Random Temporary Bleeding on LG 55LM6700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-17-2013, 02:22 AM - Thread Starter
Lee Pereira's Avatar
Hi All,
I previously had a 55LW5700 which was replaced by LG for a LM6700 because the first set had loads of bleeding.
Few months into the new set I get random and temporary bleeding on the bottom right hand corner. It had been gone for weeks and was working fine(No 3D used in the last couple weeks) and Last night i watched a bit of 3D content an this morning the bleeding is back.
I have tried loosening the screws at the back but no luck.
Also I've turned down the Backlight to 30 /100
There is a firmware update available but I think that's not relevant in fixing the issue.
Please advice
AVR - RXV 467
Source - PC - AMD 6000 Series Video Card
Setup
Video Card to AVR , AVR to TV , All Via HDMI.
Thanks in advance
Lee Pereira is offline
post #2 of 3 Old 02-17-2013, 04:36 AM
Navigationroad's Avatar
Is the room cold or lower than normal? I have my thermostat set back at night to 62F. If I check my LM5850 first thing in the morning, before the house gets up to temperature, I definitely seem to have more bleeding. After the house and the TV warm up it doesn't seem as bad.
Navigationroad is offline
post #3 of 3 Old 02-17-2013, 04:51 AM - Thread Starter
Thanks for your reply! That was the exact issue i had with my old set. The minute i would turn on my air conditioning up it would induce huge amount of bleeding. But the air conditioning is turned off during this part of the year.
Strange thing is that by the next week it will sort itself out(most of the time). I only use my set on weekends.
Reply LCD Flat Panel Displays
