LG 42SL9500 Led - screen problem - looks like snail trail? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-13-2013, 10:07 AM - Thread Starter
thexlr8r's Avatar
Had this LG 42SL9500 (exclusive to Dixons) for almost 3 years.
Over the past year, the screen has developed a strange fault.
its best described what looks like , a snail trail on the right side of the screen, and also slightly middle-bottom.
i have attached a picture taken while i was in service menu test white balance section.
Note: this fault only appears on HDMI inputs, and does not manifest itself on the tv's inbuilt test patterns within the Service Menu ??? rolleyes.gif
I contagted LG, but was a waste of time as its outside warranty and they didnt care to help at all.
Took it to a tv repair center and they said "new screen (£500)" , so thats obviously not an option.
here is a pic i took of the fault . fault areas are circled in yellow. you can see a weird stain / snail-trail mark.
I use a 4to2 matrix HDMI switchbox. thinking it was the problem, i removed it and tested several devices directly into each TV HDMI input socket, same result on all 4 inputs.
would appreciate any useful comments as to what this fault might be. thanks
thexlr8r is offline
Reply LCD Flat Panel Displays
