Is there a decent 65 / 70" LED TV out there? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-23-2013, 09:19 AM - Thread Starter
kerednai's Avatar
I'm in the market for a 65 or 70" TV. The room has a number of windows so light may be an issue.
Looking at the various reviews I cannot find a single TV that I am wowed by at this size.. Can someone please point me in the right direction.
kerednai is offline
post #2 of 12 Old 01-23-2013, 09:41 AM - Thread Starter
kerednai's Avatar
Sorry that was a rather frustrated post lol
I should add some more information.. I am looking for a TV which will become our regular viewing TV in our basement. It needs to handle things like the news, Greys Anatomy as well as Soccer and movies., So really a good all rounder. Sound isn't an issue as I will be using an external amp. I am not bothered by 3D although if its there I'm sure we will use it.
The Sharp Elite's are obviously good but way over my price range.. I cannot justify $6K on a TV.
I came across this Sony which looks good according to CNet - Sony XBR-HX950
What other TVs would you suggest? I would like to keep the price below $2500 if possible..
kerednai is offline
post #3 of 12 Old 01-23-2013, 09:53 AM - Thread Starter
kerednai's Avatar
Crap I just realized I was looking at the price of the 55" version :-(
Back to the drawing board.. Please help..
kerednai is offline
post #4 of 12 Old 01-23-2013, 10:22 AM
adupree's Avatar
Is there a reason you aren't considering plasma?
Ignorance is a choice
adupree is offline
post #5 of 12 Old 01-23-2013, 11:44 AM - Thread Starter
kerednai's Avatar
The other half is very anti-plasma as we have a bright room. We also have kids so worried about them leaving it on and getting screen burn plus they cost more to run.
kerednai is offline
post #6 of 12 Old 01-23-2013, 11:47 AM
greeno's Avatar
Liked: 25
Don't worry so much about bright rooms and plasmas. I have a panny 50st30 (2 year old model comparable to the 50st50 this year) in our bedroom that gets LOTS of pm light. no worries watching it. It has a very nice AR coating. I think you mean image retention (IR) not burn in. I notice it from the comcast DVR menu, but it goes away when switching to real content. It's also shouldn't be a a concern for you.
What you do have to choose is the size. plasma only goes to 65''. if you need/want 70'' (or bigger), then you have to go LED backlit LCD.
Best,
jeff
greeno is offline
post #7 of 12 Old 01-23-2013, 12:50 PM - Thread Starter
kerednai's Avatar
Best,
jeff
I did mean burn in...
Although it is no longer the problem it once was, there is still a chance that your plasma TV will be hit with what is referred to as "burn in." If you keep a stagnant image is on the screen for too long (if you pause a DVD, leave the TV on and don't return for hours), the screen may retain that image.
(From http://www.foxbusiness.com/personal-finance/2012/06/26/decision-points-plasma-tvs-versus-led-tvs/#ixzz2IpVOs8ni)
In terms of size..
I can fit up to a 75" screen in the space I have on the wall..
The only 75" screen on the market is a Samsung at $10K so that is out of the picture (no pun intended).
Then at 70" the only screen is the Sharp.. So really I am happy to go with either a 65 or 70" TV.
The question is which LED is going to serve me well at either of these 2 sizes..
kerednai is offline
post #8 of 12 Old 01-23-2013, 01:49 PM
GaryWA's Avatar
Quoted: 16 Post(s)
I have the Sharp 60C8470U, the 70" is essentially the same. I would highly recommend this TV.
GaryWA is offline
post #9 of 12 Old 01-23-2013, 02:11 PM
mo949's Avatar
Liked: 1113
the only reason not to get a plasma in this scenario is if you think you'll have issues with kids throwing things at the screen in which case you can justify spending that 6k due to getting something with gorrilla glass. At less than half the price of the sony, if you ever did manage to get burn in (which is extremely hard to do and would need some serious abuse to achieve) you could buy another one at that price and still console yourself knowing you have better PQ in both cases.
mo949 is offline
post #10 of 12 Old 01-23-2013, 03:36 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
Having read everything above...
Plasma doesn't cost that much more (these days) to operate year to year. Especially, not so much more to justify the price tag of large LCDs with good image quality. Cost to performance ratio is pretty high on a model like the 65ST50.
Plasmas can have an anti-glare film which solves your windows concern.
I am a video gamer, and (big surprise coming next...) a little more satisfied by plasma PQ/refresh. Set the TV for game mode on gaming input and ask your kids to turn the TV off when not using it.
If your kids throw a controller and hit the TV, nothing saves you. Gorilla glass Sony's will still crack the panel and I've seen it happen once. Gorilla glass may not scratch or break easily, but it also gives to pressure. You can push with your finger hard enough to move the LCD surface. Another note to the above, the Sharp Elite has a little glare. Ive noticed all TVs of decent PQ have a glossy finish.
I would suggest a 65ST50 or a 70" Sharp LE845. Sharp is very well priced for what they offer and the 70" TV is not that bad. If the decision on a TV isn't meaningful enough for you to try to convince the other half to accept a plasma get the Sharp.
AVR: Marantz 7008 Phono: Pro-Ject Debut III Speakers: BW CMC2 + 2xCM9 (front) + 2xCM5 (rear)
TV: Panasonic 65ZT60, Samsung 60F5300
skidawgz is offline
post #11 of 12 Old 01-23-2013, 03:49 PM
rickie's Avatar
You could consider the Vizio M3D651SV. It has a glossy screen though, which might give you concern depending on where the windows are. Mine looks good even with lots of light. BUT if you have a light source at the right angle you can get refections. If you decide to try it, you might want to get from a local source you can return to.
Rick
rickie is offline
post #12 of 12 Old 01-23-2013, 03:59 PM
dmaul1114's Avatar
There are trade offs to both LCD/LED sets and plasmas.
I like the picture better on plasmas, but have had bad luck with buzzing (or am just very sensitive to it). Tried a Vizio plasma several years back that buzzed loudly and got IR easily. Tech couldn't quiet the buzzing so I ended up getting a Sony LCD RPTV.
I just decided to upgrade and decided to give the Panny 55UT50 plasma a try. Loved the picture. Got some IR from CNN/ESPN and video games a few times, but it went away pretty quickly. But it still had a loud buzz I could hear over the sound at normal volumes on bright scenes--and especially loud if I displayed a white slide with no sound (could hear it 15 or so feet away). Again the tech wasn't able to fix it--just replaced the screws and said the buzzing was at normal levels and he could barely hear it. My girlfriend commented on how loud the white screen was during break in--so it wasn't just me. Though she didn't notice it when watching things with volume on.
Anyway, gave up again and I'm sending it back to Amazon and trying the 55" Panny LED (ET5 series). I know I probably won't like the PQ as much--especially for movies with dark scenes. But I"m not that much of a videophile and will almost definitely be happier making that trade off for know buzzing and being totally worry free about IR. The UT50 also has a glossy screen and no filter, so reflections are a big issue. I can control lighting, but it gets old having my blinds down and missing out on my 21st story view all day if I want to watch TV!
Point of this rambling is there's no right or wrong answer as to what's best as it just comes down to how you use the TV and what your personal pet peeves about displays are. Videophiles will probably mostly go toward plasma due to the blacks and color accuracy. Non videophiles will be more split over whether buzzing is noticeable/bothersome, whether they display static images for hours (long gaming sessions of the same game, hours and hours of ESPN/CNN) etc.
dmaul1114 is offline
Reply LCD Flat Panel Displays
Sony Xbr 65hx950 65 Inch Bravia Led Hdtv , Sony , Plasma Hdtv , Panasonic Viera Tc P50st30 50 Inch 1080p 3d Plasma Hdtv
