LG 47lv3730-TD Grey Vertical Bar? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-15-2013, 02:35 AM - Thread Starter
EdenDay92's Avatar
Hi guys,
I've been searching through and not sure if I'm either in the wrong forum or just can't search well enough but I have a problem.
My LG 47lv3730-TD has a grey vertical bar running down it. It's transparent and doesn't seem to change when the display has pressure applied.
I haven't taken the unit apart to test the tab bonds just yet however was wondering if there is a definitive cause for this issue? I'm under the assumption it will be an issue with the panel, but I'll leave this to the experts!
Eden
EdenDay92 is offline
post #2 of 3 Old 02-15-2013, 03:35 AM - Thread Starter
EdenDay92's Avatar
I've noticed when the t con board is unhinged on the corresponding side that the bar is still there.
That's confirmation that the panel has a fault, yes?
post #3 of 3 Old 02-15-2013, 06:29 PM - Thread Starter
EdenDay92's Avatar
A new update on the matter. After disconnecting the T-Con panel on one side, the bar is no longer visible (as far as I can tell). Further connections and disconnections are having similar results, though sometimes it appears the bar is still present but very very faint.
Is this an indication that the panel is in fact okay?
Reply LCD Flat Panel Displays
