Need suggestions on replacement for LG 55LM9600 - AVS Forum | Home Theater Discussions And Reviews
Old 01-15-2013, 08:31 PM - Thread Starter
musical123's Avatar
To make a long story short I bought and returned 2 55lm8600s due to light bleeding, bought a 55lm9600 which was great for the 1st week until it died.
The LG quality is so bad that the LM9600 is going back and I need to find a great replacement at a good price if I am to "save face" with my wife.
Looking for:
Lcd/led
55 inch
Passive 3d
Wifi with a decent browser
Thin bezel (needs to fit in 49.5 inch wide space)
$1500 - $2000
In closing I would stay very far away from LG - I tried 3 times to like them.
Thanks for you inputs
musical123 is offline
Old 01-15-2013, 08:39 PM
ondaedg's Avatar
The only other passive 3d lcds that I'm aware of (someone feel free to correct me if I'm wrong) are Panasonic and Vizios. I prefer passive myself, but you are limiting your choices if you don't like LG. Check out the Panasonic and Vizio threads to see if anything interests you.
ondaedg is offline
Old 01-16-2013, 07:11 AM - Thread Starter
musical123's Avatar
I will check into those.
Chris
Old 01-16-2013, 07:20 AM
Navigationroad's Avatar
Toshiba makes a line using the passive 3D technology as well.
Navigationroad is offline
