120/240/480hz - Always higher input lag as a result? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-08-2013, 10:54 AM - Thread Starter
John4721's Avatar
I wonder, do 120, 240, and 480hz TVs necessarily always mean inevitably higher input lag? Are the processing features these TVs employ to achieve smoother motion non-defeatable ( i.e. can't turn them off to achieve less input lag)?
John4721 is offline
post #2 of 5 Old 03-06-2013, 09:36 AM - Thread Starter
John4721's Avatar
Bump.
John4721 is offline
post #3 of 5 Old 03-06-2013, 10:22 AM
AGuy01's Avatar
Quoted: 64 Post(s)
Liked: 48
A television that has high refresh rates doesn't automatically mean it's going to have high input lag. If I'm correct (and please correct me if I'm wrong), they can achieve those refresh rates through certain image smoothing techniques and options, which you can enable, configure and disable at your leisure. On my Sony, that option is called Motionflow. When enabling it, it does increase input lag, but for most games I haven't had an issue with it. I've been playing Ni No Kuni (a Japanese RPG) and Tomb Raider (a third-person shooter) and the various Motionflow options haven't impacted my performance in either game. In something like Call of Duty or other competitive first-person shooters, though, it may be best to disable such features.
It's hard for me not to use the image smoothing effects in games, however. The interpolation technique makes movies look strange (the Sony has non-interpolation options, as well), but in games the effect is absolutely fantastic. It basically does what those 120Hz monitors do - and does it better - but without having to reach 120 frames per second to see a smoother image.
John4721 likes this.
AGuy01 is offline
post #4 of 5 Old 03-06-2013, 12:37 PM
8mile13's Avatar
Quoted: 1483 Post(s)
Liked: 827
Seems to me that there is a tiny bit more processing going on with higher refresh rates.
8mile13 is offline
post #5 of 5 Old 03-07-2013, 06:34 PM - Thread Starter
John4721's Avatar
Thanks for the replies, folks. That puts my mind at ease a bit.
John4721 is offline
Reply LCD Flat Panel Displays
