SAMSUNG PN60E7000 PLASMA or UN60ES7100 LED-LCD - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: which one?
UN60ES7100 1 100.00%
PN60E7000 0 0%
Voters: 1. You may not vote on this poll
post #1 of 3 Old 02-04-2013, 11:43 AM - Thread Starter
vigilo's Avatar
Hello,
I need some opinions on which of the two models to purchase. The unit will be in my living room which has a couple large windows opposite from the TV (with shades). I will be using the TV for gaming and Cable TV with occasional netflix streamiing. Please advise which model you would pick. Thank you.
vigilo is offline
post #2 of 3 Old 02-04-2013, 11:45 AM - Thread Starter
vigilo's Avatar
My concerns are PQ, Black levels, Brightness, Input lag for gaming, glare, etc. I also love the slim bezel on the LED and the .6" difference in depth. I am torn!
vigilo is offline
post #3 of 3 Old 02-05-2013, 08:53 AM
kevreh's Avatar
Plasma will be better as long as you accept and understand IR (image retention). Every plasma is different in terms of how bad it can be. If you watch a lot of the same sports or news channel with banners/logos in the same place then you may have a problem (I did with my Panasonic plasma). If your not and PQ purist then maybe LED is better.
kevreh is offline
Reply LCD Flat Panel Displays
Samsung Pn60e7000 60 Inch 1080p 600 Hz 3d Ultra Slim Plasma Hdtv , Samsung Un60es7100 Led Hdtv
