Sony KDL-60NX720 HDMI display problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2013, 04:55 PM - Thread Starter
doug33's Avatar
I have a Sony 60NX720 on a wall with an hdmi cable running under the house to a Pioneer SC 65 receiver which has been working fine generally. On occasion I needed to pull the receiver out which caused the hdmi cable to come loose such that gray static would display on the screen until it was reseated properly. However as of yesterday I am getting a message on the TV screen, "No signal. Check the external input or select another input". The TV is set to hdmi 1. I thought maybe the receiver hdmi out connector had gone bad but when I connected the hdmi cable directly to a blu ray player, I get the same message. I checked that the hdmi cable is properly seated in the hdmi 1 port on the TV. I do not have another screen with hdmi to test out.
Does anyone have any idea what the problem could be? The only things I could think of are:
1. The TV hdmi port is broken
2. The hdmi cable was chewed by rats. I did have rat problems under the house about 1 year ago but nothing since then.
Any ideas? Thanks.
doug33 is offline
post #2 of 2 Old 01-23-2013, 10:18 PM - Thread Starter
doug33's Avatar
So today I bought a small tv just to test the hdmi cable and sure enough, I have confirmed the hdmi cable doesn't work going from the closet to the room next door, I think 35 feet. I definitely removed the cable from the receiver numerous times but how can that damage the cable? I can see how it might damage the receiver but not the cable. Nothing looks bent. Is there anything I can do to fix the end of the cable to get it working? If not I'm ordering a blue jeans hdmi cable to replace.
doug33 is offline
Reply LCD Flat Panel Displays
Led Hdtv
