Wall mount recommendation for Elite Pro 60x5fd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-12-2013, 10:13 AM - Thread Starter
yenal's Avatar
Hello,
My TV started to become a hazard for my 10 months old son. I want to wall mount it. Can I use a non Sharp wall mount for this TV? If so can you please recommend me a good one I can find in retailers? Also ease of installation is very important as I will be doing it myself. Ideally I would want a mount that comes with dry wall anchors.
In terms of installation tools I will need a drill, stud finder (to avoid studs?) and a screw driver. Am I missing something?
Thanks in advance.
yenal is offline
post #2 of 4 Old 02-12-2013, 11:03 AM
nakenergy's Avatar
I use this for my Elite 70 - http://simplicity.sanus.com/index.php/us/en/products/tilting-mount/SXDP3
got this at costco. No issues.
nakenergy is offline
post #3 of 4 Old 02-12-2013, 01:44 PM
greeno's Avatar
Liked: 25
you must find the studs and mount to them.
greeno is offline
post #4 of 4 Old 02-12-2013, 08:50 PM - Thread Starter
yenal's Avatar
Thanks a lot for your help. I got this one: http://m.bestbuy.com/m/e/product/detail.jsp?skuId=1048546&pid=1218213532596
It was a breeze to install. Now I regret why I waited all that time to do this smile.gif
yenal is offline
Reply LCD Flat Panel Displays
Sharp Elite Pro 60x5fd 3d Led Hdtv
