32" Samsung LCD LN32A300 color issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-11-2013, 04:24 PM - Thread Starter
orion_134's Avatar
Not your typical "I don't know how to adjust my TV", but "I have to adjust the crap out of my TV just to make it usable"...and even then it has a green tint. This has been an issue over time and we've continued to tweak the settings but now it's bad. I reset to factory defaults and most blacks are green and grainy while in the normal setting, if I switch to dynamic the blacks are bright red. The LVDS contacts are still bright and shiny, wiggling the wire at any point doesn't change the colors. The menu colors seem to be consistent with factory colors.
Any ideas? Bad LVDS cable? Old panel? Time to upgrade?
Jesse
orion_134 is offline
post #2 of 7 Old 02-12-2013, 11:36 AM - Thread Starter
orion_134's Avatar
bump
post #3 of 7 Old 02-15-2013, 03:38 AM - Thread Starter
orion_134's Avatar
So can anyone recommend a forum where people respond?
post #4 of 7 Old 02-18-2013, 05:44 PM - Thread Starter
orion_134's Avatar
Ok, so doing some testing today and the menu colors started changing. I think I've narrowed it to a main board.
post #5 of 7 Old 02-22-2013, 07:11 AM - Thread Starter
orion_134's Avatar
Turned it on with new main board, and it seemed fine at first, but after about 30 seconds the pink started fading into the menu color. Not the main board.
post #6 of 7 Old 02-26-2013, 07:52 AM - Thread Starter
orion_134's Avatar
Are there any repair ninjas on here?
post #7 of 7 Old 03-01-2013, 05:08 AM - Thread Starter
orion_134's Avatar
ttt
Reply LCD Flat Panel Displays
Samsung
