Best way to clean an HDTV cabinet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-17-2013, 09:50 PM - Thread Starter
william92371's Avatar
I've had my Sony KDL-32BX420 1080p TV for about two years now, and it is wall mounted. I'd never really looked up close at the cabinet itself until last night, and it's pretty dirty.
I have some very light scuff marks in the frame surrounding the screen from when I wiped it down. What's the best cleaner + cloth to use to clean and polish the cabinet frame, and hopefully buff out some of those scuff marks?
Thanks guys!
william92371 is offline
post #2 of 6 Old 02-18-2013, 05:36 AM
cmay91472's Avatar
Liked: 42
Microfiber cloth with a little water applied (damp) to the microfiber cloth if needed.
cmay91472 is offline
post #3 of 6 Old 02-18-2013, 08:04 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 431
+1
steve1971 is offline
post #4 of 6 Old 02-18-2013, 08:15 AM
bassett72's Avatar
Originally Posted by steve1971 View Post
+1
+2, this is the best method. I used distilled water for the screen itself (Just to get the purest water I can), but use a different MF towel on the screen.
bassett72 is offline
post #5 of 6 Old 02-21-2013, 06:37 AM - Thread Starter
Thanks, guys. I will give that a try.
Sometimes the simplest solution is the best.
post #6 of 6 Old 02-21-2013, 09:11 AM
Navigationroad's Avatar
While the distilled water and micro fiber cloth is the best method for cleaning the screen I don't think it will remove the scuff marks in the plastic bezel. I'm quite OCD when it comes to this type of thing. I had the exact same problem on my Samsung bezel. Wish they wouldn't use such soft shiny plastic. What I did to help remove the micro scratches was to use an automotive polish with a low abrasive factor; I used Turtle wax. Apply a small amount of the wax to a slightly dampened very soft cotton cloth and buff the frame/bezel with it. The amount of buffing is up to you and the extent of the scratches. Let the polish dry for a few minutes then buff again with a dry cloth. This should remove many of the visible scratches but not all. Be very careful so as not to get any polish on the screen
Whenever I do something like this I always test it in an inconspicuous area first to see how effective it is. If it doesn't make a difference to your satisfaction, don't bother doing to whole frame. If it does improve it then go for it. I have used this technique on several plastic surfaces with varying degrees of success. I have not had any problem with the polish attacking or reacting with the plastic. If you have concerns on this front what you could do is leave it for a day or two after you do your trial run and then check it.
Hope this helps. Good luck.
Navigationroad is offline
Reply LCD Flat Panel Displays
