Samsung UN7000 HDMI inputs are dead - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-19-2013, 09:37 AM - Thread Starter
Super Moderator
markrubin's Avatar
Quoted: 1299 Post(s)
Liked: 2790
I have a 55 inch Samsung 7000 series LCD in my office that is approx 2 years old
Over the weekend there was a major power failure: when I powered the display on this morning, no HDMI input worked: the component video input still works
I tried all 4 HDMI inputs: I know the sources work
any ideas?
TIA
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #2 of 5 Old 02-20-2013, 10:23 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2790
bump
anyone?
post #3 of 5 Old 02-20-2013, 05:41 PM
thiao's Avatar
Quoted: 18 Post(s)
How to troubleshoot the HDMI (from the service manual for a 2010 'C' model 7000 series.
Alternatively, you can replace the Main board.
thiao is offline
post #4 of 5 Old 02-21-2013, 02:57 AM - Thread Starter
Super Moderator
markrubin's Avatar
Liked: 2790
Thanks for the info: that is what I thought
also noticed the Ethernet connection is dead : and when I power it up on an HDMI input the panel resets itself
The panel is 3 years old and came with a one year warranty so I will use the component video input for a while until I decide what to do: I don't think I want to put any money in it for repairs...
post #5 of 5 Old 02-21-2013, 03:34 PM
thiao's Avatar
Quoted: 18 Post(s)
You're very welcome.
Repair at the component level is a PITA and requires specialized skills/equipment and component availability.
A replacement main board for your set, from the usual sources, would run around $100 and very much a DIY project.
There is also also the remote possibility, that the power failure corrupted the eProm firmware or a setting.
However, I never recommend entering the service menu, unless you have the procedures/settings in the service manual on hand.
Note: broken HDMI, Ethernet and eProm firmware, all point to the main board.
thiao is offline
Reply LCD Flat Panel Displays
