OFFICIAL Samsung Smart TV "Evolution Kit" Thread - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 41Likes
post #2251 of 2269 Old 08-31-2016, 08:02 AM
torgy's Avatar
mmontanez,
I also have the 2013 F8000, with the latest 1214 firmware. I'm not familiar with the 2015 JS9000 hub. Do you consider this hub update, along with the Octa core and 2015 remote, a significant improvement to the F8000? Enough to justify the $250 price? That's a pretty expensive remote, otherwise.
The earlier SEK-2000 evolution kit for the 2013 non-UHD sets was not particularly well received. I'm really hoping the SEK-3000 will turn out to be a worthwhile upgrade, since it's the last evolution kit we're likely to see for our 2013 sets.
torgy
torgy is offline
post #2252 of 2269 Old 08-31-2016, 09:57 PM
sdsalsero's Avatar
Quoted: 22 Post(s)
Originally Posted by pbm66 View Post
I got my SEK-3000 on Friday and installed it on an PN64F8500 and my tv is pretty borked now.
The last page of the manual does not have the 8500 listed on the Compatible Models list...
sdsalsero is offline
post #2253 of 2269 Old 09-01-2016, 12:30 PM
Quoted: 12 Post(s)
Liked: 2
I saw that as well. I also saw for a year and a half that the F8500's next kit was the SEK-3000, that the Korean's got the SEK-3000k back in november for the F8500 (as well all all the other 1080 tvs that take evo kits). And when installed it identified my TV by name, and then updated the TV's firmware. The TV also had no problem booting into the EVO kit and updating its firmware. Wasnt until it was all done and installed that the problems showed up and then it was impossible to remove. There is no way that the kit would know the model of my tv and still install if it was not designed for it.
The main problem at this point is that Samsung support every day since Last friday, refuses to admit this is even a samsung product. I have B&H Photo trying to ring some bells for me since they are an authorized dealer. Plus newegg today started selling the SEK-3000 today as well so I sent that link to support too.
If they would just tell the people that are responsible for making the firmware about the problem I am quite sure they could fix it quickly.
pbm66 is offline
post #2254 of 2269 Old 09-01-2016, 02:51 PM
And the box lists 2012, 2013 and 2014 TV's, as being compatible. Due to the conflict between the manual and the box; as most people buy based on what the outside carton says. I have reached out to Samsung, and they say they are looking into it.
When the first Evolution TV's came out in 2012, they had the disclaimer that evolution would only take you till 2016. I have the SEK-2000 on my UN46ES8000, and am happy with it. Knowing that this might be the last "kick at the can", I hope they confirm, that this SEK-3000, will work on the 2012's, as the box stats. A new firmware update is the least they could do.
Samsung UN46ES8000F TV, Samsung WMN350M mini wall mount, Samsung VG-KBD1500 bluetooth keyboard, Samsung HT-E6730W home theater
Highland Logan is offline
post #2255 of 2269 Old 09-19-2016, 05:24 AM
deepspace1's Avatar
Liked: 0
Any luck getting your TV fixed? I have a F8500 and have been watching all the features slowly get stripped from it with the occasional firmware updates. I was hoping the SEK-3000 would work for the PDP TV's. D:
If it detected your TV and updated it's firmware it seems it would have compatibility, however maybe it's possible it's misinterpited it as some varient from another country which might have subtle hardware variences (causing issues, while working somewhat).. I am fairly sure there were varients of the F8500 for oversea countries that included dual TV tuners and OTA recording capability, aswell as cable card compatiblity. (feel free to correct me, I am too tired ATM to fact-check XD )
If that's the case then it seems plausible that they'd easily be able to patch it and fix those issues. However, it could be they never intended it for the US market. (if you're in the US, that is)
The fact they deny it's a samsung product (the EVO kit) doesn't surprise me. The script readers in tech support don't know anything that isn't in their database.
Short Story, relevant though: I had a Samsung camcorder (yeah, this is an old story) which I contacted Samsung support when it died about 8 months after purchase (for warranty work). They denied it was a valid model number, so I sent them them a link to their own site listing the product. They told me the product on the link was not sold in the US, and that I MUST have bought it over seas and the warranty was invalid. I bought it at BestBuy, and told them I had a receipt. They denied it up down and all around.
Finally I was promised a callback from a 'supervisor'. Long story short, after a few excahnges he confirmed it was sold in the US however they were unable to repair it since it wasn't in their support/repair database and couldn't even RMA it for repair. Instead they upgraded me to a slightly higher end camcorder, didn't even ask for me to return the old one. I was happy enough that even after a dozen calls and a few hours of hold I was happy enough to not hold a grudge.
That's when I discovered that tech support for any electronics company are no more 'experts' than their troubleshooting script lets them be. Not in the script, then it's your fault, you're crazy, lieing, or if they're smart they'll just issue a RMA and let the service center worry about it. XD Otherwise hopefully you can get ahold of a manager that knows his stuff well enough to figure things out.
So hopefully it's something they CAN and WILL support and get working after some fact-digging.
Personally, I am fine /edit: reluctantly, begrudgingly, etc./ with a Roku to deal with apps/etc. that my TV is now lacking. I bought my TV in 2014, I never imagined just a year later it'd lose much of the smart fuctionality it had out of box (it was about that time they did the big firmware update that removed the old panel home interface and replaced it with the shortcut menu, which I hate).
The fact they PROMISED support for years with new EVO kits was a key selling point for this TV. Given samsung has seemingly turned blind eye to it is something that really killed my liking for samsung products recently. The salt worked even deeper into the wounds when they DID support 4K TV's of the same year, and now seemingly even LCD/LED's going back to 2012 (my PDP is a 2013 model).
If they made the SEK-3000 compible with everything evo kit compatible BUT plasmas / US PDP F8500, I'll probably never buy samsung again. Selective favouritism. particularly when the F8500 was one of their high end TV's of the time. This wasn't just a bargan-bin smart TV.
On a side note, to those that miiiiiight say "just get a new 4K TV". No. Many reasons. lol :3
Sorry for the long post D:
deepspace1 is offline
post #2256 of 2269 Old 09-19-2016, 12:25 PM
ghostnotes's Avatar
Quoted: 26 Post(s)
Exclamation
I'm done with Samsung, going to try LG .
I had an issue with mine being defective and was blamed for the failure.
Also, this goes into the note 7 debacle. My note 5 basically did the same thing. Called them up, verified that it was still under warranty, still have 2monts left.Get an RAM with clearly staying IN WARRANTY A week later I get a repair bill for 200.00 and now it is mysteriously out of warranty.
ghostnotes is offline
post #2257 of 2269 Old 09-30-2016, 09:15 PM
mattfrayage's Avatar
like the new OS and snappiness the SEK-3000 brought to my UN55F8000 but dislike netflix not working
mattfrayage is offline
post #2258 of 2269 Old 10-21-2016, 08:00 AM
Liked: 0
Does new evo kit -SEK 3000 - supports Multiroom ?
tergunt is offline
post #2259 of 2269 Old 10-28-2016, 05:59 AM
Liked: 0
tergunt is offline
post #2260 of 2269 Old 10-30-2016, 04:34 PM
sdsalsero's Avatar
Quoted: 22 Post(s)
Does the new SEK-3000 manual identify which video formats are supported? My F8500 only officially supports h.264 L4.0 -- where L4.1 and L4.2 are the most common. So I have to manually re-encode all of my camcorder's home-videos so that they playback correctly.
I just did (another) online chat with Samsung tech-support and they insist that the only compatible Evo Kit for the F8500 is the all-but-discontinued SEK-2000/ZA. So, at this point, the simplest thing is probably just a Roku, e.g. Premiere+ which has a hard-wired ethernet port.
post #2261 of 2269 Old 11-01-2016, 12:44 PM
Liked: 0
So I'm considering buying the sek-3000 for my UN60F8000 but I'm not really sure of what the benefits are? Can anyone summarize them up for me? I mean I do know that it is supposed to have a new layout, load apps faster but other than that what are the differences? Does it make the picture quality any better/worse? Are there any new apps that you can now download that you couldn't before? Thanks for your help. I usually just mirror my phone to the screen so I'm not sure if this $220 EVO Kit is worth it?
Joseph Siliwono is offline
post #2262 of 2269 Old 12-19-2016, 09:23 PM
Liked: 0
Hello everyone,
I have a F7500 TV bought in Brazil (UN46F7500AGXZD) and need to know if SEK-3000/ZA is compatible with my device
My question is based on searchs where I found some evolution kits model ZA (2000 and 1000) sold on countries other than EUA, like Colombia and Venezuela, to work on TVs of those countries (model ended with letters ZX and XT).
I'm asking because Samsung Brazil didn't even answer me about lauching SEK-3000/ZD and there's no tips about selling this product on my country.
Ilanio is offline
post #2263 of 2269 Old 12-19-2016, 10:00 PM
Liked: 0
About this, look the post 2148 on this thread: avsforum.com/forum/166-lcd-flat-panel-displays/1450292-official-samsung-smart-tv-evolution-kit-thread-72.html#post36838458
Ilanio is offline
post #2264 of 2269 Old 12-23-2016, 01:54 AM
Liked: 0
Hi, does anyone know if sek-3000/za is compatible with european F8000 models?
Roberto Ungaro is offline
post #2265 of 2269 Old 02-07-2017, 02:30 PM
Liked: 2
No, only the XC models are.
Haug523 is offline
post #2266 of 2269 Old 06-04-2017, 04:33 AM
poppagene's Avatar
Quoted: 680 Post(s)
Liked: 495
Bestbuy has SEK-3000/ZA for under $100 today (June 4, 2017) if anyone still interested.
http://www.bestbuy.com/site/samsung-...?skuId=5031502
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is online now
post #2267 of 2269 Old 06-04-2017, 07:41 AM
pilotart's Avatar
Quoted: 479 Post(s)
Liked: 355
Model: SEK-3000/ZA
When was it introduced and for what TV's?
From BB:
http://content.webcollage.net/apps/c...#wct_state=hs1
1. Easily navigate your favorite entertainment
The SEK-3000 Evolution Kit upgrades your 2013 or 2014 Smart TV with new Smart technology, so it’s easier to find information and entertainment so you can enjoy everything you love in one place.
Customers Ultimately Purchased
Samsung - UHD Evolution Kit - Silver
(81reviews)
$399.99
Apple - Apple TV - 32GB (4th Generation - Latest Model) - Black
(8963reviews)
$149.99
EDIT:- Never heard of this but post 2255 above explains it.
Art
pilotart is online now
post #2268 of 2269 Old 06-14-2017, 09:01 AM
cuethenoise's Avatar
Liked: 0
[quote=pbm66;46394777]
Originally Posted by Highland Logan View Post
I am curious about the model too. I got my SEK-3000 on Friday and installed it on an PN64F8500 and my tv is pretty borked now. 3D Does not work right at all, Netflix,Amazon, and Hulu will never load up. The audio in plex constantly has 1/2 second pauses when sending audio to my receiver. The smart interface freezes for long periods of time.
Impossible to remove it now as the removal process in the menus does not work and simply removing it with the power off leaves the TV in a non bootable state.
Samsung support claims there is no such thing as an SEK-3000/ZA. Still Working on finding someone at samsung that has a clue...
Hey I was thinking about ordering this for my f8500. Did you ever get the issues worked out?
cuethenoise is offline
post #2269 of 2269 Old 07-11-2017, 02:44 AM
theslydog's Avatar
[quote=cuethenoise;53635161]
I have a free one given to me by Samsung and so far it works quite well.
In Australia Samsung seem to be giving the SEK-3000 away free, to people who kick up a fuss, in the hope that people don't take Samsung to the local fair trading dept. to complain and get a full refund as Samsung have failed to release 3 years of Evolution kits as promised when the TVs were purchased.
There have been a few successes by people getting a full refund which Samsung are calling buy backs.
theslydog is offline
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung , Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung 75 Inch Led Smart 3d Hdtv Un75es9000
