Official Vizio M-Series Razor Mxx1i thread - Page 323 - AVS Forum
post #9661 of 9668 Old 07-26-2014, 06:48 PM
KC-Technerd's Avatar
Quoted: 13 Post(s)
Liked: 96
Latest attempt on M501d-A2R settings. (Sony BDP-S5100 outputting RGB and Spears & Munsil 2. Results using the YCbCr options yielded inferior performance to RGB on the Spears & Munsil Colorspace Evaluation pattern.) I forgot to capture the full version number on the Vizio, but it is the 1.34 version. I did a factory reset just prior to this. Even after the factory reset, the picture still comes up with odd coloring such as green/purple flesh tone hues and reduced color intensity until the top banner disappears after the TV is first turned on.
Grayscale was left at defaults, as CNET's calibration report for the M551d-A2R shows good RGB balance and grayscale results pre-calibration, with the pre-calibration actually being better at 100IRE, and more uniform across the scale than the post-calibration, although with a very slightly higher overall dE. Based on their report, the variances between pre and post calibration appear to be so small as to be imperceptible. Whether the post firmware update default grayscale is the same as the pre firmware update default grayscale is debatable (as I don't have equipment to accurately measure it). Hopefully there was no change made.
The CMS options are still confusing to me. This time I tried to correct the color setting patterns using only the color brightness controls, rather than using the hue controls for the secondary colors. I'm uncertain if this is correct, although the results appear correct based upon the color test patterns for red green and blue. If the Vizio is a wide gamut display, meaning that it uses primary colors that are saturated beyond rec. 709 specs and then uses the CMS to compensate, my methodology for setting the color and hue controls, as well as the CMS controls may be incorrect. However this would also likely make the blue only (as well as the red and green only) options pointless, as none of display's primary colors would ever be displayed alone when reproducing a rec. 709 (HDTV) image. Mixing of the primary colors would always be necessary in order to desaturate the primary colors to rec. 709 specs.
Does anyone know for sure if the Vizio M series used rec. 709 primaries, or if it is a wide-gamut display?
In any case, I'm quite satisfied with the image and color quality for Blu-ray discs. I copied these settings for the internal ATSC receiver, and the results while watching OTA TV seem more questionable. This may be an indication that the Sony BDP-S5100 chroma output is above standard (which I experienced with a BDP-S1).
KC-Technerd is offline
post #9662 of 9668 Old Yesterday, 12:13 AM
CleCakYngMfd's Avatar
Quoted: 21 Post(s)
Originally Posted by samurai66 View Post
After 6 months, I've probably changed the batteries around 6-8 times, which seems way too often.
I'll admit that I often tweak the picture, but that's all I use the remote for.
That IS TOO OFTEN!
I get about 1-and-a-half months of battery use with my Vizio remote (Sticker inside says Feb 2013). I think the Wi-Fi will eat the batteries even quicker, so I unpaired my remote (Wi-Fi Off).
My remote for the Sony DVR is used much more often and I get about a year out of those batteries!
Something is very, very wrong with this remote. This surely cannot be the expected lifespan of the batteries for this Vizio remote?
- Pj
Vizio M401i-A3 (40") V1.34.31.0080. APC Back-UPS for DHG250 V1.2.21; Did UserConfigReset (no TVGOS Patches, FPC); 653214741 Reset aprx 12am every 4th, 5th, or 6th Thu. No CableCard. OTA & Analog/Digital Cable Service*. ClearStream-4 to DTX9950 to Composite-In of Philips 3576H; RF-In to local Cable*. WMC with WinTV-HVR-2250.
CleCakYngMfd is offline
post #9663 of 9668 Old Yesterday, 11:33 AM
Liked: 0
Is Remote RF?
I just bought the VIZIO M602i-B3 60-inch and it is on its way through the mail. I was wondering if the Remote is RF? Also if not where on the front of the TV is the Sensor for the remote?
8whosnext8 is offline
post #9664 of 9668 Old Yesterday, 01:08 PM
laserjock II's Avatar
Liked: 46
Should be RF depending on which firmware it's at and sensor on TV is bottom left, underside edge of TV as you're looking at the TV from the your viewing position.
laserjock II is offline
post #9665 of 9668 Old Yesterday, 07:12 PM
renji1337's Avatar
Quoted: 34 Post(s)
I see some of you guys using like 50 contrast, how is that possible?
In my AVS HD test I only see 230-235 flash reguardless of contrast, I never see the others but I need like 82 contrast to barely see 235 flash.
m492i is my tv. using a HTPC aswell.
renji1337 is offline
post #9666 of 9668 Old Yesterday, 08:42 PM
Quoted: 13 Post(s)
Liked: 96
Your HTPC is obviously outputting PC level RGB video rather than video level. Are there any options on it for the ColorSpace or video range, which might be labeled as YCbCr, RGB FULL, RGB Limited, RGB PC, RGB Video, SuperWhite, etc.? (Sorry, I'm not familiar with the HTPC options.)
If you cannot select a video level output option (which should restore the flashing of levels above 235) then select the HIGHEST contrast where 234 flashes (on the individual R G and B patterns if you have them. 235 should be the peak white level with PC levels, so if you are seeing it flashing at all that is simply because your HTPC isn't perfectly clipping at 235, as it should be for PC levels.
post #9667 of 9668 Old Yesterday, 09:39 PM
renji1337's Avatar
Quoted: 34 Post(s)
^apparantly I am seeing all 235+ flash. I have my nvidia gpu set to let the video player decide and then XBMC set to 16-235. I turned my contrast down and I can see more flash now but how should I have it set? If I have my contrast at 82 I can barely see 235 flash.
If I use 50-55 like I see alot of people doing I see all the way to 253 flash lol
post #9668 of 9668 Old Yesterday, 10:14 PM
Quoted: 13 Post(s)
Liked: 96
From what I can find having XBMC set to "Use limited color range (16-235)" is correct. This should allow the flashing all the way to 253 as you describe. Set your contrast to the highest possible where you can still see 253 flash. If you find while making this adjustment that the color between the flashing bars and the background shifts, then start with the contrast low and turn it up as high as you can before the color starts to shift (while still leaving the 253 bar flashing). This should be a contrast setting slightly less than that where 253 quits flashing. The color shift indicates that one of the primary colors is clipping before the others. On the M501d-A2R that I adjusted 65 was the appropriate setting. Setting the TV to discernibly show all the brightness levels up to 254 will prevent loss of detail in the brightest whites and colors, which in real video often exceed the reference 235 peak brightness level and use the headroom above it.
With XBMC set to "Use limited color range (16-235)" you should also be able to discern the black bars 16 and below if the brightness is set to high while viewing the AVS HD709 brightness pattern.
Reply LCD Flat Panel Displays
sony dhg-hdd250 , Vizio 32 Inch Smart Led Hdtv , Vizio 55 Inch Class Theater 3d Edge Lit Razor Led Lcd Hdtv M3d550sl , vizio m401i-a3 40" hdtv , Vizio M471i A2 47 Inch Smart Led Hdtv , Vizio M551d A2r 55 Inch 3d Smart Led Hdtv , Vizio M601d A3r 60 Inch 3d Smart Led Hdtv , Vizio M651d A2r 65 Inch 3d Smart Led Hdtv , Vizio M701d A3r 70 Inch 3d Smart Led Hdtv , Vizio M801d A3 80 Inch 3d Led Hdtv
