Official Vizio M-Series Razor Mxx1i thread - Page 347 - AVS | Home Theater Discussions And Reviews
post #10381 of 10405 Unread 04-15-2015, 08:45 AM
HaydAddict's Avatar
Liked: 0
Originally Posted by rakstr View Post
1.34 is the "previous" version.
The current update going out for this set is shown in the attachment
Correction went from 1.34 to 1.60.10-018.0080.
HaydAddict is offline
post #10382 of 10405 Unread 04-15-2015, 08:46 AM
brett_day's Avatar
I was rummaging through my filing cabinet and found the receipt for my M601d and low and behold I had purchased the 2 year extended warranty. I was trying to be patient with Vizio but this TV is driving me crazy now with the 1.60 firmware. The Best Buy tech should be out here to look at it today. I will let you know what they do.
brett_day is offline
post #10383 of 10405 Unread 04-15-2015, 02:19 PM
brett_day's Avatar
Not surprisingly the best buy tech told me this is the 4th or 5th vizio he has had to deal with thanks to the 1.60 firmware. Seems that standard procedure is swapping out the Mobo. He has to order the part and will be back at a later date to install it....here's hoping it has v1.34 firmware on it.
post #10384 of 10405 Unread 04-16-2015, 12:58 AM
CleCakYngMfd's Avatar
Quoted: 130 Post(s)
Liked: 35
I've been doing a 'Service Check' and turning off the M401i-A3 for over a week now. No '1.60xx' yet.
- Pj
Vizio P-Series - 2014 P502ui-B1E (50") TV, Firmware: 1.1.19. Win7 Pro and FireFox 37.0.1, Desktop.
Other Equipment: ClearStream-4 connected to dying DTX9950 to Composite-In of Philips 3576H; local CableTV to RF-In - connected to 2nd-time boards-replaced Philips 19PFL3403D (See www.BadCaps.Net - Poorly made caps).
CleCakYngMfd is online now
post #10385 of 10405 Unread 04-16-2015, 03:18 AM
jeremygary's Avatar
Quoted: 32 Post(s)
Nada on M601i-B3 either
Sent from my GT-N8013 using Tapatalk
jeremygary is offline
post #10386 of 10405 Unread 04-16-2015, 07:29 AM
rakstr's Avatar
Quoted: 66 Post(s)
Liked: 41
IMO, you are wasting your time on the Service Check stuff. Vizio controls the roll out and they have to have your "ID" in their system. Many techs I've spoken with have confirmed that. There may have been a point in time (scroll back maybe a year) where there was an apparent way with the Service Check to "get in line" but I don't know that was ever confirmed. It does seem that a set NIB always gets the update to the current MASS distribution but that MASS distribution is not always the "update distribution".
I think we're at their mercy.
As I've indicated, I've got 4 2013 M-Series. I'm happy to leave my 65" on 1.34, I've received the "1.60 update" for the 40" but it really wasn't exhibiting any REAL issues and it's in a guest bedroom.
I'd REALLY like the update to both my 47" and my 70". The 47" is really frustrating in that it can take up to 10 minutes after turning it on until it will respond to the remote. I've removed as much of the bloatware apps as they will allow from the "smart menu" but it can really be frustrating.
On the 70", I've got all the picture problems, ....
I really hope Vizio does something soon. For about 1/2 the life of these TVs, there have been issues, beginning with not having firmware for the WiFi remote. I don't mind being patient if I know I'm getting service performed but I'm losing faith here. I hate to have them come replace boards but I'm starting to get close enough to the 2-yr Costco warranty expiring that I may have to begin that process in case it takes 2-3 iterations to get it right.
This really seems like Vizio has made this more complicated than it should be, especially by not being very open on the problem/resolution.
rakstr is online now
post #10387 of 10405 Unread 04-16-2015, 04:35 PM
Quoted: 130 Post(s)
Liked: 35
I know. I keep doing it anyway... Like I'm sending a S.O.S. "If you send it, 'it' will come..." Quote from, "Field of Firmware."
Yeah, that happened with my P50. It only had the previous firmware less than 24 hours - the new one came the next day.
(1.1.19 for the P-Series.)
With my 1.34, the Color Temps are messed-up. 'Computer' is all GREEN and 'Normal' is Sepia. I eye-adjusted the 11-Point WB with 'Cool' Temp and it turned out real good.
Maybe it's time for me to contact Vizio and see if I can get 1.60xx sent to my M40 (assuming this corrects the Color Temp issue, yes?).
- Pj
post #10388 of 10405 Unread 04-16-2015, 06:12 PM
PlayNice's Avatar
Quoted: 153 Post(s)
Liked: 159
Do you have a meter or are you going off of your eyes? I have calibrated almost 10 Vizio's and the Computer color temperature on all of them was cool (having a bluish hue in the whites) while the Normal was indeed normal having a white at or close to 6500 K (D65). I have noticed that many people seem to think that a proper color temperature is a little bit orange but that's due to the over used of cooler color temperatures that sets come with by default.
PlayNice is online now
post #10389 of 10405 Unread 04-17-2015, 06:27 AM
Quoted: 130 Post(s)
Liked: 35
Eyes is all I got - at least for now. Maybe equipment someday.
I'm not a fan of Bluish White. I like it Normal or at times for B&W, Sepia.
Comparing the Color Temps of my P50 and and my former M40, there's a HUGE difference by eye, that's how much it is 'mis-tuned'.
This M40's 'Normal' Temp is way too 'Brownish/Sepia' compared to this P50. It's so far off, I had to use the 'Cool' Temp on the M40 to balance the 11-Step Bar Pattern. (Started off first, with a Factory Reset. 'Norm-Sepia' didn't go away.)
The 'Computer' Temp on the M40 is GREEN - as if the other two colors are gone. These Color Temps were not that off when I first got this TV.
I suspect when I had 'fooled' around with the Color Tuner for a Sepia Mode way back, the 1.34xx update that followed appears to not have 'erased' my Sepia setup. It's like it got 'stuck' in there - even though the Color Tuner numbers were all back at their default zeros, and it has been like that since.
- Pj
post #10390 of 10405 Unread 04-17-2015, 11:25 AM
PlayNice's Avatar
Quoted: 153 Post(s)
Liked: 159
You should look into professional calibrator sin your area. Doing it by eye is impossible. It will make a huge difference if you are particular about your PQ if you're in the Seattle area I know a guy ;-)
post #10391 of 10405 Unread 04-18-2015, 01:43 AM
Quoted: 130 Post(s)
Liked: 35
You should look into a professional calibrator in your area.
Sure. Send me a check, cash, or M.O. and I'll get this TV pro-metered right away.
I did my P50 by eye and the color is MUCH better than it was out of the box. It CAN be done by eye IF there is otherwise not going to be any Pro Calibrator or consumer-metering done.
Of coarse, if trying to technically set the values spot-on by eye, then yes - 'It's impossible'.
So, it can be, and has been useful to do an eye-adjustment if no other method will be utilized.
So, is PlayNice gonna PayNice(ly) to me? Should I PM my address? I like to have the M40 and P50
Pro-Calibrated, please.
"I know just enough to be dangerous."
- CleCakYngMfd
(Pssst... I'm in Ohio)
- Pj
post #10392 of 10405 Unread 04-18-2015, 11:05 AM
PlayNice's Avatar
Quoted: 153 Post(s)
Liked: 159
- CleCakYngMfd
Hahaha!
post #10393 of 10405 Unread 04-18-2015, 03:46 PM
Quoted: 130 Post(s)
Liked: 35
M401i-A3 Update:
I did something to the M40 I don't remember doing - even though I've posted it before:
I 'Power-Cycled' my M40 and what do ya know... The Color Tuner Problem is all but gone now!
There's only one Color Temperature that looks too purplish, but the others now look ok!
These goofy Color Temps were 'held captive' all this time until today's Power-Cycle:
Code:
Power-Cycling a Vizio TV:
Why?  It may help clear-out some bug-a-boos issues.
 [1] Turn off TV either by Remote or Power Button.
     (With the Power Button on back of the TV, press and
      hold until TV turns-off - about 1 second.)
 [2] Remove AC from TV by unplugging the AC Power Cord.
 [3] Using the TV's Power Button (on back of TV), press and
     hold for at least 15 seconds.
     This should drain any residual power within the TV.
 [4] Plug back in the AC Cord.
So, this week I start over and will WoW-Calibrate the M40.
- Pj
post #10394 of 10405 Unread 04-20-2015, 07:50 AM
letterist's Avatar
Quoted: 14 Post(s)
As a owner of this tv I have to say it kicks ass. I know there are some issues going on with the firmware but i just wanted to chime in about something unrelated. I have had my tv mounted on my wall since purchasing it day one. The 3D was always good but did not seem to have that pop out look as much as I wanted. We have since moved and I put the vizio 70" on a tv stand. The 3D is about 100 times better. It's almost like a new tv. I wish I would have done it sooner.
lotohnz likes this.
letterist is offline
post #10395 of 10405 Unread 04-20-2015, 11:14 AM
laserjock II's Avatar
Quoted: 224 Post(s)
Liked: 97
Yeah, I believe the middle of the screen is supposed to be at your eye level for optimum performance with a passive 3D set.
I need to watch a 3D movie again.
lotohnz and letterist like this.
laserjock II is online now
post #10396 of 10405 Unread 04-21-2015, 10:28 PM
lotohnz's Avatar
Quoted: 39 Post(s)
Liked: 50
Lol!... makes me want to watch a 3D movie tonight too.
mhobart and letterist like this.
lotohnz is offline
post #10397 of 10405 Unread 04-25-2015, 11:04 AM
Urlacher5454's Avatar
I just got updated to v1.60.10-020.0643_125, what does this supposedly fix?
Urlacher5454 is offline
post #10398 of 10405 Unread 04-25-2015, 11:11 AM
Quoted: 224 Post(s)
Liked: 97
What Model do you have?
Supposed to fix "Smart dimming" I think
post #10399 of 10405 Unread 04-25-2015, 11:35 AM
M551d.
post #10400 of 10405 Unread 04-28-2015, 11:05 AM
lotohnz's Avatar
Quoted: 39 Post(s)
Liked: 50
My M551d-A2 updated to v1.60.10-020.0643_125 last night too. Haven't checked calibration yet, but the backlight seems more responsive, and Birdman looked awesome last night.
lotohnz is offline
post #10401 of 10405 Unread 04-29-2015, 06:28 PM
Liked: 2
Finally got the update just now for my M501d-A2R version 1.60.10-020.0643_125. Smart dim issue toggle on/off seems to be fixed.
atticuscc04 is offline
post #10402 of 10405 Unread 05-01-2015, 12:41 PM
PlayNice's Avatar
Quoted: 153 Post(s)
Liked: 159
Hello all, I just recently received a new firmware for the M80d1-A3 that fixes the smart dimming issues 1.60.10-019.0090.
josephpearson likes this.
post #10403 of 10405 Unread Yesterday, 01:23 PM
jayissuperman's Avatar
Finally! My 60 seems fine now too
jayissuperman is offline
post #10404 of 10405 Unread Today, 01:24 PM
When was your last calibration? I'm trying to keep up with you as my inputs are labeled lotohnz. Haha.
post #10405 of 10405 Unread Today, 07:08 PM
BLeClair12's Avatar
Quoted: 17 Post(s)
I had posted about this issue a little while back, and unfortunately, it's still popping up. Wondering if anyone has any specific recommendations.
My M60 3D performance is quite troublesome. I get a lot of blurring in scenes that feature a lot of depth. The other night, a friend and I sat down to watch The Avengers 3D to gear up for Age of Ultron. She asked me to shut it off and switch it for the 2D version within about 25 minutes. The text on the few subtitles in the film were virtually illegible, causing immediate eyestrain. Foreground characters and set-pieces blur tremendously. Chapter 4 of the Blu-Ray is where the bulk of issues started popping up. It was bad.
I've mentioned it before and a member suggested making sure I wasn't using smart dimming when watching 3D films. I was sure to disable that, as well as 24hz playback within my PS3 settings.
For reference, the equipment involved:
Vizio M601d-A3
Denon X2000
PS3
BLeClair12 is online now
Reply LCD Flat Panel Displays
sony dhg-hdd250 , Vizio 32 Inch Smart Led Hdtv , Vizio 55 Inch Class Theater 3d Edge Lit Razor Led Lcd Hdtv M3d550sl , vizio m401i-a3 40" hdtv , Vizio M471i A2 47 Inch Smart Led Hdtv , Vizio M551d A2r 55 Inch 3d Smart Led Hdtv , Vizio M601d A3r 60 Inch 3d Smart Led Hdtv , Vizio M651d A2r 65 Inch 3d Smart Led Hdtv , Vizio M701d A3r 70 Inch 3d Smart Led Hdtv , Vizio M801d A3 80 Inch 3d Led Hdtv
