Repair question: Samsung LCD model LN52A530P1FXZA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-04-2013, 08:13 PM - Thread Starter
DerrickFiddle's Avatar
Hello, folks. I recently purchased a Samsung 52 inch LCD tv from a friend of mine. Model LN52A530P1FXZA. It stopped working after about a week from purchase. I called Samsung and find out it qualifies for a free repair due to faulty capacitors and/or motherboard. The technician came by today and replaced the capacitors. He plugged it in directly to the wall outlet, power cycled it about 8 times with no problem. 5 hours later, I decide to mount it back up, but I wanted to make sure it was still working. I plugged it directly to the wall outlet, and it came on, but only stayed on for about 3 minutes. I unplugged and replugged it multiple times, but still to no avail. I then plugged the TV into a power strip and it powered up and has been working perfectly for the last hour. Any reason why this was the case? I find it strange that the technician who used the same wall outlet I did had no problem with it, but I was only able to get it to power up successfully using a power strip. Any info would be appreciated. Thanks.
DerrickFiddle is offline
post #2 of 3 Old 03-17-2013, 02:15 PM
DyeLooper's Avatar
Not sure why for you're lectrical dilemma. I am though looking for a base stand for this TV, got one you wanna get rid of?
DyeLooper is offline
post #3 of 3 Old 03-17-2013, 05:24 PM - Thread Starter
Nope, sorry. I bought the tv used without the original stand.
Reply LCD Flat Panel Displays
