Major problem with the 40L5200U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-01-2013, 12:14 AM - Thread Starter
Kataklyzim's Avatar
Just got this tv 3 days ago,saw it in Best Buy and bought it. Terrible TV! The sound is horrible,the remote is...garbage,absolutely horrid and even worse there is MAJOR lag when I play Battlefield 3 on my PS3 on the tv. I even switched "game mode" on and aiming is nearly impossible,it's like being drunk and on a sheet of ice the way your characters movements are delayed or overly dramatic. Fine tune aiming is impossible! I originally hooked it up with an HDMI cable and experienced all of these problems,read about game mode and tried it,no avail,still horrible lag. Then went out and bought component cables and hooked it up,tv doesn't recognize the component hook up even though it's plugged in,showed picture in black and white at 420i,I then changed the settings on the PS3 to component.....screen goes black,no signal detected. Absolutely horrible,HORRIBLE,TERRIBLE TV! Stay away from this set if you're a gamer.
Kataklyzim is offline
post #2 of 2 Old 02-01-2013, 08:20 AM
sitlet's Avatar
Quoted: 14 Post(s)
As far as the component problem, you need to reset the ps3's video settings from hdmi to component, and the correct resolution. As far as the other problem, since you just got it, take it back and get a different model before your 30 days are up.
sitlet is offline
Reply LCD Flat Panel Displays
