Official 2013 Sharp LC-XXLE857 Series Thread - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #841 of 882 Old 04-25-2014, 08:43 AM
HTCPBuff's Avatar
I just have to ask what cable service do you have??
I have the 857U (70" ) and have Dish,, just love the picture and sound is thru 7.1 surround stereo, ( yahama). I do have a problem with one channel ( can't remember which one now,,) but only the one,, sound is off a little..make sure you use HDMI #2 or one of the other ones,, do not use #1,, ( I don't have this problem,, but some do with #1).. GL
HTCPBuff is offline
post #842 of 882 Old 07-07-2014, 11:47 PM
powertoburn's Avatar
Quoted: 117 Post(s)
Liked: 95
My 60" set is almost nearing a year of ownership and I had a cloudy set - while browsing Netflix Saturday night was deciding what to watch my tv rebooted - when it came back up most of the cloudy spots disappeared - I immediately checked the backlight level and it was still at 0 STD. All other picture settings remained the same. Anyone have an idea of what may have happened?
This could not of happened at a better time - I was debating on purchasing a 70" Sony set but it get bad reviews for 3D so definitely sticking with the Sharp since the 3D is super on it. Just wishing it was a larger set but the more I debate about it - it seems gaining 9.5 inch of screen is not significantly larger that I would notice at home - just in the showroom. I think @ home I would definitely notice an 80" set. But, can better deal with the 60" 857 now that the major annoying cloudy spots are gone.
powertoburn is offline
post #843 of 882 Old 09-08-2014, 06:10 PM
HDTV Ready's Avatar
Flashing Fault Code - Factory Reset?
I have a lc70le857u (purchased 4/2013), tonight when I tried to turn it on I am getting a flashing pattern from the power indicator light and the display stays off. When the TV is unplugged and then plugged back in, the power indicator light on the TV is normal solid for a couple minutes, then brightly flashes 2 long/slow followed by 5 short/quick, then repeats pattern.
Any guidance would be appreciated, thanks!
- Dan
HDTV Ready is offline
post #844 of 882 Old 09-11-2014, 09:20 PM
Quoted: 240 Post(s)
Liked: 24
Anyone have experience with Professional Calibration using the Service Menu from BB?? I would like to know your experience realizing fully that it all depends on the Tech I get AS WELL AS the Lighting in my room.
thanks.
AVSF458 is offline
post #845 of 882 Old 09-11-2014, 09:41 PM
Quoted: 240 Post(s)
Liked: 24
Originally Posted by Skajjen View Post
Sorry for the delay, but my honeymoon got in the way!
Got a new replacement tv after only 4 days after it was cleared that it was a dead/stuck pixel in the first set. (Great service from the scandinavian distributor)
No more defective pixels and now I'm really happy with the black levels!
Can see some clouding but think a wipe with an soft cloth will solve that.
So now the set is mounted to the wall and i have nothing to complain about! =)
That is a unique AV CAbinet/Shelves. Can you share how they are made or where you bought them
Are those Ascend Towers or Salk Songtowers as your Front speakers??
AVSF458 is offline
post #846 of 882 Old 09-16-2014, 04:30 PM
rayven's Avatar
I lowered my 70LE857 backlight setting from -8 to -14 and it appears while watching football that the blur has increased when the ball is thrown. Does the backlight effect motion blur? My 240HZ setting is unchanged.
Thanks for any input.
rayven is offline
post #847 of 882 Old 09-17-2014, 07:34 PM
Quoted: 240 Post(s)
Liked: 24
does anyone else have issues with netflix on the Sharp LC80LE8857U. The sound sucks on mine. No 5.1 and it is so low and flat with no bass and I have a great SUB.
AVSF458 is offline
post #848 of 882 Old 09-18-2014, 10:36 AM
VBB
VBB's Avatar
Quoted: 1020 Post(s)
Liked: 872
A change in backlight doesn't really affect anything other than the overall light output of the TV. For watching sports, I recommend you turn Motion Enhancement off.
How come you have your backlight set so low, by the way? What are your other settings/mode? After calibration, my backlight is at -4 as the lowest possible, and I only set it to that when I watch with no ambient light. I mostly have it at STD (0) and sometimes set it to +10 during the day.
VBB is offline
post #849 of 882 Old 09-18-2014, 10:40 AM
VBB
VBB's Avatar
Liked: 872
I get 5.1 DD from the Netflix app on the TV. This is through my receiver connected via HDMI and using ARC (Audio Return Channel). Make sure the TV is set to Bitstream instead of PCM.
VBB is offline
post #850 of 882 Old 09-18-2014, 05:10 PM
rayven's Avatar
I watch in low light levels and previously had a plasma so I'm agreeable to watch at lower backlight levels to achieve darker blacks. I use the standard setting with brightness at -2, sharpness at 3, advanced contrast on, 240hz setting, and the remaining settings at 0. I have not had a calibration yet.
Thanks for the input!
rayven is offline
post #851 of 882 Old 10-13-2014, 06:49 PM
rayven's Avatar
VBB, finally turned off Motion Enhancement which solved the blur. It darkened the picture so I brought my backlight to -8 and brightness to 0. The picture is awesome and football looks better than on the plasma I had.
Thanks for the suggestion!
rayven is offline
post #852 of 882 Old 10-13-2014, 08:27 PM
VBB
VBB's Avatar
Liked: 872
VBB is offline
post #853 of 882 Old 11-29-2014, 03:25 PM
ecue's Avatar
Liked: 0
purple spots LC-60LE857
Well hey all, I'm looking to know just what happened a few days ago with
my LC-60LE857 only 9 nomths old. First I'm on Comcast cable SD not HD and
I've never hooked the TV to the Internet.
My set shows a couple of purplish spots from the bottom right corner up
towards the middle. I've searched the web for any insight in to this problem
and only found one at-
h<>p://answers.sharpusa.com/answers/8303/product/LC60LE857U/lc60le857u-questions-answers/questions.htm?sort=recenta
Which describes the same problem but, with no fix or solution, only to contact Sharp.
I'm in hopes that someone here can suggest some ideals as to troubleshooting, a fix,
or how to get the best responce and remedy from Sharp.
ID:	392418   Click image for larger version
ID:	392426   Click image for larger version
ID:	392434   Click image for larger version
ID:	392442   Click image for larger version
ecue is offline
post #854 of 882 Old 11-29-2014, 03:36 PM
ecue's Avatar
Liked: 0
Correction - its a LC-60LE857U
I had forgot the U.
ecue is offline
post #855 of 882 Old 11-29-2014, 03:37 PM
VBB
VBB's Avatar
Liked: 872
Does it do that on every input/with every source? Have you tried a factory reset? Good thing is, you're still within the warranty period.
VBB is offline
post #856 of 882 Old 11-29-2014, 04:26 PM
ecue's Avatar
Liked: 0
Hi Henry,
I was hoping you'd offer something since your
the one to go to or answer a lot on here.
I've only used the cable input and I've not done a Factory rest yet. Didn't want to loose my setting I had decided on.
I'll try both tomorrow, do you think a movie from the usb port would be ok. Don't have DVD player anymore.
You personally have any dealings with Sharp on service or returns? It's a BestBuy purchase
you think they are factory repair authorized?
Thanks ahead for your answers and your questions. ecue
PS. sorry for the bad pictures that's SD for you. You know some shows don't hardly show
the Purple Spots then again some you can't look passed them.
ecue is offline
post #857 of 882 Old 11-29-2014, 05:24 PM
VBB
VBB's Avatar
Liked: 872
Hi Henry,
The 70LE857U is my first ever Sharp set, and so far I haven't had any issues with it. I don't think there is any point in contacting Best Buy about the warranty, because they would just point you to Sharp, since you're still within the 1 year period. Did you buy an extended warranty through Best Buy?
Definitely try a different input if you can. USB should be fine. Hook it up to the Internet and watch something on YouTube. Also write down all your settings and do a factory reset under Initial Setup -> Reset.
VBB is offline
post #858 of 882 Old 11-29-2014, 05:43 PM
ecue's Avatar
Liked: 0
WOW went looking again on the web but, didn't put my model number in the search just- "Sharp purple spot on screen". Came up with a lot more to look at. Went to a .consumeraffairs.com site were out of 109 only rated Overall Satisfaction Rating of one star. Then to top it off I ran across this guy from -
Anonymous of Anywhere, NT on Sept. 16, 2014
I used to work for Sharp (in the tv department) and we were always told to tell people that their problem was not a common issue when really the problems that customers would call in about were repetitive. I always wanted to tell the people that would call in after purchasing a brand new Sharp tv to take it back to the store NOW because it will not last and you'll have problems with it sooner than you think! You see, Sharp is a Japanese company that sells overpriced products by putting cheap (non-lasting) parts into their tvs to make them work for only a short time, forcing you to buy new. YOU'RE GETTING RIPPED OFF! I wouldn't recommend Sharp to anyone!
I've heard many complaints about the customer service as well and it's true. They aren't trained well at all. In fact, I felt like I was just trained to basically lie to the customer and perform some bogus troubleshooting that NEVER helped to solve the issue. I could go on all day about why buying a Sharp product is a bad idea but the point is, save your money! Yes, the picture is beautiful but the sound quality is horrible. You need a sound bar just to hear the tv clearly. Trust me, there is nothing good about this company or their products!
Really makes me hate the brand and the position I'm in now.
Well update you later as I read more on my situation/problem/remedy as issues arise.
Thanks all...
ecue is offline
post #859 of 882 Old 11-29-2014, 06:45 PM
ecue's Avatar
Liked: 0
"First off I'm not bashing Sharp", I'm reporting some things already in print from the web. If it helps someone make a PRE decision in stead of a POST regret thought, then be it. Sharp only has to blame their self for their business practices and support of products.
Same site as the 109 complaints from earlier, I came across some more interesting information. See this-
Shay of Houston, TX on Sept. 4, 2014
I hold my electrical engineer postgraduate degree from a top US university. I have studied the same OPC 2-long-5short flickering problem with my LC60LE847U TV for a long time. So my comment is objective. Sharp has a big financial problem in last 5 years and as a result, their board team decided to exchange 10% of their shares with Foxconn for better integration and management. The Foxconn team basically designed Sharp TV with the LCD panel from Sharp factory in Japan, and branded it as a Sharp TV. Foxconn team, in their continuous pursuit of profit margin, outsourced the power supply board to their friends call Delta.
Now do you remember why your laptop monitor has the backlight issues when it just passed warranty period? The same thing happens to your Sharp TV. These power supply team from Delta is the same company and people who designed your laptop monitor power system. They know their product mean time between failure is just little bit longer than the required 12 month warranty period. But so what? They don't care and they are only paid by Foxconn with that much money to keep it running for 12 months.
The net result is that your Sharp TV is more like your cheap $x00 laptop, and won't last any more longer than the required warranty period. If you are not happy about it, you have the choice to either buy the extended warranty or walk away from Sharp. Delta team are now so experienced with such a nasty and dirty game that they can control your Sharp TV life within months period by choosing different brands of electrolyte capacitors, ICs, power regulators, and LED backlight bulbs etc.
To bad a this comes to me after I'm an owner and have a set with problems but, I'm still within my warranty period - but what kind of a future to a short lived refurbished unit can I see. I think a Duracell battery would last longer than my currant set or a refurb one from this brand.
Thanks all...
ecue is offline
post #860 of 882 Old 10-24-2015, 02:09 PM
Quoted: 240 Post(s)
Liked: 24
What do you download? All I see there is a You Tube Video playing., are you saying play it on the Sharp to see the true colors?
Also does anyone else have their favorite setting posted that I can try? My Tv somehow had become worse. I had the Sharp Tech come out and he claimed there were no issues. Since they are essentially out of the HDTV Business I suppose I am SOL as well. That LC80LE857U was a disappointment from the day I got it home. Should have returned it within the 30 day return period. :-( :-(.
I dont know if anyones ever posted this here before but running a benchmark test is a good idea when getting any tv. tv blink is a good test that pushes the tv. You just download it and burn it to dvd. You'll see a lot more then your eyes will usually catch.
http://tvblink.com/[/QUOTE]
AVSF458 is offline
post #861 of 882 Old 10-24-2015, 06:25 PM
VBB
VBB's Avatar
Liked: 872
http://tvblink.com/
[/QUOTE]
What exactly don't you like about the 857? I've had the 70" since late 2013, and while it can't compete on black level, it's still a great set, especially in a well lit room. This was Sharp's top of the line TV back then. It does need to be dialed in, though. Out of the box, it's just not that good. But that goes for most TVs, even today. Feel free to try my settings below:
AV MODE=Movie
OPC=OFF
Backlight=STD for dark room, crank it during the day
Contrast=35
Brightness=0
Color=0
Tint=0
Sharpness=0
C.M.S. Hue
R=4
Y=4
G=-4
C=-8
B=13
M=4
C.M.S. Saturation
R=12
Y=4
G=18
C=23
B=-14
M=16
C.M.S. Value
R=0
Y=-3
G=-10
C=-7
B=6
M-9
Color Gamut Range=Standard
Color Temp
10 Point Setting On
Position 1 2 3 4 5 6 7 8 9 10
R Gain 16 3 -1 -6 -4 -6 -14 -4 -4 -3
G Gain 6 9 -1 -6 -4 -8 0 -5 -2 -1
B Gain 30 -13 -24 -30 -30 -26 -30 -17 -23 -26
Motion Enhancement=Off
Quad Pixel Plus 2=Off
Active Contrast=Off
Film Mode=Off
Digital Noise Reduction=Off
Make sure to set it to no overscan via the VIEW button.
VBB is offline
post #862 of 882 Old 10-25-2015, 06:50 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
- Dan
I know this is an old post but just for info for others on this type of set / thread, the "flashing 2 5 code" is likely an issue with the power supply card or a "bad panel". If the card checks out (mostly does 12v get to the tcon card) then it points to a panel issue. Although this issue will not be repairable by an authorized service, recently guys on badcaps.net forum have figured out a way to "save" the set from the dumpster by removing bonded tab cables running to the side of the panel. The panel has two sets of cables, one set on each side. It will run without one side connected / removed. The reason the set is shut down is the side that is in trouble is pulling down the powering of the entire panel. By removing the effected side (basically taking away the "load down"), the tv comes back to life. Of course, this isn't its "design intent" but so far the "saved sets" are operational with what appears to be a normal picture. How long, nobody knows. Vizio sets use the same sharp panel and can be saved in a similar manor (although the vizio sets do not have flashing code displays and have issues with the load taking out the tcon card which has no protection unlike the sharp sets). Anyways, if you have a set out of warranty and have this code, you might consider trying this if you have some skill and persistence to save the set from the garbage at least for a little while.
budwich is offline
post #863 of 882 Old 11-23-2015, 04:50 PM
Quoted: 240 Post(s)
Liked: 24
AV MODE=Movie
OPC=OFF
Contrast=35
Brightness=0
Color=0
Tint=0
Sharpness=0
C.M.S. Hue
R=4
Y=4
G=-4
C=-8
B=13
M=4
C.M.S. Saturation
R=12
Y=4
G=18
C=23
B=-14
M=16
C.M.S. Value
R=0
Y=-3
G=-10
C=-7
B=6
M-9
Color Temp
10 Point Setting On
Active Contrast=Off
Film Mode=Off
Make sure to set it to no overscan via the VIEW button.[/QUOTE]
Thanks @VBB , Today I find nothing to like about the 80 incher. The picture keeps getting worse and there is like a halo effect in the background most times which is freaky and relatively new. I am not sure what could be causing that. The closeups look just fine but the background has gotten worse and it is only what like 3 years old. I am glad Sharp got out of this business because they really suck for me. I will try your setting to see if anything improves. I just don't like answers like it could be your transmission when the transmitter has not changed over time I still use the same Dishnetwork receiver I have had for a some time now.
Thanks again.
AVSF458 is offline
post #864 of 882 Old 11-23-2015, 04:50 PM
Quoted: 240 Post(s)
Liked: 24
AV MODE=Movie
OPC=OFF
Contrast=35
Brightness=0
Color=0
Tint=0
Sharpness=0
C.M.S. Hue
R=4
Y=4
G=-4
C=-8
B=13
M=4
C.M.S. Saturation
R=12
Y=4
G=18
C=23
B=-14
M=16
C.M.S. Value
R=0
Y=-3
G=-10
C=-7
B=6
M-9
Color Temp
10 Point Setting On
Active Contrast=Off
Film Mode=Off
Thanks again.
AVSF458 is offline
post #865 of 882 Old 12-03-2015, 09:23 AM
pee
pee's Avatar
Quoted: 84 Post(s)
Liked: 51
Since this thread was so instrumental in me purchasing this TV in November 2013, I'd thought I'd chime back in and share my sadness.
As above...I also received the dreaded purple spot on my 857U screen.
Happens on every input depending upon the color of the image being shown.
I contacted Sharp to utilize my extended warranty. They sent a 3rd party service company out (Precision TV). The tech looked at the spot, tried several inputs...then after 5 minutes he says, "it's your panel. it's going out and will get worse over time. nothing we can do to fix it."
He took photos and said Sharp would contact me to either replace or do a buyout for the current value of the TV.
It took several weeks for Sharp to finalize my claim...but in the end, I chose the buyout offer, which was about $150 less than what I paid 2 years ago. They only offered a 757U TV as a replacement and I vetoed that.
Anyway, very disappointed because I completely enjoyed this TV and had no intention on getting a new one for at least a year or 2 later. This in turn has resulted in me now upgrading to a 4K TV and upgrading my AV Receiver. Whoa is me huh? lol
So, if any of you fellow owners start to see that purple blob...start researching your next TV.
One positive, Sharp will not come pick up my current 857. They said I can dispose of it or just keep it until it completely goes out. Since it's still watchable and that spot only shows up on certain images...guess I'll have the best garage in my community. Because I'm going to mount it there and let it live the rest of it's life.
pee is online now
post #866 of 882 Old 01-24-2016, 03:02 PM
rayven's Avatar
70" 857 died
I have a 70" le857 I purchased January 2014. I have enjoyed this tv and had thought I could have it for at least four more years. I watched football last Sunday with no problem. Monday night I turned the tv on and no power up, no flashing lights, nothing. I unplugged it, plugged it in to a different outlet and still nothing. I did buy the Sharp warranty so I filed a claim. I am now waiting for the serviceman to come out with a power board. Hopefully this week it will be up and running or am I wishful thing?
Yamaha RX3900
JBL Studio 590 7:1
SVS Ultra PB 13
Sharp LC70LE857U
Sony SACD
rayven is offline
post #867 of 882 Old 01-24-2016, 04:27 PM
VBB
VBB's Avatar
Liked: 872
That sucks. I have the same TV, and it's still going strong, although not at my house any longer. Best of luck. Hope you get it fixed before Super Bowl.
VBB is offline
post #868 of 882 Old 01-24-2016, 05:58 PM
rayven's Avatar
VBB, thanks but I have the feeling this will be a long process.
Yamaha RX3900
JBL Studio 590 7:1
SVS Ultra PB 13
Sharp LC70LE857U
Sony SACD
rayven is offline
post #869 of 882 Old 01-24-2016, 05:59 PM
rayven's Avatar
Yamaha RX3900
JBL Studio 590 7:1
SVS Ultra PB 13
Sharp LC70LE857U
Sony SACD
rayven is offline
post #870 of 882 Old 01-29-2016, 06:57 PM
rayven's Avatar
Talking
Sharp really did the job and within a week my TV was repaired. I can't complain at all about the warranty service. Hopefully good to go for another two years!
Yamaha RX3900
JBL Studio 590 7:1
SVS Ultra PB 13
Sharp LC70LE857U
Sony SACD
rayven is offline
Reply LCD Flat Panel Displays
Sharp He Lc 70le857u 70 Inch 3d Smart Led Tv , Sharp 80 Inch Full Hd Aquos Led Smart Tv
