Official Vizio M-Series Razor Mxx1i thread - Page 337 - AVS Forum | Home Theater Discussions And Reviews
 264Likes
post #10081 of 10637 Old 12-16-2014, 07:40 AM
Liked: 3
Originally Posted by drameddie View Post
Can you guys explain where is Smart Dimming? Is it even labeled as smart dimming in the menu because i don't see it.
Mine is called "Active LED Zones"
Robin Halabicki is offline
post #10082 of 10637 Old 12-16-2014, 08:17 AM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
What set is this?
rakstr is offline
post #10083 of 10637 Old 12-16-2014, 09:07 AM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
Update on the 1.60 Update
As I've mentioned before, I have 4 of the 2013 M-Series sets thanks to mother nature and lightning. I have a 65" and a 70" that were purchased on 11/22/2013, a 40" that was purchased on 1/30/2014 and a 47" purchased on 4/27/2014; All from Costco.
I've been in high tech for almost 40 years now. I agree with whomever mentioned differences with product within a model series. I've seen it cost some rather large Companies a significant share of wallet by not standardizing their component supply chains sufficiently and using "supposedly" the same component from multiple vendors through a long term production run only to find that they ended up supporting multiple revisions of firmware because of tolerances amongst the build parts. You try to convince a Fortune 100 IT department that it needs to use serial numbers and not model numbers when it comes to applying patches/updates. That said, it costs more to secure that supply chain and thus you must charge more. All trade offs. I guess that's a long way to say, there is validity to certain builds behaving differently and I suspect Vizio has figured this out.
I've received the update to 1.60 for the 40", the 47", and the 70". The 65" is in the Family Room and is on quite a bit. That's the only explanation I have for it having not yet received 1.60 for that set.
For all 3 sets with 1.60, my Picture Mode was changed to one of the presets as a result of the update. In all cases I selected "Calibrated Dark" to begin my "tuning" and then saved my settings to a new Custom Profile.
In all cases, I've been able to set Smart Dimming to OFF, "calibrate some items", and SAVE the new settings to a NEW custom profile. I then powered down the set(s) and observed that Smart Dimming remained OFF through multiple power OFF/ON cycles.
Last night I unplugged all 3 of the updated sets to see if there was anything that may be connected with a complete power cycle. This morning I powered them all up and Smart Dimming was still set to off. I also do not see the "flash to bright" being mentioned on any of the sets but I will admit, I have NOT really looked for it. Besides, if as reported it is a 1-2 second temporary item and the picture rapidly stabilizes to the intended settings, I don't really care.
For complete background, all three of these sets are connected to the same source as follows. All other connected sources not mentioned on the various switches are capable of the same resolutions and display capabilities (except for 3D of the 70; when I want to watch 3D I power down the first 1x4 switch and re-negotiate). Another way to put this is the lowest common denominator would be the 40 for purposes of HDMI handshake negotiations.
  • DTV HR24-100 -> 3' HDMI cable -> Yamaha RXA1020 (pass-thru enabled)
    • -> Yamaha RXA1020 (HDMI out 1, processing enabled to 1080P) -> 6' HDMI -> 70"
    • -> Yamaha RXA1020 (HDMI out 2)
      • -> 6' HDMI cable -> 1x4 HDMI Splitter/equalizer/amplifier
        • -> 30' HDMI -> 40"
        • -> 25' HDMI -> Monoprice 1x4 HDMI over CAT5E/6 (75') -> 47"
Additionally, all my sets are connected via WiFi to a separate AP on a separate channel from the AP I use for my computers and all my sets have the WiFi remote enabled (much earlier in this thread I mentioned it was an important feature for my use). This separate AP keeps any/all "interference" from my normal and allows for me to easily keep the WiFi remotes functioning while isolating the sets from the internet.
rakstr is offline
post #10084 of 10637 Old 12-16-2014, 10:27 AM
goldmine848's Avatar
Rakstr, I too see little if any of the flashing issue. But I do see odd flesh tone variations and clay-like appearance. This was not present before the update. I wonder if you are seeing any of these issues on your sets?+
goldmine848 is offline
post #10085 of 10637 Old 12-16-2014, 11:06 AM
korbink's Avatar
Just to note, the Smart Dimming feature appears off in the menu after power cycling, but it's very apparent that the feature is actually turned On. It won't actually be Off until you cycle it from Off to On then Off again.
korbink is offline
post #10086 of 10637 Old 12-16-2014, 11:10 AM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
You have the non 3D model correct?
PlayNice is offline
post #10087 of 10637 Old 12-16-2014, 11:16 AM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
THX, I did perform multiple OFF/ON cycles as indicated. I was trying to highlight that the setting did remain off with no other apparent ill-effects.
rakstr is offline
post #10088 of 10637 Old 12-16-2014, 11:27 AM
Liked: 0
Since the 1.60 update, I'm also having the "Smart" Dimming issue with my M551d-A2R (it's not listed as Active LED Zones on my model). I am able to toggle the setting as a work around, but it is definitely annoying to have to do it for each power cycle. I have also emailed the issue to Vizio's support, hoping that if enough of us report the issue, there will eventually be a fix (new update). Very frustrating, as it was working wonderfully prior to the update.
rmiller242 is offline
post #10089 of 10637 Old 12-16-2014, 11:43 AM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
Did you try saving your changes to a new custom profile?
rakstr is offline
post #10090 of 10637 Old 12-16-2014, 11:59 AM
korbink's Avatar
I've tried that and it doesn't help.
korbink is offline
post #10091 of 10637 Old 12-16-2014, 12:03 PM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
It might be beneficial for those having issues to try to collect build date information on their sets. That used to be on the box but I don't know if it's still available on these sets. If not build date, perhaps at least purchase dates. Definitely is something strange but as I've said, I have no problems and I've got 4 different models.......
rakstr is offline
post #10092 of 10637 Old 12-16-2014, 01:52 PM
Crakaveli's Avatar
new owner here. i've got a blemish/shadow looking spot on the screen. it's especially noticeable watching football. other times it's noticeable is light colored scenes with motion. purchased from online retailer b&h.
Crakaveli is offline
post #10093 of 10637 Old 12-16-2014, 03:33 PM
netkrazed's Avatar
I took a quick video to show what is happening on my 80. Have an open ticket with Vizio, they stated most sets are coming back after a factory reset and power off for 3 mins. Didn't fix mine.....and yes, I did call SD auto dimming.
This set was puchased Q3 of 2013.
netkrazed is offline
post #10094 of 10637 Old 12-16-2014, 03:58 PM
waylo88's Avatar
Quoted: 76 Post(s)
Liked: 61
That's the way Smart Dimming works dude, that's not a problem. It's especially noticeable, as seen in your video, when you have a bright image in the middle of a black screen. It's turning off specific LED zones to make them darker, while still leaving certain ones on to light the image in the center.
waylo88 is offline
post #10095 of 10637 Old 12-16-2014, 04:10 PM
fr8doggr's Avatar
Quoted: 16 Post(s)
Liked: 66
I agree, that is the way the smart dimming works...always has. But one of the new problems (among others) now is what Falconman clearly shows on post 10001. When you turn the set on, change channels, or have a dramatic scene change, the backlighting is extremely bright for a second or two before it slowly fades into a good picture. His 4 pictures taken over a few seconds clearly demonstrate one of the problems with the new FW update.
waylo88 likes this.
fr8doggr is offline
post #10096 of 10637 Old 12-16-2014, 04:31 PM
PlayNice's Avatar
Quoted: 185 Post(s)
Liked: 174
Here you go guys, these are the updated calibration settings for my Vizio M801d-A3. As you know these setting may not carry over to your set perfectly however if you are in the Seattle area Contact Digital Imagery Refined @ 206.414.2406 and they can stop by and calibrate your set for you well worth the penny.
Name:	photo 1 - Copy.jpg
ID:	429201   Click image for larger version
Name:	photo 2 - Copy.jpg
ID:	429209   Click image for larger version
Name:	photo 3 - Copy.jpg
ID:	429217   Click image for larger version
Name:	photo 1 - Copy (2).jpg
ID:	429225   Click image for larger version
Name:	photo 2 - Copy (2).jpg
Name:	photo 3 - Copy (2).jpg
Vizio 80" 3D LED M801D-A3 ISF Calibrated | Onkyo TX-NR818 w/ Polk Monitor 50 (Fronts), Onkyo SK-520 (Surronds), SKW-770 (Sub) | Win 8.1 PC i7 3930k, 2 SLI GeForce 770's, 32GB RAM | Mac Mini 2011 i5 2.3Ghz, 16 GB RAM w/ PLEX | Roku 3 | Oppo BDP-103D | Xbox One, PS4, Wii U, Xbox 360 S, PS3 Slim | Harmony Touch
Last edited by PlayNice; 12-18-2014 at 10:49 AM. Reason: Updated settings better grey-scale and CMS. For Pre mode I used Standard, for a laugh to see how off it is.
PlayNice is offline
post #10097 of 10637 Old 12-16-2014, 05:09 PM
netkrazed's Avatar
No no no. SD has not worked this way. Turn the tv on....go to menu, picture, more picture, SD is off. Toggle it on, no change, turn it off, you see the screen brighten. I dont want SD on, I want it OFF. It did not work this way for the last year and a half. There should be NO dimming effect with SD in the off mode, which is where mine is at when you first see the dimming in my video. And as you can see in my video, SD is clearly OFF.
post #10098 of 10637 Old 12-16-2014, 06:03 PM
waylo88's Avatar
Quoted: 76 Post(s)
Liked: 61
Oh, yeah, that's what we've been complaining about for the last few pages. The new firmware is bugged. In order to turn SD off, I need to switch inputs, then go in and toggle it on, then back off again. It should then stay off for as long as your TV is on. You need to repeat that process every power cycle unfortunately.
Your video made it seem as if you were meaning to use SD, but were complaining about the light bleed caused by SD. Sorry for the confusion.
waylo88 is offline
post #10099 of 10637 Old 12-16-2014, 06:08 PM
netkrazed's Avatar
I actually have to change it if i change inputs...luckily i only use two.
post #10100 of 10637 Old 12-16-2014, 06:18 PM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
I used my Disney WOW disk and am happy with the picture. I don't notice the color issues you mention. I do notice less "soap opera" effect than before on the 70 but I've often dismissed most "soap opera" complaints as perception and I haven't watched the 70" TV for a few weeks prior to the update.
rakstr is offline
post #10101 of 10637 Old 12-16-2014, 06:41 PM
fr8doggr's Avatar
Quoted: 16 Post(s)
Liked: 66
Ok, I need to edit my posts. I finally got some time to experiment on my 2013 edge-lit 70 incher. Not only do I have the momentary wash-out problems when first turned on or dramatic scene changes, I now realize I have the exact same problem with the smart dimming as everyone else has.. Thanks Netkrazed for the video. It was very helpful.
Has anyone brought this issue up with Costco? Do you need the original box for their warranty?
netkrazed likes this.
fr8doggr is offline
post #10102 of 10637 Old 12-16-2014, 06:59 PM
netkrazed's Avatar
Good question. I haven't talked to Costco yet. Figured I give Vizio a chance to fix their issue...but not too much time.
post #10103 of 10637 Old 12-16-2014, 09:35 PM
Liked: 3
my reply to vizio, I suggest you keep on them for this.
This issue is still not resolved. Here is the problem that can be reproduced on now 6 different sets of friends and family.
I did a service reset
a Reset TV to Factory defaults.
Set Active LED Zones to OFF
Power off the display
Power on the display
The current setting is set to OFF (like it was in the the power down state). However, viewing any material with bright lights or white will show the fault of the dimming firmware.
Also, going into the more picture setting and setting Active LED Zone to ON shows no difference to the picture, setting it to OFF WILL ABSOLUTELY IMPROVE THE PICTURE meaning the display is capable of turning off the setting.
However, powering off the display will default the display back to Active LED zone to on regardless of the setting.
I am also not the only one : (see url of this forum)
Please either fix this in the next firmware, replace my unit with a P series or something that the firmware works or allow me to update the firmware to anything prior to 1.60 where I know there picture wasn't degraded from this error in coding and I could disable Active LED Zones permanently.
Robin
post #10104 of 10637 Old 12-16-2014, 10:41 PM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
What is the model of your TV? None of mine (4 different sizes of M-Series) have the "Active LED Zone" and I see you didn't answer this Q earlier.
Robin
rakstr is offline
post #10105 of 10637 Old 12-17-2014, 05:05 AM
viper99ta's Avatar
Quoted: 12 Post(s)
I bought my 70" Model #M702i-B3 in September 2014 and just got the update. It has completely ruined all my settings and picture quality stinks now. I had used Spears and Munsil to get a fantastic picture and now it is ruined. Bought through BestBuy but imagine I have to contact Vizio direct. NOT FREAKING HAPPY
viper99ta is offline
post #10106 of 10637 Old 12-17-2014, 05:19 AM
Liked: 3
60" M602i-b3
I would pay to have the old firmware
post #10107 of 10637 Old 12-17-2014, 05:44 AM
viper99ta's Avatar
Quoted: 12 Post(s)
"I would pay to have the old firmware"
Oh yes indeed
post #10108 of 10637 Old 12-17-2014, 06:45 AM
laserjock II's Avatar
Quoted: 769 Post(s)
Liked: 431
60" M602i-b3
Sorry if I'm mistaken but aren't those the 2014 FALD sets?
laserjock II is offline
post #10109 of 10637 Old 12-17-2014, 06:51 AM
viper99ta's Avatar
Quoted: 12 Post(s)
Yes - but I'm unclear what you are asking/meaning?
post #10110 of 10637 Old 12-17-2014, 07:21 AM
rakstr's Avatar
Quoted: 127 Post(s)
Liked: 64
I'm not trying to diminish anyone's pain here because it's always the most important thing when it's happening to you!!!! I think Vizio's method of rolling out firmware updates is very poor but it's been no secret for quite some time now! I've had an "expensive" calibration thrown out the door within weeks of the calibration because of Vizio's firmware changes.
I think some of the point may be that there are a handful of complaints spread out over a number of models so when Vizio says they don't have that complaint you need to take this "diversity" into account. And no, I'm not making excuses, just highlighting that there is no "mass problem" here. I think it was posted that 6 people have complained on this thread and just in the past few posts we can see 2 of them are on different sets. Again, personal pain is always the only pain but, ....
The two "Mxx2i-B" series sets in the past few posts are from a different generation (I believe) and not necessarily the same issue. Not sure all these discussions can necessarily be lumped together. This is after-all the Mxx1i thread, not 2i! Perhaps my 1D sets should not be part of this discussion either. People have tried to start model specific threads but they haven't taken off. Given both Sam's and Costco and a LOT of other big box stores sell these sets, there are a LOT of them out there.
For instance my TVs are
M651D-A2 (11/22/2013) - Still on 1.34
M701D-A3 (11/22/2013) - 1.60, appears to work fine
M401I-A3 (1/30/2014) - 1.60, appears to work fine
M471I-A2 (4/27/2014) - 1.60, appears to work fine
So I'll leave a final thought. I remember when the first generation sets came out and there were some units in some models that had "the buzz" as backlight was turned up. It was a problem and I think Vizio tried to respond. I had one set repaired in house and returned one myself. However, that problem turned into an abuse of the Sams and Costco return policy which actually led to the use of that policy as a "free upgrade path" which led to the destruction of that policy to the current 90 day limit, which is still awesome. It saved me when Vizio failed to roll out the 1.09 update for the WiFi remote. I was able to work out an extension with my local Costco manager (that he worked out with Vizio) that if I didn't have my update by a certain date, he would exchange my TV beyond the 90 day limit. I did that through rational discussion with the manager and the fact I'm a pretty darn good spender there. It boiled down to I could retunr the set now (within the 90 day limit) or I would be willing to work with Vizio up to a certain point given I could still make the exchange (not return). This gave him incentive to work with his management at Costco corporate and eventually Vizio.
rakstr is offline
Reply LCD Flat Panel Displays
sony dhg-hdd250 , Vizio 32 Inch Smart Led Hdtv , Vizio 55 Inch Class Theater 3d Edge Lit Razor Led Lcd Hdtv M3d550sl , vizio m401i-a3 40" hdtv , Vizio M471i A2 47 Inch Smart Led Hdtv , Vizio M551d A2r 55 Inch 3d Smart Led Hdtv , Vizio M601d A3r 60 Inch 3d Smart Led Hdtv , Vizio M651d A2r 65 Inch 3d Smart Led Hdtv , Vizio M701d A3r 70 Inch 3d Smart Led Hdtv , Vizio M801d A3 80 Inch 3d Led Hdtv
