help me choose between the samsung UN55ES7150 or the LG 55lm7600 - AVS Forum | Home Theater Discussions And Reviews
Old 01-28-2013, 03:34 PM - Thread Starter
suncom3's Avatar
I see pretty good reveiws between both of these models,they seem to be pretty sim othter than the samsung being dual processor..looks like the cost id pretty sim as well,the costco model 7150 seems to be the same as the 7100 anywhere else but comes with wireless keyboard..for 1450
Ive seen the lg for 1300 or so..
I have a feeling after the superbowl prices will drop again significantly though
suncom3 is offline
Old 01-28-2013, 11:47 PM - Thread Starter
suncom3's Avatar
anyone?
suncom3 is offline
Old 02-09-2013, 02:12 PM
kevreh's Avatar
I think the biggest difference is that the LG uses an IPS panel, so you get wider viewing angles with less washout effect. Plus the 7100 is several hundred more. Cosmetically, the LG has a cleaner/more minimal frame.
kevreh is offline
Samsung Un55es7100 55 Inch 1080p 240 Hz 3d Slim Led Hdtv Black , Led Hdtv , Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv
