How to connect Vizio VHT215 to LG 47LW5600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-16-2013, 02:34 PM - Thread Starter
panda104's Avatar
I have a Time Warner Cable box connected to a LG 47LW5600. Just bought a Vizio VHT215 soundbar. Need help to connect the soundbar to these two device. 47LW5600 has four HDMI, unsure any is with ARC or not. Also not sure it has digital optical.
Thanks in advice
panda104 is offline
post #2 of 5 Old 02-16-2013, 02:41 PM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Ratman is online now
post #3 of 5 Old 02-16-2013, 02:47 PM - Thread Starter
panda104's Avatar
Ratman:
Are you trying to advise me to buy some device from the posted link? Please advise. I just need some step by step advice on connecting these three devices. I'm very challenged with connecting AV devices together.
panda104 is offline
post #4 of 5 Old 02-17-2013, 06:14 AM
Ratman's Avatar
Liked: 1022
My mistake. I read too quickly. Sorry for the confusion.
From what I can read, both the TV and soundbar support ARC. So, run an HDMI cable the cable box into the soundbar's input and an HDMI from soundbar's HDMI output to the TV's (ARC capable) HDMI input. That's all you need.
post #5 of 5 Old 02-17-2013, 07:11 AM - Thread Starter
panda104's Avatar
Thank you, Ratman. I'll try your suggestion and report back if it works or not. I'm techno-challenged. Again, thank you.
panda104 is offline
Reply LCD Flat Panel Displays
Lg Infinia 47lw5600 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv
