Component Video Through 55HX929. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-20-2013, 09:31 AM - Thread Starter
gbaby's Avatar
Quoted: 623 Post(s)
Liked: 246
I connected a DVD through the component input of my HX929, but the colors are way off. Faces are blu and I've tried everthing but nothing seems to work. Has anyone else had a problem with the colors through HDMI?eek.gif
gbaby is offline
post #2 of 4 Old 01-20-2013, 04:34 PM
walford's Avatar
Are you sure you are using component video cables (red, green and Blue) and not a composite video cable (yellow)? for both separate red and white connector cables are used for audio.
walford is offline
post #3 of 4 Old 01-21-2013, 12:59 PM
sitlet's Avatar
Yea, sounds like one of your three component video cables is bad or disconnected. Check the connections again, and maybe try another component cable.
sitlet is offline
post #4 of 4 Old 01-21-2013, 01:53 PM
Ratman's Avatar
Quoted: 1434 Post(s)
Liked: 1146
Originally Posted by gbaby View Post
If using component cables, do as suggested above in post #3.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply LCD Flat Panel Displays
