Need Firmware for Vizio VA26L or Replacement Turner Box - AVS Forum | Home Theater Discussions And Reviews
Old 02-02-2013, 02:15 PM - Thread Starter
Josh Guyette's Avatar
I've a Vizio VA26L that can't decode digital stations on cable... I just get a blue screen, but my channel scan adds the channel because there is a signal. My other Vizio E371VL has no problems decoding the stations. I've done some searching and could not find a firmware update. Does anything know if there is a bootleg firmware update or could suggest a replacement tuner box that would pick up all the analog and ALL the digital stations?
Josh Guyette is offline
Old 02-02-2013, 06:47 PM
walford's Avatar
What is the source of your Digital Signals: Antenna, cable or satellite? Are you using the ATSC or QAM tuner?
walford is offline
