Samsung Screen 'shadow/bruise' Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-14-2013, 06:42 AM - Thread Starter
Optikal101's Avatar
Hi
My Samsung LE40M87BD LCD TV has recently developed something of a fault on the screen but i'm not entirely sure what the fault is exactly. As you can see in the first image, there seems to be a deep shadow or bruise type thing on the screen, mostly visible when solid blocks of bright colour are on the screen (changing channels, playing FIFA etc
However, when watching TV , there's no distortion in the colours or the picture itself.
It also isn't as apparent when you first turn the TV on, becoming more apparent as the screen warms up. This is the TV directly after a cold start.
And most baffling, if you turn the TV to a 'dead' channel with no signal input the problem seems to disappear altogether.
There's absolutely no other issue with the TV other than this problem. Can anyone please diagnose and maybe offer a solution?
Optikal101 is offline
post #2 of 8 Old 01-14-2013, 08:37 AM
EndeaverouX's Avatar
Liked: 27
Originally Posted by Optikal101 View Post
Hi
quiet common issue...all tvs have that....
one word....
massage the screen....
EndeaverouX is offline
post #3 of 8 Old 01-14-2013, 08:45 AM - Thread Starter
Optikal101's Avatar
massage the screen? So it should just rub out?
post #4 of 8 Old 01-14-2013, 08:50 AM
Katie Meadow's Avatar
Katie Meadow is offline
post #5 of 8 Old 01-14-2013, 10:38 AM
Liked: 27
yes...do your homework...there is no specific technique....
I cant be the mama bird here feeding you every lil information like dropping worms inside the baby bird's beek....lol..
is all over AVR forums, google, youtube.... let me know how you make out.... biggrin.gif
post #6 of 8 Old 01-16-2013, 07:55 AM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
The most often used term to describe what you have is "clouding." Googling "clouding LED TV fix" will show that most commonly prescribed fix is turning down backlight level and "rubbing" with soft microfiber cloth. For example, check out:
http://www.ehow.com/how_6516595_fix-spots-lcd-tv-screens.html
Good luck.
EndeaverouX likes this.
Apostate is offline
post #7 of 8 Old 01-16-2013, 10:57 AM
Liked: 27
Good luck.
good link...hope people now learn how to massage their pixels...lol
post #8 of 8 Old 03-23-2014, 06:03 AM
treydaponq's Avatar
Hi, If you still have the issue, try this:) best of luck. It has worked for hundreds of others.
http://www.youtube.com/watch?v=nuOzmpUKTEY
treydaponq is offline
Reply LCD Flat Panel Displays
