Is this "normal" or "bad" vertical banding? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By cmay91472
  • 1 Post By PlasmaPZ80U
  • 1 Post By Phase700B
  • 1 Post By Hanna
  • 1 Post By Hanna
  • 1 Post By Hanna
  • 1 Post By WilliamG
post #1 of 30 Old 02-05-2013, 01:16 AM - Thread Starter
downtownriot's Avatar
Would you say this is "normal" or "bad" vertical banding for an LED TV? I have a Samsung UN32EH5000.
For the testing I used this grey image: http://i.imgur.com/uD2xe.jpg
downtownriot is offline
post #2 of 30 Old 02-05-2013, 12:35 PM
cmay91472's Avatar
Liked: 42
Not unusual at all to see that amount on a grey slide. The big key is if you notice it on solid backgrounds while watching TV or when something pans across the screen. Everyone has a different tolerance level and it will all depend on how noticeable it may or may not be during normal viewing for you to be able to term it "bad".
But let's just say I have seen much, much worse than that.
downtownriot likes this.
cmay91472 is offline
post #3 of 30 Old 02-05-2013, 01:01 PM
PlasmaPZ80U's Avatar
Quoted: 2294 Post(s)
Liked: 706
that's actually quite a bit better than on my TS01 (S-PVA panel) UN46EH6030
which panel version do you have?
also, vertical banding is most visible on dark grey test patterns... so check dark grey patterns to see vertical banding at its worst (those grays are somewhat brighter than the ones I'd use to expose vertical banding on a set)
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #4 of 30 Old 02-05-2013, 03:38 PM
Phase700B's Avatar
Liked: 25
Unless it appears more pronounced on darker gray screens or as when panning on a football or soccer field, that screen looks fairly decent.
"Vertical" banding often shows more defined dark to lighter borders. Based on your pictures, your panel just shows some typical lighter and darker screen areas that blend pretty well.
If you see little or no banding when program material is being watched I would say you have a good TV panel. It looks about typical and better than some of the 8 TVs I've purchased and set up for family and friends.
Phase700B is offline
post #5 of 30 Old 02-05-2013, 06:39 PM
Hanna's Avatar
Hi, I just bought a new tv, Samsung 40es6100, and I did this test too but it doesn't look great, what do you think? Thnaks to all in advance.
Hanna is offline
post #6 of 30 Old 02-05-2013, 07:02 PM
cmay91472's Avatar
Liked: 42
Unfortunately, unlike the OP images, that looks really bad. I'd return that one immediately.
post #7 of 30 Old 02-05-2013, 07:58 PM
Hanna's Avatar
Thanks, that's what I thought, I didn't notice it yet while watching tv (I didn't have time to see anything properly yet), but I know it's a really bad panel and I could have a better experience with this model. I don't know if the store will replace it or if they will just argue that that's not an issue for them....
Hanna is offline
post #8 of 30 Old 02-05-2013, 07:59 PM
cmay91472's Avatar
Liked: 42
Where did you buy it?
post #9 of 30 Old 02-05-2013, 08:05 PM
Hanna's Avatar
I bought it in a small store here in Portugal. I am portuguese.
Hanna is offline
post #10 of 30 Old 02-05-2013, 08:28 PM - Thread Starter
I also have the TS01.
Since you have the same panel may I ask if you see faint vertical lines when viewing the "no signal screen" at extreme viewing angles? Anyone know if this is normal at extreme angles? At normal viewing angles the lines aren't visible at all.
Thanks again everyone for all the responses to my original question. smile.gif
post #11 of 30 Old 02-05-2013, 08:43 PM
cmay91472's Avatar
Liked: 42
If they are not visible at regular angles, don't worry about it. Your panel is an example of one that has very minor vertical banding.
post #12 of 30 Old 02-06-2013, 06:57 AM
Hanna's Avatar
Where can you see the panel information?
Hanna is offline
post #13 of 30 Old 02-10-2013, 03:58 AM - Thread Starter
Well that's good to hear, thank you. Would you say most LED/LCDs suffer from some degree of vertical banding?
post #14 of 30 Old 02-10-2013, 05:32 AM
cmay91472's Avatar
Liked: 42
Yes, almost all LED panels will display vertical banding to some degree. Some are minimal where it can only be seen on grey scale slides. Others are atrocious such as the Samsung 65ES8000 which is blatantly visible on almost all sources.
post #15 of 30 Old 02-10-2013, 04:23 PM
Liked: 706
the Samsungs with the S-PVA panel seem the most prone to it... other Samsungs with non S-PVA panels (like S-MVA, A-MVA, and Sharp panels) might still have it, but to a significantly lesser degree
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #16 of 30 Old 02-11-2013, 09:52 AM
Phase700B's Avatar
Liked: 25
It is interesting that some TV makes have a return to banding issues, which really are a manufacturing defect during bonding of the layers that make up an LCD panel. Maybe that's what comes with buying a low end basic feature LED TV. rolleyes.gif Not to mention the LEDs can degrade in as few as 10 months use as Chad-B found in a recent thread. Apparently the yellow producing element in the LEDs degrades and produces a color shift. It can sometimes be compensated for in calibration, but over time it is doubtful since it IS the actual light source for the LCD panel.
I have a 6 year old Mitsubishi LT-46231 with the S-PVA and have no banding whatsoever. It is the most uniform LCD panel I've seen compared to 8+ LCD/LED TVs I've purchased for friends and family over the past 2 years or so. It tops the S-IPS panel on my 42LD550 for lighting uniformity and black level also.
Back in '05 to 'early '08 there was no end to banding, columns, and clouding on all the major brands of LCD TVs. I had to return a Toshiba 47" in 2007 because it had three wide bands that were very visible especially on solid color back grounds in scenes.
post #17 of 30 Old 02-11-2013, 10:33 AM
cmay91472's Avatar
Liked: 42
I wouldn't call the Sony 65HX950, Samsung 65ES 8000 or 70 Sharp Elite low end, but all three display vertical banding to some degree with the 65 ES8000 just being flat out atrocious.
post #18 of 30 Old 02-11-2013, 01:20 PM
Phase700B's Avatar
Liked: 25
Wow. . . you're right. It seems perhaps, the whole manufacturing process for LCD panels have spotty quality control. That said, you are likely to have more panel issues with screen sizes over 40".
Also, maybe they try and crank so many out much too fast or other manufacturing process issues enter into it .
Here's an article about banding:
http://www.youtube.com/watch?v=_yzYtAsrKPA
post #19 of 30 Old 10-14-2013, 10:48 AM
Marbury021's Avatar
I bought a Samsung UN65F8000 a couple of months ago. Never noticed anything until I watched football on it. Particularly on kickoffs, I can see sections of darker and lighter green. I believe this is pretty bad vertical banding, but I really don't know how to best test for banding. Can somebody point me in the right direction? It has a 12 month warranty, so I'd like to get it replaced if it's bad (and it does appear to be to me - very bothersome when watching football).
Marbury021 is offline
post #20 of 30 Old 11-30-2013, 05:30 PM
kid97's Avatar
kid97 is offline
post #21 of 30 Old 11-30-2013, 05:32 PM
kid97's Avatar
i think my tv Is the worse I've seen. Samsung 65es8000
kid97 is offline
post #22 of 30 Old 11-30-2013, 05:49 PM
kid97's Avatar
Are all samsung 65 es8000 like that?
kid97 is offline
post #23 of 30 Old 02-09-2014, 03:21 AM
Daveikin's Avatar
Yours is just like mine... Samsung 6740...engineers from Martin Dawes came out and said it was acceptable... It's was really bad watching football and on grey backgrounds... I only bought it last week.its not acceptable to me.... This rubbish about things being within specification is total pap.... image.jpg 1166k .jpg file image.jpg 1159k .jpg file
ID:	75674   Click image for larger version
Daveikin is offline
post #24 of 30 Old 05-03-2015, 04:28 AM
Liked: 0
Ignore the swedish but Id really like some input if this is badvertical banding or not. Borrowing this old htread.
Samsung UE65HU7505
I've adjusted one image to be cross section with levels adjusted to display exactly where the vertical bands are.
ID:	698250   Click image for larger version
ID:	698258   Click image for larger version
ID:	698266   Click image for larger version
AnderSWE is offline
post #25 of 30 Old 07-02-2015, 11:53 AM
Quoted: 24 Post(s)
Liked: 3
Kdl60w630b
Hi,
I got my new Sony KDL60W630B couple of days ago. I ran some solid background color tests last night. I'm seeing some vertical banding. Would this be considered within normal range?
Cheers.
Chinook_pdx is offline
post #26 of 30 Old 07-14-2015, 06:44 PM
WilliamG's Avatar
Quoted: 637 Post(s)
Liked: 274
Originally Posted by Chinook_pdx View Post
Hi,
Cheers.
Hard to say. All TVs have some of it, and depending on the way the picture was taken it can make things look worse than they really are, or better than they really are. My same TV as yours has some vertical banding, too. Just the way it is...
Chinook_pdx likes this.
WilliamG is online now
post #27 of 30 Old 07-15-2015, 10:28 AM
Quoted: 24 Post(s)
Liked: 3
Thanks. I would say the picture I posted is a good representation of the vertical banding I'm seeing.
I've been posting this picture in my reviews of the TV on sites like Amazon, Best Buy and Sony websites and none of the Sony reps commented on it...
post #28 of 30 Old 07-15-2015, 10:29 AM
WilliamG's Avatar
Quoted: 637 Post(s)
Liked: 274
I'd say if it's very distracting under normal viewing conditions, return it/get it fixed. But all these sets have some vertical banding. Off-axis my TV is TERRIBLE, especially with no signal, or watching a soccer game. Oy... so bad..!
post #29 of 30 Old 07-15-2015, 10:38 AM
Quoted: 24 Post(s)
Liked: 3
I'd say 90% of the time, we don't notice the bands. We don't watch much sports. But yes, we did some tests watching soccer and the bands are visible during wide shots and panning.
Good luck with your TV. Is the warranty period over?
post #30 of 30 Old 01-17-2016, 09:16 AM
h29558's Avatar
Quoted: 40 Post(s)
900C is currently $2,299 on Bestbuy.com. Down a couple hundred dollars from its recent $2,500 price point.
h29558 is offline
Reply LCD Flat Panel Displays
Samsung Un32eh5000 32 Inch 1080p 60 Hz Led Hdtv , Samsung Un55eh6030 55 Inch Led 3d Hdtv , Samsung Un40es6100 40 Inch 1080p 120 Hz Slim Led Hdtv
