Can I send the audio from the smart apps like Netflix OUT to a receiver from a Panasonic ET5? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-22-2013, 11:13 AM - Thread Starter
LordJezo's Avatar
Is this possible? I know there are a lot of inputs on the set to pipe in sound and video but how about sending audio back out? Using the Netflix and Amazon apps are very convenient, if I get a proper receiver and speakers will I be able to pipe that audio out of the TV or will I be forced to use the set's built in speakers?
LordJezo is offline
post #2 of 5 Old 01-22-2013, 12:37 PM
iatacs19's Avatar
Quoted: 230 Post(s)
Liked: 146
If you have a TV and receiver with the ARC feature then you may be able do what you are asking. The caveat is that not all TVs will send multi-channel audio through ARC, but they will at least send 2.0 sound.
http://www.hdmi.org/manufacturer/hdmi_1_4/arc.aspx
XBR65X930C, AVR-X4200W, NVIDIA ShieldTV, SVS SB12-NSD, RF-42 II, RC-52 II, RB-41 II
iatacs19 is offline
post #3 of 5 Old 01-24-2013, 06:04 PM - Thread Starter
LordJezo's Avatar
How do I know if my TV can do such a thing?
LordJezo is offline
post #4 of 5 Old 02-06-2013, 07:14 AM - Thread Starter
LordJezo's Avatar
Anyone?
LordJezo is offline
post #5 of 5 Old 02-06-2013, 08:17 AM
adupree's Avatar
As far as I've seen all TV's send multichannel audio out the ARC, but I know for a fact the Panasonics do.
Ignorance is a choice
adupree is offline
Reply LCD Flat Panel Displays
Panasonic Viera Tc L55et5 55 Inch 1080p 3d Full Hd Ips Led Lcd Tv With 4 Pairs Of Polarized 3d Glass , Receivers Amplifiers , Led Hdtv
