vizio m3d550kd soap opera effect, please help me get rid of - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-22-2013, 07:26 PM - Thread Starter
trowe's Avatar
Hi all,
I have looked through the forums and tried several settings but can,t seem to find what I need to do get rid of this, I understand that many people like the affect it its not for me
(Especially the wife). Every thing was fine up until I received a firmware set up to version 3.12.1. It was nice that all of my settings were removed with the update, but I am not going there. Looking at the help resolution is set to 1920 x 1080 vertical frequency is 60.
Any help from anyone would be greatly appreciated.
trowe is offline
post #2 of 7 Old 01-25-2013, 05:40 PM - Thread Starter
trowe's Avatar
So I guess everyone either loves this effect or has not
Found fix?
trowe is offline
post #3 of 7 Old 01-26-2013, 10:23 AM
DPSAJ's Avatar
I have the same problem. It just happened this week and I also noticed the version is now 3:12:1. We also lost all of the inputs after the upgrade and had to re-input. Still looking for a solution. Picture was fantastic before.
DPSAJ is offline
post #4 of 7 Old 01-26-2013, 11:13 AM - Thread Starter
trowe's Avatar
That was exactly the same thing that happened to me. All settings were lost when the "upgrade" was delivered. Would be real nice if the changes were published somewhere, but if I can just get the picture reset that would be great.
trowe is offline
post #5 of 7 Old 02-03-2013, 06:50 PM - Thread Starter
trowe's Avatar
So i guess no help out here?
trowe is offline
post #6 of 7 Old 02-04-2013, 03:12 PM
DPSAJ's Avatar
Have you tried clearing the memory/returning back to factory settings from the help menu? I was going to give it a try but after a week it doesn't seem as noticeable.
DPSAJ is offline
post #7 of 7 Old 02-05-2013, 12:37 PM
n2ition's Avatar
Hubby and I hated this as well...turns out it is an easy fix!
Go to TV settings and select Picture. Scroll down to More and then select Advanced Picture
Set Real Cinema Mode to Off.
You should be good to go!
Enjoy. :-)
mikecu likes this.
n2ition is offline
Reply LCD Flat Panel Displays
Vizio M3d550kd 55 Inch 240 Hz Class Theater 3d Edge Lit Razor Led Lcd Hdtv , Led Hdtv
