Picture split in half with right and left halves reversed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-19-2013, 03:06 PM - Thread Starter
cb9501's Avatar
have a customer that purchased a samsung display and blu-ray online, and hired me to do some wire management and programming. I'm assuming there's a mismatch in the picture settings between the blu-ray and the display. This problem only happens when blu-ray is selected (hd cable stb) works fine. It almost looks like 3d on the smart hub screen except the fact that the left and the right half of the screen is reversed. Look familiar to anyone?
cb9501 is offline
post #2 of 4 Old 01-20-2013, 08:00 AM
mikepier's Avatar
Quoted: 16 Post(s)
Is the Samsung just a display and not a TV?
Does it play DVD's normal?
Check the resolution settings on the BD player or display. Try changing to maybe 1080i and 720P and see if it changes anything.
mikepier is offline
post #3 of 4 Old 01-20-2013, 10:26 AM
Super Moderator
DrDon's Avatar
Quoted: 871 Post(s)
Liked: 1730
Please read the stickies before posting. Thread moved: http://www.avsforum.com/t/1437752/note-questions-about-specific-television-sets-belong-in-the-proper-display-areas-not-here#post_22561613
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #4 of 4 Old 01-21-2013, 07:22 AM - Thread Starter
cb9501's Avatar
Thanks for the reply. DVDs reportedly have the same problem, but not cable. It's a brand new set that is definately capable of 1080p, but I did notice that it initially had deep color turned on in the blu-ray player's setup, and there was some sparkle on the blacks, so I turned it off. I hoped it would be obvious to someone. Anyone?
cb9501 is offline
Reply LCD Flat Panel Displays
