Ambient light sensor that auto-adjusts picture to room lighting? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-01-2013, 08:52 AM - Thread Starter
gecoffin's Avatar
I plan to put this TV in a room that has many windows
As far as I know LG and Vizio TV's have this feature
Does any other brands have it?
Thank
Gary
gecoffin is offline
post #2 of 3 Old 02-01-2013, 10:20 AM
astrodanco's Avatar
I found this feature to be annoying as it continually and very noticeably adjusted the brightness for seemingly no apparent reason. The feature appeared to act like it had little to no built-in hysteresis. So far as I can tell, It might have even been reacting to the change in light level caused by its own brightness level changes. I turned it off.
astrodanco is offline
post #3 of 3 Old 02-01-2013, 10:41 AM
Steve S's Avatar
Liked: 46
Both LG and Samsung models have this. On most mid-high end LGs you can adjust the maximum and minimum brightness change as well as the sensitivity of the feature, I'm pretty sure Samsungs also offer this adjustability--you might try downloading Samsung owner's manuals from their website to verify.
Steve S.
Steve S is offline
Reply LCD Flat Panel Displays
