LG VS Vizio 50" LED TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-14-2013, 12:00 AM - Thread Starter
dgfalk's Avatar
Hello, new user and first time poster here. Heard this was the best forum on the net for this kinda stuff so heres my question:
I found 2 TV's within my price range, both are $700, that I would like to buy to replace a crappy old rear projection TV. I'm not a big TV watcher, don't care about blue ray and all that fancy crap. Pretty much all I watch is some HD channels on cable, and movies/tv shows that I stream from my computer via HDMI cable. Here are the 2
VIZIO 50” Class LED Smart TV E500i-A1
http://store.vizio.com/e500ia1-1.html
LG 50" LED 50LS4000
http://www.lg.com/us/tvs/lg-50LS4000-led-tv
The only big different I can see is the Vizio is a Smart TV, which I could care less about, I would probably never use those features. I also have owned a 32" Vizio TV for 4 years and have never had a problem with it, great little bedroom TV. Which one would you recommend?
dgfalk is offline
post #2 of 3 Old 02-19-2013, 11:25 AM
jLp vAk3r0's Avatar
I have the 50LS4000 and like it very much.
Unlike other LG tv's in that price range, you can actually turn on/off the TruMotion settings.
That Vizio has been recently reviewed by Cnet and apparently is a 60hz TV.
jLp vAk3r0 is offline
post #3 of 3 Old 02-19-2013, 11:28 AM
jLp vAk3r0's Avatar
BTW, where are you gonna purchase the LG if you go with it?
I found it for $649 at Best Buy on Super Bowl weekend.
Reply LCD Flat Panel Displays
Lg Electronics 50ln5400 50 Inch Led Lcd Hdtv , Vizio E500i A1 50 Inch Led Smart Fhdtv , Lg Electronics 50 Inch Led Lcd Tv Trumotion 50ls4000
