LCD Flat Screen Storage Temperature - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-19-2013, 09:10 AM - Thread Starter
Bapon's Avatar
I'd like to get a new flat screen for my vacation home. During the winter months, I'm there infrequently and the heat is off. Can an LCD withstand below zero temperatures? Will it have to come to room temperature before operating? Is a plasma a better choice? Thanks
Bapon is offline
post #2 of 4 Old 01-19-2013, 03:37 PM
sitlet's Avatar
Depends on how well it was made. We have LCD's in our production trucks that sit outside in the cold for weeks at a time. Granted, they are professional grade monitors, but still very similar components inside to a normal set.
Absolutely. Let the ambient temp warm up, then wait at LEAST a few hours.
sitlet is offline
post #3 of 4 Old 01-19-2013, 05:08 PM
myoda's Avatar
Liked: 57
This set is rated to operate between -40 F to 122 F.
http://store.sunbritetv.com/p-147-model-5510hd.aspx
Always a good idea to things wam up before operating.
myoda is offline
post #4 of 4 Old 01-19-2013, 05:22 PM
Bond 007's Avatar
Quoted: 2376 Post(s)
Liked: 1914
Your biggest enemy will not be temp. It will be moisture. That is why you must make sure that the room and tv reach a proper temp before operating it. To avoid condensation.
Licence to Kill
Bond 007 is offline
Reply LCD Flat Panel Displays
