Official Vizio M-Series Razor Mxx1i thread - Page 199 - AVS Forum | Home Theater Discussions And Reviews
 264Likes
Old 12-03-2013, 03:11 PM
Micah123's Avatar
Quoted: 80 Post(s)
Originally Posted by PlayNice View Post
The M80 and M70 and M60 shareS similar panels, as for the M65 that uses a different kind of panel.
The M70 I was looking at was much darker than the M80 or M65. All 3 were side by side at Costco.
Micah123 is offline
Old 12-03-2013, 03:24 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Most likely a settings issue, not a panel issue.
Vizio 80" 3D LED M801D-A3 ISF Calibrated | Onkyo TX-NR818 w/ Polk Monitor 50 (Fronts), Onkyo SK-520 (Surronds), SKW-770 (Sub) | Win 8.1 PC i7 3930k, 2 SLI GeForce 770's, 32GB RAM | Mac Mini 2011 i5 2.3Ghz, 16 GB RAM w/ PLEX | Roku 3 | Oppo BDP-103D | Xbox One, PS4, Wii U, Xbox 360 S, PS3 Slim | Harmony Touch
PlayNice is offline
Old 12-03-2013, 05:34 PM
Micah123's Avatar
Quoted: 80 Post(s)
Went back to costco and learned a few things. Went to advanced under picture settings and turned off the auto brightness selection. That was the major reason for display being so dark. Also appears that the 65a2 has a glossy screen whereas the 70 and 80 have more of a matt screen. Was told that LG makes visio screens. Vizio said the a2 means second generation and a3 is third generation. Guess third generation screens are matte types.
Micah123 is offline
Old 12-03-2013, 05:51 PM
semillertime's Avatar
Anyone know what SOC the M-Series has?  I curious to know it's capabilities and can't find it documented anywhere.
semillertime is offline
Old 12-03-2013, 06:28 PM
vislld's Avatar
 I am interested in the smaller 47" M471i-A2 model - trying to keep the 2-screen family room not to be screen dominated to look like a conference room.ttHh8k
vislld is offline
Old 12-03-2013, 07:07 PM
chrisg54's Avatar
Just picked up my 70" Vizio M-Series tonight. Got it set up. Perfect panel. Absolutely no light bleed or hot spots. Looks flawless. Did calibration according to Ursa's settings in combination with the Disney WOW disk. Stunning picture!!!! Now just need to pick up a mount. Any suggestions? :)
chrisg54 is offline
Old 12-03-2013, 07:48 PM
RiskTaker's Avatar
Has anyone been able to successfully calibrate a 50".  I scanned through the past few pages and didn't see anything.  Right now I am using the default calibration mode
RiskTaker is offline
Old 12-03-2013, 08:17 PM
lotohnz's Avatar
Quoted: 42 Post(s)
Liked: 51
Originally Posted by Infinite Xero View Post
I just got my M50 from Best Buy today and I have a minor audio issue.
My previous TV had an 3.5mm audio jack on it that I would use with my Klipsch Promedia 2.1 speakers. When I would listen to audio from my PC onto my TV, I could control the audio with the TV remote. I can't seem to figure out how to do this with my Vizio. I got a 3.5mm to RCA convert adapter so I could connect my Klipsch to my TV and while they work, the audio isn't controllable with the TV remote when I'm using my PC. Is there a way to fix this?
EDIT:
When using my PS3, the audio is only controlled through the Klipsch's satellite sound control so I can't use the TV Remote to adjust the sound either.
In the "Audio" menu, switch "Analog Audio Out" from "fixed" to "variable".
lotohnz is offline
Old 12-03-2013, 08:20 PM
jasonamd's Avatar
EDIT:
The audio out on the TV is a fixed level meant to be controlled through an external amplifier. The TV volume control will not change it.
jasonamd is offline
Old 12-03-2013, 08:21 PM
Matthew1785's Avatar
So in my previous post to KC-Technerd I stated I felt I was having some uniformity issues in the top right hand corner, so i took a flathead screw driver and slightly loosened the screws in that particular corner.. I took some pictures of the uniformity beforehand and after I loosened the screws. Basically with the backlight set to 33 uniformity is non-existent but I have to up the brightness to compensate
I took 3 pictures with different levels of the backlight I‘ll have to upload them tomorrow and I'd like an opinion if you guys think its bad or an ok TV
Matthew1785 is offline
Old 12-03-2013, 08:46 PM
bigcat's Avatar
Quoted: 93 Post(s)
Liked: 26
How about the settings here
Originally Posted by vestaviascott View Post
 "A2" series panels (
50", 55", 65") Calibration Settings (From Cnet.com)
Picture Mode: Calibrated or Calibrated Dark
Backlight: 62
Brightness: 51
Contrast: 82
Color: 49
Tint: 0
Sharpness: 0
Colour temperature: Normal
Red Gain: 489
Green Gain: 460
Blue gain: 381
Red offset: 517
Green offset: 510
Blue offset: 515
Auto Brightness Control: Off
Black Detail: Off
Smart Dimming: On
Smooth Motion Effect: Off
Reduce Signal Noise: Off
Reduce Block Noise: Off
Film Mode: Auto
50", 55", 65" Calibration Settings (From Dr. Schankenstein)
Picture Mode: Calibrated Dark
Backlight: 50
Brightness: 52
Contrast: 73
Color: 53
Tint: 0
Sharpness: 20
Color Temp: Normal
Red Gain: 525
Green Gain: 472
Blue Gain: 443
Red Offset: 505
Green Offset: 512
Blue Offset: 514
Black Detail: Off
Smart Dimming: On
Film Mode: Auto
BenQ W1070/Silver Ticket 120"/Denon X4200W/Infinity Primus | Vizio 80" 3D LED M801D-A3 w/ Denon X3200W/Infinity Primus | Sony Bravia XBR-60LX900 w/ Sony HTCT550W 3D Sound Bar | Sony SXRD KDS-R70XBR2 w/ Onkyo HT-S770 | Sony PS3 (Slim) | DIRECTV Genie HR44-500, C41s | Harmony 700
bigcat is offline
Old 12-03-2013, 08:52 PM
KC-Technerd's Avatar
Quoted: 64 Post(s)
Liked: 137
See post #5861,
& post #2421,
& item #8 in this post: Official Vizio "M-Series" Razor Owners Survival Thread post #2.
KC-Technerd is offline
Old 12-03-2013, 08:57 PM
Infinite Xero's Avatar
Quoted: 12 Post(s)
And thanks for explaining the problem.
TV: VIZIO M501d-A2
Speakers: VIZIO S4251w-B4​
Infinite Xero is offline
Old 12-03-2013, 09:58 PM
twilly7's Avatar
I am getting the same green line on the right side of my tv. I also have Comcast. It's about a half inch thick and highlighter green. However does it only come up for you on Standard Def channels? Mine adjusts the picture when I change to an HD. Anyone else having this problem and have a solution?
twilly7 is offline
Old 12-03-2013, 10:38 PM
Quoted: 12 Post(s)
It seems to be asked a lot, but I never see an answer to the question: Has anyone calibrated the M50 for games/with game mode? Currently I'm using Dr. Schankenstein's settings but with game mode enabled and smooth motion set to high for use with my PS3 and PS4. For some reason, I have a feeling this isn't the proper way to go about calibrating the TV so if anyone has anything better/tested, it would be appreciated.
TV: VIZIO M501d-A2
Old 12-03-2013, 11:02 PM
PeterNincompoop's Avatar
Quoted: 49 Post(s)
Liked: 88
Originally Posted by Bond 007 View Post
Reread them again. It says they will be thicker. Just like the Samsung direct lit they have to be.
The current edge-lit E-series 55 is 1.9 inches thick - the proposed upcoming full-array version of the E-series 55 will be 2.5 inches. That's almost an imperceptible increase in depth...
As Tigepilot said, we'll see in one short month if they will be offering a product worth waiting for in lieu pulling the trigger now on an edge-lit. I can wait 6 months if need be as I WANT a new TV, I don't need one wink.gif
PeterNincompoop is offline
Old 12-03-2013, 11:05 PM
walstylez's Avatar
What's up guys, ordered my M601D from Amazon the other day. Didn't get a service plan for it, does anyone recommend that I look at some sort of a service plan for this TV? I see a lot of folks telling me great things about the TV, I can't wait!!!
walstylez is offline
Old 12-03-2013, 11:48 PM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 79
I just wanted to thank everyone for their contribution to this thread. I spent a good amount of time reading through reviews and I'm convinced that I should give the Vizio M series a serious look. Unless I see something I don't like, which is highly unlikely based on the reviews I'm reading, I will most likely pick up a M80.
Over the past several weeks I've been obsessing over which TV to buy. I've been toggling between the Samsung 75" 7100 and 8000 series. I wasn't blown away by either display at BB (I know it's not the ideal set up) so I didn't pull the trigger. For less money I can get a bigger TV. At about 12' to 13' feet away I'm convinced the 80" will provide a great immerse experience -- not to mention I'm upgrading from a 52". And my wife absolutely prefers the passive 3d technology over active. Can't wait to check it out at Costco.
josephpearson and chrisg54 like this.
Dolby Atmos 5.1.4
Denon x6200
Ascend Acoustics Towers and Horizon Center (NrT)
RSL 34CE in-ceilings (4)
Rythmik E15HP
Jahjd2000 is offline
Old 12-04-2013, 06:17 AM
cash70's Avatar
Originally Posted by chrisg54 View Post
Just picked up my 70" Vizio M-Series tonight. Got it set up. Perfect panel. Absolutely no light bleed or hot spots. Looks flawless. Did calibration according to Ursa's settings in combination with the Disney WOW disk. Stunning picture!!!! Now just need to pick up a mount. Any suggestions? smile.gif
Did you make any changes to Ursa's settings after running the WOW disk? Thanks!
cash70 is offline
Old 12-04-2013, 07:03 AM
bigcat's Avatar
Quoted: 93 Post(s)
Liked: 26
This happened to me couple of days ago. I was watching a bluray movie (out of my PS3) and suddenly the picture broke completely, looked like watching a 3D picture without the glasses, and the vertical solid green line appeared at the same time. I had to quit playback, and the picture went back to normal. I have since watched three more movies and it hasn't happened again. At the time I thought maybe an issue with the disc I was watching but the fact that others are seeing this points to a defect, hopefully software, but could be hardware. If I see it again, I'll take a picture and try to have the TV replaced.
bigcat is offline
Old 12-04-2013, 07:45 AM
PatrickGSR94's Avatar
Originally Posted by PatrickGSR94 View Post
Well I tried putting it on Game mode and the lip sync issues do seem to be much less than on Calibrated Dark. I just don't understand what the difference is. There is no issue at all if I run audio from the DVR to the AVR. But if I run audio through the TV to the AVR (TV speakers turned off) I have the lip sync issues in Calibrated Dark mode.
When I get a BRD player for this room I'll run the S&M calibration BRD from the Game mode setting.
Well crap I was still getting noticeable audio lag last night from a recorded program on my D* DVR with the TV set to Game mode. frown.gif
PatrickGSR94 is offline
Old 12-04-2013, 10:12 AM
RetiredNow's Avatar
Quoted: 47 Post(s)
Liked: 26
Ja.... maybe you should tell your wife that you are waiting a few more days until the new XVT 4K's come out that won't require glasses to see 3D.
RetiredNow is offline
Old 12-04-2013, 10:20 AM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 79
Good call! Thanks for the heads up regarding the XVT's release date. The market seems to be at an inflection point. New 4K hitting the market putting downward pressure on current 1080p models, and competitively priced 4K models to boot.
Dolby Atmos 5.1.4
Denon x6200
Rythmik E15HP
Old 12-04-2013, 11:09 AM
waylo88's Avatar
Quoted: 76 Post(s)
Liked: 61
Cable and satellite providers still haven't been able to figure out 1080p and now we're expected to move to another even more bandwidth intensive format? 4K seems completely unnecessary at this point in time and going forward. It's going to be YEARS before cable or satellite providers can even make a valid attempt 4K.
waylo88 is offline
Old 12-04-2013, 12:00 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
http://www.avsforum.com/t/1503585/official-vizio-streaming-thread-mkvs-mp4s-etc
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
Old 12-04-2013, 01:13 PM
tigepilot's Avatar
4K does make good sense regarding passive 3D and that I think is why he might be interested in it based on prior post. But yeah, you're right about the rest. I don't watch enough and won't watch enough 3D for me to care much about this 4K thing but I can see why someone would.
tigepilot is offline
Old 12-04-2013, 02:27 PM
RetiredNow's Avatar
Quoted: 47 Post(s)
Liked: 26
4K Blu-ray 3D is the way to go and is coming on line now....everything else is obsolete and a waste of money......but remember if you want a Sony or Pany effect just get the new 4K Blu-ray players coming on line that uses its internal hardware instead of your TVs. You don't need a smart TV if you have a smart Blu-ray player.
Old 12-04-2013, 03:06 PM
Keith Lashinski's Avatar
Yeah if you have the dough to spend. Some of us can't afford a 4k TV and a 4k blue ray player.
Keith Lashinski is offline
Old 12-04-2013, 03:11 PM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 79
^^^ this. If a 4K set can be had at a reasonable price and provide a better passive 3D experience, I'd consider it. How much more am I willing to pay to "future proof" my TV I've yet to determine.
Dolby Atmos 5.1.4
Denon x6200
Rythmik E15HP
Old 12-04-2013, 03:35 PM
HofstraJet's Avatar
Quoted: 17 Post(s)
Has anyone successfully used a QWERTY remote with one of these sets (specifically the M501D-A2R)?
I got one on Black Friday and want to see which QWERTY remote I should get, if any.
HofstraJet is offline
sony dhg-hdd250 , Vizio 32 Inch Smart Led Hdtv , Vizio 55 Inch Class Theater 3d Edge Lit Razor Led Lcd Hdtv M3d550sl , vizio m401i-a3 40" hdtv , Vizio M471i A2 47 Inch Smart Led Hdtv , Vizio M551d A2r 55 Inch 3d Smart Led Hdtv , Vizio M601d A3r 60 Inch 3d Smart Led Hdtv , Vizio M651d A2r 65 Inch 3d Smart Led Hdtv , Vizio M701d A3r 70 Inch 3d Smart Led Hdtv , Vizio M801d A3 80 Inch 3d Led Hdtv
