Official Vizio M-Series Razor Mxx1i thread - Page 217 - AVS Forum | Home Theater Discussions And Reviews
 264Likes
post #6481 of 10635 Old 12-19-2013, 01:55 PM
Bond 007's Avatar
Quoted: 2375 Post(s)
Liked: 1911
Check out Pacific Rim. Very cool in 3d.
Licence to Kill
Bond 007 is offline
post #6482 of 10635 Old 12-19-2013, 02:20 PM
PatrickGSR94's Avatar
I think Gravity will definitely be one to add to that list when it comes out on BRD. 3D was a big part of the story in that movie.
se7encrows likes this.
PatrickGSR94 is offline
post #6483 of 10635 Old 12-19-2013, 03:32 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
I just watched Gravity in HD. Streamed. It was ok. Pacific rim is still my best choice to show off this TV.
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
post #6484 of 10635 Old 12-19-2013, 03:36 PM
BigBeard's Avatar
Quoted: 26 Post(s)
Hey all, ne guy here.
I just got the 50-inch m series 240hz 3d tv a few days ago.
Two issues:
I have an external hdd that I connected to the tv. the tv reads the drive fine...except that the movies in it do not show up at all - they are in mkv format dts audio. however, I also have pictures on the hdd and those show up just fine.
Second...what is the best dlna windows app to use for the vizio? I downloaded the ps3 media server. the tv also connect fine to that - I can see all the movies, but when I click on a movie, the tv freezes. on my pc is shows a massive buffer size that is declining very slowly. How di I properly set this up so it will work? Can the 3v play mkv files without transcoding? how do I set up ps3 media server properly?
BigBeard is offline
post #6485 of 10635 Old 12-19-2013, 04:03 PM
jtl46's Avatar
Quoted: 97 Post(s)
Liked: 50
Originally Posted by noeffort View Post
Out of stock, glad I got my m70 delivered last week.
They maybe are not getting anything in from Vizio. The new models with full back lit led are being introduced early next month at the CES so I would bet the current version is not longer in production. I for one will be all over that after the miserable experience I have had with the LB on the current model (3 returns and they were all basically the same).
jtl46 is offline
post #6486 of 10635 Old 12-19-2013, 04:08 PM
brokedrifter's Avatar
Watching Jurassic Park Blueray on my M50 after a Disney wow calibration and installation of my sony 660 sound bar! Wow I just fell in love with my tv again! Maybe it's just I love Jurassic Park?? Either way very happy person right now!
brokedrifter is offline
post #6487 of 10635 Old 12-19-2013, 04:58 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
Two issues:
Forget PS3 media server. It will not work with our tv's, especially with MKV and DTS audio!
I've worked with vizio and a media server company to fix this, and exactly for MKV's with DTS audio smile.gif among others. Download TvMobili. After install, under "status" tab, change to "vizio client" and it will work! Report back.
Note (if you have an xbox, you can get around going through the tv, but the above fix lets you use the tv to do it)
Sniperman likes this.
Harmony 890 Remote
Jasonn B is offline
post #6488 of 10635 Old 12-19-2013, 08:06 PM
Sniperman's Avatar
Originally Posted by waylo88 View Post
I'm also on V1.06.6.1136. It's the FW I've been on since I bought my television (M50) back in like June or July.
got mine from amazon a couple weeks ago, it has 1.06.10.1310 havent been prompted for any update and no wifi remote.
Sniperman is offline
post #6489 of 10635 Old 12-19-2013, 08:20 PM
indept's Avatar
Quoted: 84 Post(s)
Liked: 92
My M551D has ver: 1.06.8.1285
indept is online now
post #6490 of 10635 Old 12-19-2013, 08:55 PM
BigBeard's Avatar
Quoted: 26 Post(s)
thanks for the advice. I just downloaded on my computer to see how it works. is this just a free trial, because there is an option to purchase this.
Also, I just tested 4 different movies - the video plays fine, but the tv says "no audio codec" or something like that; there is no sound from the movies. any idea on what is the problem?
BigBeard is offline
post #6491 of 10635 Old 12-19-2013, 09:01 PM
vitalius24's Avatar
Originally Posted by ironicninja View Post
Is it me or is the 70" version no longer available on costco.com?  They still have the E-series version up there.
try your local store, I was just at costco and they have M 70" and 80" in store.
vitalius24 is offline
post #6492 of 10635 Old 12-20-2013, 07:22 AM
gepetto420's Avatar
Originally Posted by KC-Technerd View Post
Here's the latest calibration results for the M501d-A2R, using Spears & Munsil HD Benchmark 2nd Edition on a Sony BDP-S5100 Blu-ray player outputting RGB connected to the Vizio's HDMI 1 input.
2D
Picture Mode: Computer
Backlight: (100) Auto-Mid
Brightness: 53
Contrast: 63
Color: 45
Tint: -2
Sharpness: 0
Auto Brightness Control: Mid
Black Detail: Off
Smart Dimming: Off
Smooth Motion Effect: Off
Reduce Signal Noise: Off
Reduce Block Noise: Off
Film Mode: Auto
Color Temperature: Normal
Red Gain 545
Green Gain 472
Blue Gain 443
Red Offset 517
Green Offset 512
Blue Offset 514
(Blue Bars Color 43 Tint -5)
(Green Bars Color 46 Tint +2)
(Red Bars Color 47 Tint -1)
3D
Brightness: 53
Contrast: 63
Color: 45
Tint: -2
Sharpness: 0
Black Detail: Off
Smart Dimming: Off
Film Mode: Auto
Red Gain 545
Green Gain 472
Blue Gain 443
Red Offset 517
Green Offset 512
Blue Offset 514
(Blue Bars Color 42 Tint -5)
Note: The color settings of Color: 45 and Tint: -2 were an attempt to average the differences between how the color decoder handles different colors. This TV definitely has an unusual blue push in the color decoder. Hopefully someday soon someone will learn how to access the service menu and find settings to adjust the color decoder to eliminate this.
Also the color temperature settings are simply the TV's default "Normal" for HDMI 1. I do NOT have the proper equipment to calibrate the color temperature at this time. I found that, strangely, the default "Normal" color temperature settings for the internal ATSC TV tuner were different, so I readjusted those to match the ones listed above. These should be the ones that CNET used prior to adjustment that resulted in them measuring a perfect D65 color temperature.
I tried these settings on my 55" It looks pretty good. I think it helped my 3d viewing a lot. Computer mode is like the extra special sauce mode. Never gave it much of a chance.
gepetto420 is offline
post #6493 of 10635 Old 12-20-2013, 08:32 AM
ursa99's Avatar
Quoted: 36 Post(s)
Liked: 100
Probably need to reencode movie audio to AC3. I had the same problem and that fixed it...
Ursa
ursa99 is offline
post #6494 of 10635 Old 12-20-2013, 08:43 AM
BigBeard's Avatar
Quoted: 26 Post(s)
Ursa
thanks. what is the easiest way to go ahead and do that?
BigBeard is offline
post #6495 of 10635 Old 12-20-2013, 08:56 AM
sanjava's Avatar
Hi All,
I was researching in forums to replace my Sony 46"  nsxgt1 Google TV and decided to buy Vizio M651-A2R.  I had purchased it from amazon warehouse deals for $1400. But when the package arrived  yesterday I saw vizio logo at the bottom broken and TV stand didn't had any screws.  I went to Home Depot and purchased the screws and fixed the TV.
I had tested the TV for 12 hours,. TV looks good and we also watched A Turtle's Tale: Sammy's Adventures in 3D and my kids enjoyed a lot. I had contacted Amazon for support and asked me to call Vizio Support. Unfortunately Vizo support does not honor Amazon Warehouse Deals, so, I cannot get warranty on the product, but they said, broken Vizio logo does not impact the TV and you can enjoy watching TV it without any issues.
So, I am little confused  Amazon offered $300 further discount on TV  making it $1100 , but I am worried about warranty.  I purchased 4 year warranty from Square Trade and filed a claim and they said it a prexisting condition so, they don't cover it.
sanjava is offline
post #6496 of 10635 Old 12-20-2013, 09:01 AM
I'm guessing those Amazon warehouse deals are a "sold as-is" type of thing?
post #6497 of 10635 Old 12-20-2013, 09:21 AM
joboujp's Avatar
I got the M471i yesterday and although I like the TV overall I 'm having huge back-light bleeding in the top and bottom right corners.
So I'm thinking of returning it for a Samsung 46F6350 that is 100$ more because I'm not sure it is a problem with that specific TV or the M47i series. frown.gif
joboujp is offline
post #6498 of 10635 Old 12-20-2013, 09:51 AM
waylo88's Avatar
Quoted: 76 Post(s)
Liked: 61
Light bleed is a problem with all of these thin LED's. It's not limited to a specific brand.
waylo88 is offline
post #6499 of 10635 Old 12-20-2013, 10:12 AM
deverett's Avatar
I have used PopCorn MKV AudioConverter for my audio converting needs many time. Everyone prefers a their own program but it all boils down to the same thing. Use a program to browse to your file then let it do it's thing. In the end you should have a converted file that will play the audio the way you need it. If anyone has any other program suggestions feel free to share.
Oh and as far as 3d movies go, Pacific Rim all the way. First saw it at IMAX 3D, had to buy it.
deverett is offline
post #6500 of 10635 Old 12-20-2013, 10:16 AM
joboujp's Avatar
I know it a issue but i have a 32" insignia were i don't notice as much light bleed.
So maybe the samsung is not as bad for bleeding and will keep the same picture quality.
joboujp is offline
post #6501 of 10635 Old 12-20-2013, 02:12 PM
ursa99's Avatar
Quoted: 36 Post(s)
Liked: 100
I can say there is nothing particularly easy about encoding when you are starting from the beginning. Here is the tool I use.
http://www.connecta2000.com/BDtoAVCHD/?lang=en
Fill in the blanks, particularly the one marked "Target Audio" and see what happens.
Ursa
ursa99 is offline
post #6502 of 10635 Old 12-20-2013, 02:24 PM
Matthew1785's Avatar
So I have a question, I've owned this TV (M501d-ar2) since the end of September, I've been screwing around with the settings for months now and it's apparent in the middle right hand side of the TV is noticeable DSE during certains scenes. it's worse during watching TV on the DirecTV and less noticable like if im watching an actual movie on netflix. I really dont know how else to explain it.
First I'd like some reassurance that it's normal and second why is it more apparent on watching live TV vs watching a movie. Thirdly if it keeps on annoying me what are my options? replacement? Having Vizio look at it? return it to bestbuy? I have a 2 year geek squad protection..
BTW I'm using KC-Technerd's recent calibration settings and seem's to help some what.
Matthew1785 is offline
post #6503 of 10635 Old 12-20-2013, 03:28 PM
goldmine848's Avatar
Originally Posted by srg914 View Post
I can't say that the remote works pointing it anywhere.  However, I can point it facing the ceiling or to the sides of the tv and it works.  Like I said, before the update I had to point it directly at the lower left.  I agree about Vizio's method of providing firmware.  The Samsung I exchanged for the Vizio had an option in the system menu to check for firmware updates and install them on demand.  But the Samsung's screen uniformity was horrible, so weighing it all out, I'm much happier with this Vizio.  I use my Verizon fios remote to control the TV's basic functions anyway, I only use the Vizio remote to adjust picture settings, etc.
I have version V108.12.0000 on my 60 "....the remote info says unpaired...is there something you need to pair it assuming I have the correct version?
goldmine848 is offline
post #6504 of 10635 Old 12-20-2013, 03:37 PM
srg914's Avatar
I didn't have to pair anything....
srg914 is offline
post #6505 of 10635 Old 12-20-2013, 03:46 PM
thanks...do you know what version you have?
post #6506 of 10635 Old 12-20-2013, 05:21 PM
Padinn's Avatar
Quoted: 26 Post(s)
My wireless mysteriously stopped working. Says its connected, but no internet apps work....hmmmm...
Padinn is offline
post #6507 of 10635 Old 12-20-2013, 06:02 PM
Sniperman's Avatar
not really, amazon warehouse deals has the same kind of return policy as anything else amazon sells, they used to be really good in checking everything they sent out, but recently things have gotten really bad, but returns are easy and they pay for return shipping and everything.
that little vizio tab must get broken more than i thought, i accidentally broke mine during unpacking but managed to glue it back on i would have kept it off as i prefer not having it, but as you can see from his picture it covers part of some pcb.
post #6508 of 10635 Old 12-20-2013, 06:37 PM
srg914's Avatar
~~V1.06.6.1136...65 inch
srg914 is offline
post #6509 of 10635 Old 12-21-2013, 12:46 AM
Sniperman's Avatar
i added some "ambient" lighting to my tv, thought i would share, can basically change it to any spectrum and has diff modes like flashing or fading all with a remote.
post #6510 of 10635 Old 12-21-2013, 02:24 AM
PDDUFRENE's Avatar
Liked: 50
That looks pretty cool! Is that some kind of kit u bought to do that? Are is it something you just rigged together yourself?
PDDUFRENE is offline
Reply LCD Flat Panel Displays
sony dhg-hdd250 , Vizio 32 Inch Smart Led Hdtv , Vizio 55 Inch Class Theater 3d Edge Lit Razor Led Lcd Hdtv M3d550sl , vizio m401i-a3 40" hdtv , Vizio M471i A2 47 Inch Smart Led Hdtv , Vizio M551d A2r 55 Inch 3d Smart Led Hdtv , Vizio M601d A3r 60 Inch 3d Smart Led Hdtv , Vizio M651d A2r 65 Inch 3d Smart Led Hdtv , Vizio M701d A3r 70 Inch 3d Smart Led Hdtv , Vizio M801d A3 80 Inch 3d Led Hdtv
