Replacement Advise for Samsung LN46A850 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-28-2013, 03:30 PM - Thread Starter
ndan123's Avatar
Hi,
I have a LN46A850 with the geeksquad best buy 4 year protection plan, the panel started having the vertical lines issue a week before my warranty. I was wanting the panel to be replaced, but looks like they are not going to go ahead with the repair but instead issue a replacement. Could someone please advise, in the current line up what should I try to get? Thanks a lot in advance.
Regards
- n
ndan123 is offline
post #2 of 4 Old 01-29-2013, 05:51 PM - Thread Starter
ndan123's Avatar
Update I was offered a samsung es6500 or an lm6700. After lot of back and forth got a samsung es7100 upgraded to 55 for 200 more.
ndan123 is offline
post #3 of 4 Old 01-29-2013, 07:12 PM
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
I went from a A850 to ES7100 also.
Its a good successor...
PiratesCove is offline
post #4 of 4 Old 01-29-2013, 09:19 PM - Thread Starter
ndan123's Avatar
Ah i see, cool looking forward to see how it works out, thanks
ndan123 is offline
Reply LCD Flat Panel Displays
Samsung Ln46a850 46 Inch 1080p 120hz Lcd Hdtv With Red Touch Of Color , Lcd Hdtv
