My HDTV is SO grainy! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-11-2013, 12:38 AM - Thread Starter
marcusj0015's Avatar
When I watch my blu-rays on my computer, they look beautiful, but when I play them on my TV they look REALLY grainy, distractingly grainy, and it hasn't always been this way, but I've looked through it's settings and reset the settings a few times, and it's still grainy. Any ideas on what to do? It's a cheap POS Dynex DX-L40-10A by the way.
~EDIT~
It's 1080p and so are the Blu-ray's I'm watching, so it's not like it's using a reallllly ****** downscaler or anything.
~EDIT2~
Also, whenever I connect my TV to my Macbook, Mac OS think's it's 720p, but I've looked at both Dynex and the panel manufacturer's sites and they both confirm that it is indeed 1080p, why would it lie about it's native res and is there anyway to fix it?
marcusj0015 is offline
post #2 of 5 Old 01-11-2013, 07:55 AM
Danediz's Avatar
You cant compare a mac display with a dynex. Your mac display has almost the same amount of pixels as your 40" so blu rays on your mac will always seem to look clearer. My 10" ipad has more pixels than my 55" 1080p tv. Thers no question the ipad is going to look better. For a tv to have as many pixels per inch as your macbook would cost a massive amount. I dont even think 4k tvs will have as many pixels per inch as an ipad.
This aside there are a lot of tvs out there that do 1080p much better than dynex.
Danediz is offline
post #3 of 5 Old 01-11-2013, 08:24 AM
sitlet's Avatar
Quoted: 16 Post(s)
You answered your own question right there.
Are you connecting with HDMI? Is the computer set to output 1080p?
sitlet is offline
post #4 of 5 Old 01-11-2013, 09:21 AM
walford's Avatar
What resolution does the INFO button on your TV remote say the TV is receiving from the BR player?
walford is offline
post #5 of 5 Old 01-11-2013, 12:00 PM - Thread Starter
Actually, if we're going to get technical, my Mac is a Retina MAcbook, and has over 5 million pixels. biggrin.gif
My info button say's it's running in 1080i which is odd, beucase it does support 1080p, but also I've realized that my EDID is masivly messed up, but I've got Win8 on my Macbook for windowsy things, and it doesn't want to play nicely with the EDID editor apps, do you have any idea how to get my TV to regenerate it's EDID, or any EDID editors that will actually work? there's one called ViewSonic EDID Editor, which seems perfect, but it can't read it becuase of some ActiveX bs. :/
Not to be an *******, but yes, there are TVs that do a lot better job than my Dynex, but I don't really have the money to just run out and buy a new TV. (I'm a college student.)
Yes, I'm connecting it through HDMI and the TV is set to output at 1080p.
I think that grain I was talking about, is actually interlace lines, that makes a lot more sense.
Also, this TV was reported to support 5.1 audio, but it tells the OS that it's only capable of 2 channel audio.
Reply LCD Flat Panel Displays
