OFFICIAL Samsung Smart TV Firmware Updates - Latest Info & How-to's - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 05-28-2013, 10:18 AM - Thread Starter
EndeaverouX's Avatar
Liked: 27
Originally Posted by aristokratika View Post
hi, new owner here. i've got 65" es8000 floor model from bb for a 2 k steal. i'did not have much time to experiment but i see little clouding spots when screen is black. should i install 051 firmware to address picture quality? thanks
clouding on these tv's are normal (it shouldn't be) . There are techniques like "massaging the screen" that can take away some of the cloudy spots. And NO...no firmware update will improve picture quality of any screen, it is what it is from the factory....firmware updates will take care primarily of software issues/bugs...
EndeaverouX is offline
post #32 of 37 Old 06-13-2013, 10:57 AM
majnu's Avatar
I have a samsung ue60f6100. The firmware for the TV is:
T-NVTF6DEUC-1019.0
Can I use the firmware from a higher range "F" model TV to access smart features like dlna, apps, netflix etc?
Sorry on my ignorance on the matter or if it is a dumb question.
majnu is offline
post #33 of 37 Old 06-13-2013, 11:07 AM
Superturtle's Avatar
unable to answer the question above as don't have that model, but lol to transcript, I liked;
Sinclair: Support Angry Birds app. biggrin.gif
So long as it does that i don't know what your worried about.
You did give the tech guy a bit of a drilling, considering a lot of these peeps are just on min wage and only have the answers they are provided with. But it can be frustrating at the same time.
Superturtle is offline
post #34 of 37 Old 07-14-2013, 08:33 AM
Samsung UN46ES8000F TV, Samsung WMN350M mini wall mount, Samsung VG-KBD1500 bluetooth keyboard, Samsung HT-E6730W home theater
Highland Logan is offline
post #35 of 37 Old 07-14-2013, 12:29 PM
Jsolo's Avatar
A number of these firmware updates state "improved picture quality". They don't actually expand on that. What about the picture quality has been improved???? As with most firmwares/updates, don't fix unless broken...
Jsolo is offline
post #36 of 37 Old 07-25-2013, 08:55 AM
zyexx's Avatar
I have a UN40ES7500F, however it has started the whole turn off and on thing, any idea where I can get the latest firmware for this? Or even an older firmware to go back to?
zyexx is offline
post #37 of 37 Old 07-25-2013, 09:41 AM
Reply LCD Flat Panel Displays
Samsung 46 Led Smart Tv , Samsung Un46es7500 46 Inch 1080p 240 Hz 3d Slim Led Hdtv , Samsung Un60es7500 60 Inch 3d Slim Led Hdtv , Samsung Un55es7500 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Samsung Un65es8000 Led Hdtv , Samsung Un46es8000 Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Samsung Un60es8000 60 Inch 1080p 240 Hz 3d Slim Led Hdtv , Samsung
