LG LM6700 or Samsung es6500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-12-2013, 12:57 PM - Thread Starter
Ecko915's Avatar
I was looking into getting an LED and came down to these 2.. Which one do you think think is better or maybe something else?? My budget is at most 1300
Ecko915 is offline
post #2 of 5 Old 02-12-2013, 01:24 PM
Dr.Shankenstein's Avatar
Quoted: 508 Post(s)
Liked: 442
If those are your choices the lm6700 would be better IMO. This generation low-mid range samsungs had pretty bad uniformity and even worse motion performance. If you don't mind waiting a few days you can get a lm7600 from best buy for $909 after they price match alltimetv.com. Which is a much better set than the lm6700 or es6500 IMO. That is for the 47" model on the 7600.
Dr.Shankenstein is online now
post #3 of 5 Old 02-12-2013, 03:14 PM - Thread Starter
Ecko915's Avatar
Yeah I have the Panasonic GT50 and it's not very bright to me and I'll probably give it a week or so and try to get used to it, if not I will get the lm7600 or is there a better tv I can get for around 1300 and no bigger then 50"
Ecko915 is offline
post #4 of 5 Old 02-12-2013, 03:45 PM
BassAtl's Avatar
Or, right now, the LM7600 is on sale in-store for $1199 at Frys, if there's one near you. I looked at it side-by-side versus the LM6700 and there is no comparison.
BassAtl is offline
post #5 of 5 Old 02-13-2013, 06:52 AM
Fam Money's Avatar
I have a LM6400 from Costco and will be returning it and am interested in the 7600. Could you explain how one could get that price from Best Buy? I assume alltimetv.com is going to have it on sell soon!?!? Also, they're not listed on Best Buy's site as being an online competitor they will pricematch.
For the above promotions, the Designated Major Online Retailers are: Amazon.com, Apple.com, Bhphotovideo.com, Buy.com, CircuitCity.com, CompUSA.com, Crutchfield.com, Dell.com, hhgregg.com, HP.com, HomeDepot.com, Lowes.com, Newegg.com, OfficeDepot.com, OfficeMax.com, Sears.com, Staples.com, Target.com, TigerDirect.com, and Walmart.com.
Fam Money is offline
Reply LCD Flat Panel Displays
Lg Cinema Screen 47lm6700 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv With Smart Tv , Samsung 65 Inch Class Smart Tv 3d Slim Led Hdtv Un65es6500
