Samsung 46" help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-11-2013, 04:52 PM - Thread Starter
mopar4u's Avatar
Model LN-T4661F
Have a white screen. I get the Samsung sound when you turn on the tv. I can faintly see the menu. When I plug in coax or hdmi from the cable box I get no picture or sound. The same cable box is working fine with another HD TV.
Here is what I have done:
swapped T-Conn card and no change
swapped main board (board with HDMI's, RCA jacks etc) and no change
I'm thinking maybe swap the power supply next? The caps don't look bad and it has no problem turning on.
Any input on this would be appreciated, thanks
9803-0.jpg 171k .jpg file
mopar4u is offline
post #2 of 2 Old 02-12-2013, 10:15 AM - Thread Starter
mopar4u's Avatar
Anyone think a power supply will fix the problem? Any input?
mopar4u is offline
Reply LCD Flat Panel Displays
