Official Sony KDL-55W900A Owners Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 369Likes
post #4861 of 5874 Old 07-26-2014, 07:26 AM
steve1971's Avatar
Quoted: 504 Post(s)
Liked: 437
Originally Posted by oxygen7 View Post
Yes it was. Of course the first thing I did was factory reset. To me it seems to be not just this single unit problem, I've checked another unit in another store, and it seamed to have the same problems.
steve1971
You have to compare it with another display to see the difference, when viewed alone, 100% yellow might seem fine.
The photo I did isn't very accurate, the difference is actually not that much dramatic.
There is another photo, some other guy did with his 55w905a on the left http://fotkidepo.ru/?id=photo:904646 . It's not a clear representation of what i'm seeing, but at least close.
Here is what i'm trying to explain: http://www.fullhd.gr/images/stories/...inema2/cie.jpg . That's a gamut of 46w905a, it shows that if life color set on low, green is shifted towards blue and yellow is slightly undersaturated. In case of life color off ( http://www.fullhd.gr/images/stories/...inema1/cie.jpg ), green is just undersaturated and so is yellow.
But on 55w905a these problems are much more pronounced.
I'm trying to find a way for fix it somehow, it actually may be impossible to fix.
Maybe there exist some custom firmware for this tv or some kind of option in service menu for color adjust?
oxygen7, first if your using Live Color my suggestion is don't! Oh it may look pleasing to the eye but it over saturates colors and at times will undersaturate colors. Second I have compared my set to my older 46HX850 and my friends Samsung 8000 and in both cases the yellows on my W9 beat both of them as did the overall PQ and black levels. Its hard to say why your seeing what you are but if its a used set that may be the answer as used store sets are on almost 24/7. But honestly I don't know because this is the first time I have ever heard of someone having an issue with the yellow color of the W9, there may be others I don't know. But here's the thing if you aint satisfied with what your seeing then by all means return it, I would, unless you can live with it. With the W9 the positives of such a great tv far outweigh the negatives but its up to the individual person to make that call. For me its been the best HDTV I have ever owned and I have owned a few of them!
steve1971 is offline
post #4862 of 5874 Old 07-26-2014, 08:58 AM
bull3964's Avatar
Quoted: 169 Post(s)
Liked: 190
Are those results pre or post calibration. I'm almost thinking pre since two presets are compared.
This is actually one of the most accurate TVs for color out there right now after the white balance has been calibrated. For example, below is the post calibration results from a review on the internet. I can confirm that mine looks very similar after calibration.
If you can't get results like that after calibration, than the tv is likely faulty in some way. I would stay reset to defaults and either get a meter or have someone come do a pro calibration.
steve1971 likes this.
bull3964 is offline
post #4863 of 5874 Old 07-26-2014, 09:03 AM
dende82's Avatar
Using Live Colour on Low and dropping saturation by a few points (=45-49) gives punchy colours without being too oversaturated. I like that setting, it's worth a try.
dende82 is offline
post #4864 of 5874 Old 07-27-2014, 12:58 AM
Didee's Avatar
Quoted: 48 Post(s)
Liked: 43
@oxygen7
In the first comparison (your own photo), it's the W905 that is showing yellow. The BenQ, on that photo, does not show yellow, but lime green.
In regard to
this one seems like the W905 has much few light output than the other one. Did you go into system settings and have disabled the light sensor in the Eco menu? When compairing to other displays, it definetly should be off. If backlight is lower on one one panel compared to another (in this case due to Eco light sensor), the picture often is described as "dull", "lifeless", "has no punch", and whatnotelse, even if it's just reduced light output. - Just turn the light sensor off, and probably your yellow will be so punchy and saturated, yummy!
Another point is -- viewing angle, indeed. The characteristic of the W905 panel is that of the RGB matrix, the green channel is losing contrast a bit quicker than the R and B channels when viewed from an angle. This is the reason for the "pink tinge" that is often talked about, and it will also affect colors like full-green (becoming more yellow) and yellow shifting a bittowards orange and become darker. Problem is, when you have two sets side-by-side, than you always deal with some kind of off-angle viewing.
On the positive side, it seems your W905 has pretty good screen uniformity. Compared to other W905' panels, there seems only very minor signs of "fingers" ate the left/right edges, or DSE/banding over the screen area. Seems like a lucky hit!
Didee is offline
post #4865 of 5874 Old 07-29-2014, 05:21 AM
Liked: 0
Thank you for your answers.
My 55w905a has approx. 1600 hours of operating time. It was the last one from store shelf when I took it. It is an equivalent of 5-6 moths on normal use and I don’t think it’s enough for TV to degrade in some way. Led’s don’t degrade that fast.
I know some tricks and definetly turned eco setting off, also tried setting hdmi full\limited range. color x.v.\normal. Also tried outputting 10bit x.v. color from my ps3.
Where could I download another firmware to this tv? I don't want to put the latest version from Sony site, because it is impossilbe to downgrade if something goes wrong. Some guy wrote that motionflow impluse mode became worse with the latest firmware.
So I would like to find some previous versions. Maybe someone still has it?
oxygen7 is offline
post #4866 of 5874 Old 07-29-2014, 06:56 AM
steve1971's Avatar
Quoted: 504 Post(s)
Liked: 437
Previous Firmware's are hard to find for the W9. In days past you could down load previous firmware updates but with newer models that aint the case anymore so good luck trying to find one. That being said 1600 hour's is a lot of hours on a tv but not surprising for an open box tv being that they are on all the time. Could that be the reason for what your seeing? Could very well be but not sure. I really don't know what to tell you except maybe if your not happy then maybe get your money back and buy a different set. Would I? Yes. I stay far away from open box and refurbished TV's because I simply don't trust them because god only knows what they been through with previous owners/stores
post #4867 of 5874 Old 07-29-2014, 10:30 AM
ph00p's Avatar
My AVR won't give me the option to Auto Lip sync with this tv, it's a Yamaha, I've read that auto lip sync is supposed to be a HDMI 1.3 feature, the AVR is newer and of course this TV is new enough, maybe this is an AVR issue? Could it be my hdmi cable?? I'm a bit lost, but when I go into Lip sync on the AVR it won't let me do AUTO.
EDIT: According to the AVR manual
"Adjusts the delay between video and audio output automatically whena TV that supports an automatic lipsync function is connected to theAuto (default)unit via HDMI"
But I can't select AUTO on the AVR, any ideas??
ph00p is offline
post #4868 of 5874 Old 07-30-2014, 06:53 AM
steve1971's Avatar
Quoted: 504 Post(s)
Liked: 437
ph00p, that's definatley and AVR issue! It should let you select AUTO. Try a different HDMI cord and if that don't work? See if you can give Yamaha customer support a call to see if they can help. But that is a head scratcher for sure.
post #4869 of 5874 Old 07-30-2014, 11:44 AM
delfincek's Avatar
Quoted: 31 Post(s)
Liked: 53
Hiya Oxygen,
When I bought my W905A I was also not so satisfied with how the colors were represented. I used and tried many settings published online and also here. Then I went on a trial for my own settings using different technics to achieve as natural as possible for my ambient and usage.
I also had problem with yellow if I used Cinema 2 and Warm. Green was never green but was more or less all the time moving towards yellow. Here are my settings and now I'm very satisfied with all the colors. For calibration I used Nokia monitor test and Lagom LCD test (online tool).
best, d.
delfincek is offline
post #4870 of 5874 Old 08-01-2014, 01:14 AM
tempa5's Avatar
Guys i really need you help here.
i aswell am tempted to buy the w905 in its 46 inch version. However uniformity is still a concern to me.
Let me start out that i use a Hx755 40" and i see very little uniformity issues.
Calibrated in a pitch blck room: barely visible clouding/flashlight in the corner unnoticable in movie watching.
I used this test pattern: http://img1.lesnumeriques.com/news/1...clouding-1.jpg
However, i wonder how you guys test grey uniformity (DSE) or those fingers etc.
I have the calibration AVS downloaded. Which Test patterns do you use?
-When i use a test pattern like the pure field gamme option 80%, i see nothing. The same goes for full field 100% clour test pattern.
Should i noot be seeing a little bit at all or am i using the wrong test pattern?
In real live content while panning, there is some dse i can see. / though thats normal for LCD/LED Backlight Tvs.
should it not be like these? http://www.rtings.com/info/gray-unif...een-effect-dse
Also as far as i know the smaller the screen size= less uniformity issues.
So in theory 55" usesr here should have more issues than 46" am i right?
Hope you can help me out here.
tempa5 is offline
post #4871 of 5874 Old 08-01-2014, 04:34 AM
Quoted: 16 Post(s)
Liked: 1
a Best Buy in my area has a 55w900a which was a shelf display for $719.99. Has everything but has three 1/2 inch scratches in the middle of the screen though. Worth it?
balancedphoto is offline
post #4872 of 5874 Old 08-03-2014, 06:18 PM
Luckybum's Avatar
I'm watching the Hall of Fame game right now on my Best Buy bargain TV and it's absolutely spectacular! I bought it with a lazy pixel but from where I'm sitting...it's just as if it was white glove delivered by Sony. Good stuff!
Luckybum is offline
post #4873 of 5874 Old 08-04-2014, 12:27 AM
DMViolator's Avatar
Been looking at new tvs, and wanted something 'decent' for a change. I do prefer Sony generally, and the W905a seemed to tick the boxes, particularly with the triluminous feature and panel type used.
I see now it's been discontinued. John Lewis in the UK are offering the Sony Bravia KDL46W905 for £799. Are these the same models (there's no a after the 905), and is it definitely worth getting over the 2014 models (haven't seen glowing reviews of these)?
I'm not bothered about the sound as it'll be routed through my 5.1 setup, PQ is all important.
DMViolator is offline
post #4874 of 5874 Old 08-04-2014, 05:27 AM
delfincek's Avatar
Quoted: 31 Post(s)
Liked: 53
It is the same model, distributed in EU regions. In terms of picture quality it is without a single doubt a truly spectacular TV. Best, d.
steve1971, DMViolator and _Jack_ like this.
post #4875 of 5874 Old 08-04-2014, 06:40 AM
steve1971's Avatar
Quoted: 504 Post(s)
Liked: 437
I have now had my W9 since May and it could be my eye's but it seems to have gotton better, if that's possible, PQ wise. I am beginning to wonder if these TV's do indeed get better as time goes on.
post #4876 of 5874 Old 08-04-2014, 12:07 PM
DMViolator's Avatar
Seems I have the approval of the other half as well, so happy days I'm hoping this will sync in nicely with the Oppo 93 as well.
post #4877 of 5874 Old 08-07-2014, 05:40 AM
steve1971's Avatar
Quoted: 504 Post(s)
Liked: 437
Watched 3 Blu rays last night. Transformers, TF Revenge Of The Fallen and Pacific Rim. Damn I love my W9! My W9 hooked up with my Sony 6200 makes an unbeatable combo. I have never seen these 3 movies look so good. Lovin the HD life right now.
post #4878 of 5874 Old 08-08-2014, 10:57 PM
aragno's Avatar
Anyone experiencing any Skype connectivity issues?
I did a factory reset.
I tried wireless and wired connections. Both passed the connectivity tests.
Online content from YouTube and another online source worked.
Skype returns this message when I login (using the correct or incorrect password):
"Skype cannot connect to the Internet. Please check your Internet connection in Settings."
-Trey
aragno is offline
post #4879 of 5874 Old 08-09-2014, 07:42 AM
steve1971's Avatar
Quoted: 504 Post(s)
Liked: 437
Watched a few pre-season NFL games for the first time on my W900 and all I can say is WOW! Just chalk up yet another reason why I love this tv so much. Fantastic is all I will say.
post #4880 of 5874 Old 08-10-2014, 12:57 AM
DMViolator's Avatar
Got to say I'm loving this TV. Using Steve1971's calibrated settings (using TrueCinema instead of Standard for MotionFlow tho'), BR has never looked so good
post #4881 of 5874 Old 08-10-2014, 01:04 AM
DMViolator's Avatar
You might want to check this out http://www.sony.co.uk/support/en/con...ed-on-some-tvs
Seems there's some update being done.
post #4882 of 5874 Old 08-12-2014, 05:13 PM
helvetica bold's Avatar
Quoted: 465 Post(s)
Liked: 279
Just got home from work and got prompted for a TV firmware update. Weird it did happen in the morning. Anyone get the update?
steve1971 and DMViolator like this.
helvetica bold is offline
post #4883 of 5874 Old 08-12-2014, 05:38 PM
steve1971's Avatar
Quoted: 504 Post(s)
Liked: 437
I got my update for my W9 this morning as well. Don't see any PQ improvement which to be honest I don't know if it can get any better then it already is. I guess we will have to wait and see what Sony say's this updates for but knowing Sony that explanation may take awhile lol!
post #4884 of 5874 Old 08-13-2014, 04:59 AM
DMViolator's Avatar
Yep just installed it now. Can't see any immediate difference, but it's probably an app update or something.
Sony W905a (46)
Mede8er 600X3D
Anthem MRX 510
JL E112
KEF LS50 (5)
ATI 1805
post #4885 of 5874 Old 08-13-2014, 09:55 PM
aragno's Avatar
Perhaps they have addressss the recent Skype issue which I asked about a couple days ago.
-Trey
aragno is offline
post #4886 of 5874 Old 08-18-2014, 07:42 PM
Flemi's Avatar
Has anyone had success getting 5.1 sound from the toslink (optical out) when they have connected their laptop up to the W9 via HDMI? My laptop only seems to want to output stereo pcm to the TV for video I have which is encoded in DD5.1. This is my set up:
Laptop>HDMI>Sony W9>toslink>receiver
Is it a handshake issue? Is the HDMI from laptop to TV only thinking the TV is stereo and is not delivering DD5.1 to the receiver?
Thanks in advance!
Flemi is offline
post #4887 of 5874 Old 08-18-2014, 11:55 PM
delfincek's Avatar
Quoted: 31 Post(s)
Liked: 53
What kind of receiver do you have? Why do you have it connected like this?
My connection is like this:
TV watching
from optical out to optical in on A/V receiver via optical cable
HTPC usage
from HTPC HDMI output via HDMI cable to A/V receiver HDMI input. Another HDMI cable from A/V receiver HDMI output to HDMI input on Sony TV.
When using like this I just need to select correct audio input on A/V receiver when watchin certain source and that's it. I'm not doing circles with sound through TV when using my HTPC.
Another important note:
When putting out Dolby Digital 5.1 from the TV. There are two settings important in the TV menu: Sound \ Speakers. This setting you need to set to Audio System. That way the internal TV speakers are automatically disabled. If you want to have 5.1 content passed through optical then you need to set Sound \ Digital Audio Out to Auto and not PCM (PCM will pass through only stereo 2.0).
Also you need to be attentive to the settings which you find in menu Digital Set-Up \ Audio Set-Up -> here you need to set Audio description to Off in order that DD5.1 is pass through the optical cable, otherwise I have only stereo while watching TV programme with DD encoded sound. This last setting may vary from country to country and depends on the cable provider.
best, d.
post #4888 of 5874 Old 08-20-2014, 03:30 AM
Flemi's Avatar
TV watching
HTPC usage
best, d.
Thanks for the suggestions but they didn't work I've hooked it up this way as the W9 has more HDMI in slots. The Receiver is running out of HDMI ins (3).
I think it might be a handshake issue. Maybe the W9 is telling my laptop it only accepts stereo pcm? I can definitely see that only a stereo HDMI signal is going in.
Otherwise it might be that the laptop's sound card for some reason only outputs in stereo.
I guess the only way to find out is to plug the laptop via HDMI into the receiver.
Does anyone get 5.1 outputted via toslink from a HDMI signal?
Flemi is offline
post #4889 of 5874 Old 08-20-2014, 03:45 AM
delfincek's Avatar
Quoted: 31 Post(s)
Liked: 53
Yes, first you will need to configure your notebook to output DD in its 5.1 form through HDMI. Connect notebook to A/V receiver directly. Be sure that is set for 5.1 and that there is passhtrough. This depends on the drivers and software you use on your notebook. If you share the model of the notebook we can see what are the proper settings for it.
best, d.
post #4890 of 5874 Old 08-22-2014, 12:00 AM
Quoted: 465 Post(s)
Liked: 279
Watched The Amazing Spider Man 2 BluRay tonight. It's a Sony release so it's mastered in 4K w/ xvYCC color. Looks spectacular on the W9. It's not the best super hero film but it's ref quality AV.
Reply LCD Flat Panel Displays
Sony , Sony Bravia 55 Inch Led Tv 3d Support Bravia Hx850 Kdl 55hx850 , Sony Xbr 55hx950 Bravia Led Hdtv , Sony Kdl 55w900a 55 Inch Led Hdtv
