Samsung LCD color problem - AVS Forum | Home Theater Discussions And Reviews
Old 01-19-2013, 02:47 PM - Thread Starter
ezfeakes's Avatar
I have this Samsung model ln32a300j1dxza , the color has gone weird, it almost looks like a cartoon I've tried the reset and tried a different main board, nothing helped, could this be the panel going bad? The menu looks normal.
Thanks for any help.
ezfeakes is offline
Old 02-15-2013, 05:54 AM
orion_134's Avatar
I have the same problem, did you figure it out?
orion_134 is offline
Old 02-15-2013, 06:13 AM - Thread Starter
ezfeakes's Avatar
Yes, it was the T-Con board, if you are good at soldering it is the AS15-G chip $3.21 on eBay. Good luck
ezfeakes is offline
Old 02-15-2013, 06:31 AM
orion_134's Avatar
What kind of diagnostics did you do to be sure? I'm fairly competent with electrical stuff and a volt/ohm meter.
Old 02-15-2013, 07:04 AM - Thread Starter
ezfeakes's Avatar
If it is the same problem just buy the chip or the board, it will fix it. The chip is small and has about 40 legs so if your not good at soldering just buy the board, I found it for $30 the site was called interliquids I think.
ezfeakes is offline
Old 02-15-2013, 08:18 AM
thiao's Avatar
Quoted: 17 Post(s)
Removing and replacing these types of surface mount devices requires specialized equipment and soldering techniques.
Just buy a replacement TCON board from one of the usual sources (e.g. retechtv.com shopjimmy,com etc.).
thiao is offline
Old 02-15-2013, 09:06 AM
SAM64's Avatar
Liked: 78
SAM64 is offline
Old 02-15-2013, 12:16 PM
orion_134's Avatar
I know someone who can SMT solder and I plan to learn from him before I try it myself. But seriously, I want to do some diagnostics before I throw parts at it.
