Vizio TV IR sensor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-28-2013, 12:52 PM - Thread Starter
wilhelm1202's Avatar
Hello, I have a Vizio VL470M television that is out of warranty and I've been having some issues with what I thought was the IR sensor, but now I'm not sure. I noticed that when I was using the Vizio remote it would control the TV for about 30 seconds just after the initial start up and then I would have no control from the TV remote at all. I verified that the remote is sending a signal by looking at the front through a digital camera, which showed a blinking light when buttons were pressed. I then removed the back from the TV and cleaned the IR sensor and also the protective covering on the front of the TV, this did not help. I purchased a replacement IR sensor online and installed that and now am still having the same issue. I've tried to program the cable remote to control the TV (which I assume would be similar to using a universal remote) but it will not program to the tv, probably for the same reason the other remote wont work. Does anyone have any suggestions of other things I could try or what else it might be? Thanks for your help!
wilhelm1202 is offline
post #2 of 3 Old 01-30-2013, 09:46 AM - Thread Starter
Nothing??
post #3 of 3 Old 01-30-2013, 11:24 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Yes.
There are quite a few previous threads about remotes and interference due to backlights of the TV or CFL lighting in the home. Search around and you may get some ideas.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply LCD Flat Panel Displays
Vizio
