Samsung F8000 -- 2013 Flagship Models - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3601 of 3737 Old 02-25-2014, 06:36 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
I checked the various picture settings but no option for screen fit for SD channels. Can only zoom.
Samsung UN75F8000 LED TV, NAD T-777 (7.2 Receiver), Oppo 103, Sony PS4, Panamax MR-5100, 7 Paradigm Reference series 8" in ceiling speakers (AMS-150R) - 30 degree tilting speakers, 2 Paradigm SE Sub, universal remote MX-450, universal advanced RF base station MRF-3501. Pics here.
HPQ is offline
post #3602 of 3737 Old 02-25-2014, 08:31 PM
jedi29's Avatar
Quoted: 79 Post(s)
Liked: 59
I just checked my F8000 , I have Comcast , and I tuned to an SD -Ch. and screen fit was an option.
I tried it and it looked the same as 16X9.
jedi29 is offline
post #3603 of 3737 Old 02-25-2014, 10:03 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
That is good. I suspect I can't do that since I am using antenna.
HPQ is offline
post #3604 of 3737 Old 02-28-2014, 06:28 AM
mindlogiczero's Avatar
could someone help me figure out how to use 3d on this?
i have the glasses and i bought fresh batteries, i play 3d on the tv using a htpc, see the blurry image, when i hold the glasses 1-2 feet from the screen i hold the button on the glasses untill i see the "connected" msg popup on the screen but see no 3d image threw the glasses.
ive tried all 4 pairs, is there something im doing wrong or any ideas of anything i can try?
mindlogiczero is offline
post #3605 of 3737 Old 02-28-2014, 07:21 AM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
Do you have a 3d blu ray player? Put a 3d disc in the try and see if the TV adjusts to 3d and your glasses after turning on are able to see 3d?
HPQ is offline
post #3606 of 3737 Old 03-12-2014, 09:53 AM
XeroHertZ's Avatar
Hi guys,
I'm new here and I bought the UN55F8000 a month back, it's a great TV. Recently I got me a bluetooth headset which didn't come with a bluetooth dongle..i'm wondering is there any way I could connect this headset to my TV? Possibly using a bluetooth dongle, will that work??
I also have another Wireless Headphone, how can I connect it to my TV since it doesn't have a 3.5mm headphone jack?
Thanks in advance :)
XeroHertZ is offline
post #3607 of 3737 Old 03-12-2014, 10:21 AM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
Originally Posted by XeroHertZ View Post
Hi guys,
I don't use a bluetooth headset but I did a search in google and came across this.
"have to add the BlueTooth (BT) audio transmitter and on some sets an Optical Audio to analog audio convertor."
I wasn't able to find anything more so not sure if the above can help or not. Maybe if someone here is using a bluetooth headset can speak up but not sure if anybody is using one. smile.gif
HPQ is offline
post #3608 of 3737 Old 03-12-2014, 10:30 AM
XeroHertZ's Avatar
Thanks HPQ, appreciate your efforts :) it seems like a complicated process...Sigh
What about a non bluetooth headset, just a regular wireless one with an IR transmitter..how do I connect it??
post #3609 of 3737 Old 03-12-2014, 11:35 AM
jedi29's Avatar
Quoted: 79 Post(s)
Liked: 59
Just for fun , try going to Device Manager , under System and choose either KB or Mouse and see if it will hook up.
G. 
jedi29 is offline
post #3610 of 3737 Old 03-12-2014, 11:40 AM
XeroHertZ's Avatar
Lol that would be funny if it worked....unfortunately I forgot the headset on my desk at work...will get it tomorrow and try it smile.gif
post #3611 of 3737 Old 03-13-2014, 05:52 AM
XeroHertZ's Avatar
G. 
Just tried that...unfortunately it didn't detect the headset :(
post #3612 of 3737 Old 03-13-2014, 07:46 AM
jedi29's Avatar
Quoted: 79 Post(s)
Liked: 59
O__well it was worth a try.
Later ,
G. 
jedi29 is offline
post #3613 of 3737 Old 03-13-2014, 10:19 AM
XeroHertZ's Avatar
Later ,
G. 
Thanks anyways jedi :)
post #3614 of 3737 Old 03-13-2014, 04:26 PM
rocknrobn26's Avatar
After several emails back and forth to Tech Support,I came to a conclusion that they don't understand what I was asking (How do I set up a Bluetooth head set to the F8000). Their answer was kinda obtuse:
"Connect the USB device that came w/ the headphones and connect."
I have purchased several BT head sets over the years and NONE have come w/ a USB device. That's why they are BT...they don't (shouldn't need) a USB dongle! Please correct me if I'm wrong. Maybe they are referring to an RF set w/ a dongle? One of those that have a base unit operating at 2.4GHz?
Needless to say I gave up.
Good luck.
rocknrobn26 is offline
post #3615 of 3737 Old 03-24-2014, 02:10 AM
Enam Hoque's Avatar
Anyone please let me know how to access F8000 "Service Menu" and check Total Run Time in hour>
Enam Hoque is offline
post #3616 of 3737 Old 03-24-2014, 07:45 AM
bellest's Avatar
Liked: 30
If you have the US model F8000 and the IR remote; put the TV in standby mode then press mute, 1, 8, 2, then power on. It takes a few seconds for the SM to display.
bellest is offline
post #3617 of 3737 Old 03-24-2014, 12:13 PM
XeroHertZ's Avatar
I wish I could turn on the Picture Off option when using the TuneIn Radio app in the Smart Hub..I would like to listen to music while the screen is off..but the Picture Off option becomes unavailable :(
post #3618 of 3737 Old 03-26-2014, 02:03 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
Samsung announced their 2014 lineup.. Good thing I got my F8000 this year. 2014 model (H8000) is curved.
bellest likes this.
HPQ is offline
post #3619 of 3737 Old 03-26-2014, 02:13 PM
bellest's Avatar
Liked: 30
You'd like to trust Samsung's market research team and think they made the right move. But, had I not bought the F8000 I would have definitely gone with another manufacturer rather than buy a curved set...
bellest is offline
post #3620 of 3737 Old 03-26-2014, 02:18 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
Personally, I see the "curved" aspect as a marketing push.. Just to say, we can make the tv curved! But in reality, it may not be as successful as they think it will be. Time will tell. But, for me, I will stick with flat TVs. smile.gif
HPQ is offline
post #3621 of 3737 Old 03-26-2014, 02:27 PM
jedi29's Avatar
Quoted: 79 Post(s)
Liked: 59
Personally I am looking forward to the new G series !! LOL
I don`t know curved might be a-ok , we will see !!
Me 
jedi29 is offline
post #3622 of 3737 Old 03-26-2014, 08:43 PM
DRN94's Avatar
Quoted: 68 Post(s)
Liked: 92
Me 
There is no "G" series. It's the H series for 2014. And there are no reviews to indicate how the picture quality compares to the 2013 flagships to draw a conclusion if the new series is worth the premium over the 2013 flagships.
DRN94 is offline
post #3623 of 3737 Old 03-27-2014, 07:56 AM
jedi29's Avatar
Quoted: 79 Post(s)
Liked: 59
Hi ,
The curved screen makes sense , but I am not ready to buy a new tv now anyway. ( I already have 4 eek.gif )
It will be interesting to see how they do , to see if the general public will embrace a curved screen or just chuckle at and say " now isn`t that stupid ".
Ordinary people don`t care about what a slight curve might do , of course we don`t either , at least not yet.
Non Videophiles really don`t care if the picture is good or bad rolleyes.gif , they just want to watch there favorite show.
It will be people like us that will decide the fate of the curved screen , the nit pickers and people that want the best from there gear.
G. 
jedi29 is offline
post #3624 of 3737 Old 03-31-2014, 11:49 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
G. 
And they think they are getting a great deal when they pay under $1000 for their 6000 series samsung 60" TV and you paid 2.5x that for your 8000 60" TV.
CaptMike is offline
post #3625 of 3737 Old 03-31-2014, 11:53 AM
DRN94's Avatar
Quoted: 68 Post(s)
Liked: 92
Everyone who comes over and sees my F8000 is blown away by the picture quality and comment on how life like it looks. My sister was saying "wow, that looks great" on almost every show and commercial and her boyfriend was quietly agreeing. Non-videophiles definitely appreciate a good picture, its just not something they feel is worth the premium price.
DRN94 is offline
post #3626 of 3737 Old 03-31-2014, 11:59 AM
CaptMike's Avatar
Quoted: 397 Post(s)
Liked: 281
Or they say they better go home and clean their TV screen better.
CaptMike is offline
post #3627 of 3737 Old 03-31-2014, 12:36 PM
DRN94's Avatar
Quoted: 68 Post(s)
Liked: 92
Of course there are those lower level functioning people who don't understand there is more to picture quality than just size and resolution, but I fortunately don't invite such people to my home smile.gif
DRN94 is offline
post #3628 of 3737 Old 04-01-2014, 05:49 AM
jedi29's Avatar
Quoted: 79 Post(s)
Liked: 59
Non - Videophiles do exist !!
Sad but true , most of the populous will go to a place like BB or P`s TV and say what a wonderful picture , I think I will buy one.
Have they done the research ? probably not.
Have they shopped around ? maybe.
Do they have a clue how a newer style tv works ? doubtful ?
So there it is , it all reverts but to the true videophiles after all !! smile.gif
Gary 
jedi29 is offline
post #3629 of 3737 Old 04-01-2014, 06:19 AM
MilesToEmpty's Avatar
So is $1500 a decent price for the 55F8000?
Id rather buy a 2014 model, but there's so much "marketing" in the features. I really narrowed it down to the 55F8000 or the 55W900A (which cant be purchased anywhere really now.)
http://www.buydig.com/shop/product.aspx?sku=EMSAMUN55F8000&ref=cnet&omid=113&CAWELAID=230005120000254861&sdc_id=1396354298z690282z3f073b0a9858zz
MilesToEmpty is offline
post #3630 of 3737 Old 04-01-2014, 01:39 PM
jedi29's Avatar
Quoted: 79 Post(s)
Liked: 59
Ya` 1500 is a great price for a 55" --F8000 , BUT , if you need help you will be better off posting than calling Samsung !!
Me. 
jedi29 is offline
Reply LCD Flat Panel Displays
Samsung , Led Hdtv , Sony Bravia Xbr65hx929 65 Inch 1080p 3d Local Dimming Led Hdtv With Built In Wifi Black , Samsung 55 Inch Led Hdtv Un55b8500 , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
