Calibration setting - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2013, 02:16 PM - Thread Starter
m2845's Avatar
Sorry if this question has already been posted but was looking for some calibrations settings to try out on this tv.
I just purchased this tv today without really researching it but the price I paid was just to good to pass up.
Thanks in advanced for the replies!!
m2845 is offline
Old 01-20-2013, 02:28 PM
Otto Pylot's Avatar
Quoted: 1402 Post(s)
Liked: 877
Calibration settings will vary from tv to tv because of component tolerances even within the same model and build line. Calibration also takes into consideration the viewing environment. Using someone else's settings may help you get a better picture but to get the best your tv can do you'd be better off to create your own settings either using a calibration disk such as the free AVS HD709 disk or a commercial disk like WoW, Spears and Munsil, DVE, etc. Keep in mind that using a disk alone won't "calibrate" your tv but will make accurate picture adjustments based on the rec.709 standards which may be all you need.
Otto Pylot is offline
Old 01-20-2013, 02:31 PM
Maverickaim9's Avatar
Ummm, yeah, your supposed to include your TV model if you want an answer. Still, it's better if you type in your model on the search box and post that question on your model's official thread. Anyways, good luck.
Maverickaim9 is offline
