, i opened up my OCB as well, the golf and arm chip was inside, but it was on the inner side of the board, so i had to lift the board to see the chips, but could only lift part of it. im not sure if the number (1308) matches whats on the tv, or if its the same as last years box that we have pictures of (1303).
so we know there is a golf and arm chip inside the HU9000. but the question now, is how many of these chips are inside non OCB tvs such as the 8700/8550/7250? do they have 2 chips like the hu9000? and if the other tvs dont have 2 and they only have 1, what happens when the new N chip is hooked up to it via OCB ugprade, does the N chip simply over ride the 1 golf/novatech chip on the inside?? i would assume so.
I also wonder if my golf board inside my HU9000 could be changed out with a board from the JS9000?
TV; SAMSUNG 65 HU9000(current) SAMSUNG 65 8550 4k (30 days) SONY XBR65X850B 4k(owned for 2 weeks), previous was SAMSUNG 65 7100
AVR: Sony 7.2 1040
Blu Ray: Oppo 103D
post #2019 of 2040 Old 04-19-2015, 10:53 PM
ray0414's Avatar
Liked: 383
by the way, i see the ARM 1301 is the same inside my tv as it is inside the OCB. but the GOLF chips have different numbers. maybe tomorrow ill re-open my OCB to see if the golf chip in there is 1308 or 1303.
AVR: Sony 7.2 1040
Blu Ray: Oppo 103D
post #2020 of 2040 Old 04-19-2015, 11:37 PM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
spd 1308 is a frame rate converter
Samsung
SDP1308
Frame Rate Converter
http://www.chipworks.com/TOC/Samsung...05-905_TOC.pdf
ray0414 likes this.
post #2021 of 2040 Old 04-19-2015, 11:40 PM
ray0414's Avatar
Liked: 383
Samsung
SDP1308
Ok, I'm no video chip expert at all, what's the difference between golf 1303 and golf 1308? What is a frame rate converter you have any idea?
post #2022 of 2040 Old 04-20-2015, 12:05 AM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
1303 does all the video scaling ..1308 does frame frequency ensuring that motion is transferred properly and smoothed out like amp. This chip is only in 9000 and explains why it has a higher motion rating than all other models that year. 9000 has a special chip for motion and it's 1308 good find ray. Frame rate converter is dealing with lots of data that is why 9000 has another 1301 serdes chip to handle the data from 1308.
FRC (Frame Rate Conversion) algorithms are used in compression, video format conversion, quality enhancement, stereo vision, etc. The most popular application is format conversion. This is the case when FRC is used in order to convert the frame rate of video stream. It is needed for example in order to playback 50Hz video sequence using TV set with 100Hz frame rate. FRC makes the motion of objects smoother and therefore more pleasant for eyes. It allows to slow down the playback speed thus making the objects' movements more evident.
http://compression.ru/video/frame_ra...x_en_frcn.html
ray0414 likes this.
post #2023 of 2040 Old 04-20-2015, 12:17 AM
ray0414's Avatar
Liked: 383
yea, good thing i broke apart the black casing to see what was under it lol i only had to break 2 black screw things, no biggy. so the 1303 is a scaler/decoder, and the 1308 is for motion. by "scaler" does this mean "upscale"? or are they different? like ive said quite a few times, i seen a big difference in motion between the 8550 i had and the hu9000 i have now. are we sure this 1308 chip isnt in the other tvs??
AVR: Sony 7.2 1040
Blu Ray: Oppo 103D
post #2024 of 2040 Old 04-20-2015, 12:35 AM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
yes the scaler also upscales and downscales if needed . yes 1308 is not in 8700 0r 8550
post #2025 of 2040 Old 04-20-2015, 07:56 AM
Thread Ender
WS65711's Avatar
Quoted: 253 Post(s)
Liked: 158
Here is what was posted in different thread that put in to rest!! . . . . .
Now here is a exploded view of 9000 note that the 9000 does not have the video processing chips in panel the parts are just not listed http://www.searspartsdirect.com/sams...323/00001.html
No rest for the weary . . .
ray0414 - That appears to be thermal paste on top of those processors to help keep them cool while they are enhancing your TV's image. Be sure you left that in place when re-assembling your set.
I believe it's time to Overthrow VerticalScope..
and Bring Back Huddler!
It's a shame that in the end TCU's playoff chances all came down to this . . .
WS65711 is offline
post #2026 of 2040 Old 04-20-2015, 09:16 AM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
dude do you read most of the posts b4 posting? Anyways this chip is handling the motion of the image video processing is done first by the DTV scaler which is 1303 golf chip . first video image goes to 1303 which scales and processes image then it goes to 1301 serdes for serialization then it goes to main board where 1308 handles the motion/frame rate then sends it 1301 for serialization then it goes to TCon board . 1303 golf still handles scaling of incoming images and still is marked DNIE just like the golf chip doing the frame rate converting (1308). We see that 9000 has extra golf chip that is not present in other model and Chipworks states that it is a Frame rate controller(1308) . Now if you understand CPU's you can see that this is all part of the system on chip (soc)that separates 9000 from other models EXtra chip for Motion handling. I repeat this chip is not present in other models!!!! Chip works is the industry standard for extensive chip layouts , you have to pay $2500 even $6000 to get layouts they are 100% accurate. They state chip is Frame rate Converter http://www.chipworks.com/TOC/Samsung...05-905_TOC.pdf
Now from ray opening his panel he pointed where the OCB goes in which is to the main board which is part of the SYSTEM ON SOC.Now the OCB can add new video processor ,codecs, cpu's and send it to the main board and it becomes part of the SOC like a IGP. We have rep on camera stating OCB will get new video processors
seriously any chip that has DNIE is part of the processing of the image the 1303 does the scaling of all images so it does 4k scaling,4 upscaling 2k scaling and will even downscale if needed then is sent to 1301 for serialization and passed to main board for 1308 to handle the motion there are decoders on the way to the set and other coprocessors but make no mistake any chip marked DNIE is part of the proprietary video processing . Now just using basic logic if the Chip in OCB that is marked DNIE is swapped out for a new chip would it not be implementing a new algorithm
post #2027 of 2040 Old 04-21-2015, 06:18 AM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
This post is for users wanting to know if 2015 OCB has video processor inside and is for the Nay sayers .
Samsung continued its excellent initiative to offer a remote housing that incorporates connectivity, HDMI chipset, but also the CPU, GPU, multimedia chipset and other components. This allows to change the TV every year and with the premises of 4K, knowing that many compatibilities are not yet present, it is practically essential for the sustainability of the TV.
The One Connect 2015 already offers a great support UHD with HEVC compatibility for tuners and multimedia management, and 2160p compatibility 24, 25, 30, 50 and 60 im / s, compatibility YCbCr 4: 4: 4 and 10 bits per color (especially interesting with 10 bit panel) and HDR technology. It only lacks the ability to display the Rec.2020, but unfortunately it is still far enough! We also see it later in the test
http://www.hdfever.fr/wp-content/upl...28-597x228.jpg
http://www.hdfever.fr/wp-content/upl...30-150x100.jpg
http://www.hdfever.fr/wp-content/upl...31-150x100.jpg
http://www.hdfever.fr/wp-content/upl...32-150x100.jpg
http://www.hdfever.fr/wp-content/upl...02-597x398.jpg
This One Connect includes 4 HDMI 2.0 inputs. By examining the electronics of One Connect box, we can see an HDMI chipset Silicon Image Sil9777. This is the latest and most powerful in its class with support for HDCP 2.2, MHL 3.0, and support for all HDMI 2.0 specification (4K / 60, YCbCr 4: 4: 4 and encoding 10 bits per color). It will be updated soon HDMI 2.0a to manage the HDR. There is also an Ethernet port, the port owner "One Connect" to connect to the TV so output optics, a connector for the service, and finally through the Antenna and Satellite TNT with double tuner Freeview-HD, Cable and Satellite. This allows to record one channel while watching another program, or watch two channels simultaneously in PIP or PAP, or from your tablet or smartphone iOS and Android.
translate to english when using link http://www.hdfever.fr/2015/04/19/tes...tTabs_ul_60683
This should put issue to rest OCB does have the video processor inside ...
Name:	oneconnect inside.jpg
ID:	677345   Click image for larger version
ID:	677353   Click image for larger version
ID:	677361   Click image for larger version
ID:	677369   Click image for larger version
ray0414 likes this.
post #2028 of 2040 Old 04-21-2015, 08:18 AM
ray0414's Avatar
Liked: 383
Wish i could read what the out early chip says to see if it says golf or something else.
I do find it interesting that they say the silicon chip completely controls hdr and will be turned on with a firmware update.
post #2029 of 2040 Old 04-21-2015, 11:12 AM
player002's Avatar
Quoted: 706 Post(s)
Liked: 267
well we know its not golf its the h chip
post #2030 of 2040 Old 04-25-2015, 09:28 AM
Liked: 0
Thumbs down Same here, any solution?
Originally Posted by sky190176 View Post
HI
I also bought sek-2000 for my 2012 es7000 TV
worked great first few days then smart remote stopped working, camera wouldn't work and ir blaster wouldn't control anything.
Decided on doing a factory reset on TV and all came back again, then after being switched off overnight the previous problems re-occurred........do I have to do a daily factory reset :-(
SEK-2000 is on fw 1004
has anyone had reply from samsung ?
remcomat is offline
post #2031 of 2040 Old 04-25-2015, 09:38 AM
Liked: 0
Hi, Same here on a 40ES7000 with SEk-2000 kit (firmware 1030 now)
Works fine except for two issues
Wifi (does not get any SSID, and just returns to TV), but I use CAT6 cable anyway.
BlueTooth for Smart Remote....only Not available message and on/off button works
Seems like bluetooth and WiFi are not working at all I guess...
remcomat is offline
post #2032 of 2040 Old 04-25-2015, 11:23 PM
poisike's Avatar
Quoted: 126 Post(s)
Liked: 38
Its a hardware issue. I had BT/WiFi module fail on my E8000 two times after I started using sek-1000.
Samsung UE65F9000ST + SEK-2500U/ZG (European firmware v1220.4)
Samsung UE78HU8500TX (European firmware v1220.4)
poisike is offline
post #2033 of 2040 Old Yesterday, 01:28 PM
JimSatala77's Avatar
Quoted: 199 Post(s)
Liked: 52
Question
es8000 series needs to be wired with ethernet if you are using the evolution kit..I had a major problem and thats what the tech said...he said if you use the tvs wifi you are bypassing the kit and causing some kind of dual mac exclusion? whatever that is
JimSatala77 is online now
post #2034 of 2040 Old Today, 07:06 AM
YellowCows's Avatar
I think I can try to explain what he meant. Every network-enabled device has a unique identifier, an "address", that it uses to announce itself to other network devices (routers, PCs, modems, hubs etc) called a MAC address (stands for Media Access Control address).
MAC addresses are essential for network devices to connect to your router/home network and get assigned an IP and get online. What the guy was telling you essentially is that the wifi/bt chip is probably duplicated on the panel's electronics, meaning the wifi will get confused or fail altogether (i.e. An 'exclusion', meaning fatal error in computer jargon) when it's activated with an evolution kit attached, which has its own unique chipset and corresponding MAC addresses. One network device cannot have two MAC addresses for the same connection, hence using the Ethernet cable avoids this conflict because the wifi chip(s) are never activated and the Ethernet plug sends one unique MAC address to your router, as it should.
If that's the case with these kits, however, then Samsung is making a huge problem for people that it should at the very least warn them about prior to purchase and in BOLD in the included documentation.
JimSatala77 likes this.
YellowCows is online now
post #2035 of 2040 Old Today, 07:14 AM
Quoted: 41 Post(s)
Liked: 1
anyone know the length of the the 2015 OCB cable (to the TV)? all inputs are made to the OCB (hdmi, ethernet, etc) and just one input to the OCB port on the TV? thanks
mjb8706 is online now
post #2036 of 2040 Old Today, 07:22 AM
YellowCows's Avatar
Most likely the same length as the previous OCB - 10ft/3m. Yes, all connections, incl. optical/hdmi/Ethernet etc are made to the OCB, and there is only cable that runs to the TV (combined power/Ethernet/AV/control cable)
mjb8706 likes this.
post #2037 of 2040 Old Today, 07:53 AM
poisike's Avatar
Quoted: 126 Post(s)
Liked: 38
The SEK-1000 and SEK-2000 do not have built in wifi or BT, so this cant be the problem.
I have seen countless reports on different forums about WiFi and/or BT failing on high end E series TVs. It happened to me twice on my E8000 and I got my money back at the end. I'm afraid this is a known design or chip issue and I'm sure Samsung knows about it.
poisike is offline
post #2038 of 2040 Old Today, 08:09 AM
Quoted: 199 Post(s)
Liked: 52
They dont have wifi in the evo kits but they have an ethernet adaptor that you are supposed to use instead of the tvs built in wifi..that was the point of the convo... if you use the tvs built in wifi you cause an issue where the evo kit isnt able to connect to the internet
post #2039 of 2040 Old Today, 08:13 AM
YellowCows's Avatar
I'm no expert on the sek 1000/2000, but the problem, if the tech guy was right, can be present without a second wifi chip in the kit. Dual MAC exclusion can happen if there are 2 MAC addresses attempting to broadcast simultaneously, even when there is no chipset attached. What this means is that if the evolution kit has its own wireless MAC address (even without the presence of an independent WLAN chipset) and that if the panel electronics are not overridden by the kit (which has to happen in order for there to be one single MAC address) then the exception will occur. Jim's post seems to point in that direction, meaning that the kit, which in theory is supposed to take over the TV's controls and connections, is not programmed to either override or adopt the internal wifi chipset.
This, of course, is very sloppy coding on Samsung's part, if true, as it can be easily handled in firmware. I understand what you're saying - it's hard to imagine that it could have escaped Samsung engineers that people don't want to lose wifi connectivity in order to gain new evo kit features.
post #2040 of 2040 Old Today, 08:22 AM
YellowCows's Avatar
Yes, that explains it Jim. I didn't know the ES8000 kits had their own Ethernet jacks. That means they require physical bypass of the TV network capability, so using the TVs wifi is essentially making an external callout - the evo kit would indeed attempt to broadcast its internal MAC address, and come into conflict with the TV's wifi chip with its own adresses, and FAIL.
I still say this is a cop out by Samsung. They're cutting corners here because that way, they're forcing a (much cheaper) physical bypass of the internal electronics without providing an alternate wifi chipset. They could easily have incorporated a wireless module into the kits, but we all know Ethernet is a hundred times cheaper (for them). Shame.
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
