LG 42" LM series 3DTV - Playing .mp4 and .mkv files through USB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-08-2013, 06:10 PM - Thread Starter
ExcelPremium's Avatar
I just downloaded a movie and it was in .mp4 format "sbs_1080p_8000.mp4" so I'm guessing it's SBS format. I dragged it onto my USB drive and connected to my LG TV, the video doesn't work, no sound or video as it says the video is not supported. I tried converting it to .mkv thinking it doesn't support .mp4, I used mp42mkvac to do it and still same error. It doesn't work at all.
Does anyone know what's wrong with it and what should I do to get this movie playing on my LG 3DTV?
Thanks all!
ExcelPremium is offline
post #2 of 8 Old 01-09-2013, 10:00 AM
sitlet's Avatar
Well the problem is, mkv and mp4 are just containers. The codec inside is what matters.
sitlet is offline
post #3 of 8 Old 01-09-2013, 10:35 PM - Thread Starter
Oh...how can I check what codec it is and what codec should I convert it to?
post #4 of 8 Old 01-10-2013, 09:19 AM
sitlet's Avatar
MediaInfo
Whatever codec your tv supports.
sitlet is offline
post #5 of 8 Old 01-10-2013, 11:27 PM - Thread Starter
I just used MediaInfo and this is what came up.
I have a LM5800 LG 3DTV and I'm not sure what codec works with this TV.
The format is AVC, so I'm going to guess the LG TV doesn't support it? What Codec/format should I convert the file to without losing audio and video quality?
Edit: Seems like the LG TV does support AVC(from google?) so what exactly is wrong with this file? I can play it on my computer just fine but when I try plugging the USB thumb drive(1.3GB 3D Video) it doesn't play, no video or audio.
post #6 of 8 Old 01-11-2013, 01:39 AM - Thread Starter
Wow! It works now! So after some googling, instead of High@5.1, I used H264LevelEditor and changed it to High@4.1 and it works...a simple change lol
post #7 of 8 Old 01-11-2013, 09:29 AM
sitlet's Avatar
I was just going to suggest that, most tv's don't like the High Profile.
ExcelPremium likes this.
sitlet is offline
post #8 of 8 Old 01-11-2013, 09:28 PM - Thread Starter
Reply LCD Flat Panel Displays
3d Hdtv , Lg
