is there a 37" LCD that will fit in a 35" width? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-23-2013, 04:24 PM - Thread Starter
changejobs's Avatar
I have been trying to find a 37"lcd that will fit within a space that is only 35" wide? Does anyone know of one that might fit?
changejobs is offline
post #2 of 5 Old 01-23-2013, 06:07 PM
Iwanthd's Avatar
Quoted: 27 Post(s)
Iwanthd is online now
post #3 of 5 Old 01-27-2013, 12:08 PM - Thread Starter
changejobs's Avatar
post #4 of 5 Old 01-27-2013, 04:17 PM
walford's Avatar
Just about any 37" wide screen should be less then 35" wide check the 37" model specs at the different vendors web sites. A better idea may be to go to a local BB, Costco, or Wal-Mart and measure the different 37" models. Then you can check the to see if they have side air vents which mean that you would have about 3/4" on each side for ventilation.
walford is offline
post #5 of 5 Old 01-28-2013, 02:33 PM - Thread Starter
changejobs's Avatar
Thank you.
Reply LCD Flat Panel Displays
Lcd Hdtv
