Official Sony KDL-55W900A Owners Thread - Page 177 - AVS | Home Theater Discussions And Reviews
post #5281 of 5293 Old 03-16-2015, 02:51 AM
Jorgens's Avatar
Originally Posted by winb83 View Post
Anybody have any idea where I can get the "Guide Pins" for this TV for the stand. I can't find them on Sony's site. They help support the TV stand and screw into the back of the TV. The stand has spaces that they slide into. I don't have mine as I purchased a display model that apparently had them removed.
iirc the guide pins are mainly there to allow you to initially hook/hang/support the screen on the stand when you are assembling it. the 4 additional screws then secure the screen to the stand. the guide pins probably provide some additional structural support, but any similar screws would work (and dont need to be "sony" )
they just need to have the right thread diameter, length of thread, and the correct shape head.
steve1971 likes this.
Jorgens is online now
post #5282 of 5293 Old 03-26-2015, 09:19 AM
Keirik's Avatar
Anyone have any advice for me with this tv when it comes to using game mode with the ps4? Specifically, it darkens and washes out the picture a lot under game mode. Is there something I can change to fix that?
Keirik is online now
post #5283 of 5293 Old 03-26-2015, 10:14 AM
steve1971's Avatar
Quoted: 274 Post(s)
Liked: 318
Try adjusting your Game Mode settings. When my friend comes over with his PS3 and we game I leave the Game Mode settings as they are which how they were "out of the box" as they say.
steve1971 is online now
post #5284 of 5293 Old 03-26-2015, 10:15 AM
steve1971's Avatar
Quoted: 274 Post(s)
Liked: 318
My wife and I watched the Hobbit last night and all I can say is jaw dropping!
post #5285 of 5293 Old 03-26-2015, 10:42 AM
Quoted: 17 Post(s)
Perhaps the PS4's auto range option is sending a signal to the TV that looks like this with your settings. I think its auto mode defaults to sending a Limited signal, so perhaps try forcing it to Full and calibrate the TV around that. Just a thought.
mjpartyboy is offline
post #5286 of 5293 Old 03-27-2015, 08:25 AM
delfincek's Avatar
Quoted: 16 Post(s)
Liked: 45
mjpartyboy has a point. Set everything (PS4 and TV) on Full for gaming. On TV you can find that setting under: Home / Settings / Display Settings / Video Input Settings / Dynamic Range / HDMI (x)
best d.
delfincek is offline
post #5287 of 5293 Old 03-27-2015, 06:18 PM
Keirik's Avatar
Ive already done that before i posted this. Any other ideas?
post #5288 of 5293 Old Yesterday, 07:46 AM
Didee's Avatar
Quoted: 17 Post(s)
When you say that Game Mode "darkens and washes out" -- which picture mode are you referring to in comparison? (If you compare to "General-Vivid", then it's no surprise )
As Steve said, adjust your picture settings under Game mode. Game-Standard behaves pretty much like General-Standard, and Game-Original behaves pretty much like General-Custom.
Didee is offline
post #5289 of 5293 Old Yesterday, 01:11 PM
Keirik's Avatar
Well, i know it's not going to be like vivid, but what I mean is the black levels aren't as black as they look washed out grey. I've adjusted it and gotten it to where I like it, but is there anything under game mode that i shouldn't turn back on (besides what is obviously greyed out so i cant turn on)? I don't want to use game mode but then still have some input lag because i enabled a few features
post #5290 of 5293 Old Yesterday, 02:09 PM
Didee's Avatar
Quoted: 17 Post(s)
Sorry if I'm dull, but for me it's a bit hard to decide what your actual problem is. One time the picture is too dark, but then, when "the blacks look grey", it's kind of "too bright" again, isn't it? Moreover, you did not say the problem is with games in general (which would indicate wrong RGB levels setting), but you explicitely said it is when using Game Mode (which would collapse things down to a problem with picture settings).
So. Is the problem present with games always, regardless of Scene Mode? Or are games okay with Scene General or Scene Cinema, and look only bad with Scene Game?
Simple test. Bring on a dark screen with lots of black. The TV's native black point is at "Brightness=50", exactly there and nowhere else. Check in a very dark room. When things are correct, then the plain-black level should not change with Brightness<<50, and full-black should immediately begin to brighten up with Brightness=51..52..53.
If you need to bring brightness down to ~36 for full-black to get truly black, then there is an input level mistake (input="limited", TV expecting "full").
If true-black only starts to brighten up from Brightness=64 upwards, then there is an input level mistake (input="full", TV expecting "limited").
Didee is offline
post #5291 of 5293 Old Yesterday, 11:51 PM
Liked: 0
new member to this forum here. sorry if this has been answered before, but can someone tell me how to access to diagnostics of my kdl-55w900a ?
i am trying to just get a read out on the total times booted, run hours, etc. im not trying to change anything and i have no issues currently.
any insight as how i can obtain this info would be great. thanks
twenty20 is online now
post #5292 of 5293 Unread Today, 08:12 AM
Keirik's Avatar
It's only when putting on the game mode in scene select. The picture is outstanding when watching a movie, tv, etc. The picture istself is dark. The blacks are washed out. I've managed to someone alleviate this by altering a lot of the settings in game mode but won't that just increase input lag again?
post #5293 of 5293 Unread Today, 09:58 AM
steve1971's Avatar
Quoted: 274 Post(s)
Liked: 318
In my opinion its not the tv but something with your setting choice. I know from experience game mode out of the box is outstanding and that all I do when I game is switch to game mode and I'm ready to go with no adjustments being made. But thats just me.
Reply LCD Flat Panel Displays
Sony , Sony Bravia 55 Inch Led Tv 3d Support Bravia Hx850 Kdl 55hx850 , Sony Xbr 55hx950 Bravia Led Hdtv , Sony Kdl 55w900a 55 Inch Led Hdtv
