Official LG 84LM9600 (Ultra HD 4K) Owners' Thread - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1351 of 1352 Old 02-11-2017, 09:20 PM
zebity's Avatar
Hdr
Hi BC,
Assume as you are connected to PC that you are connected to HDMI 2. This supports HDR, but not HDCP 2.2 .
I am only using HDMI 1, and Picture setting to enable/disable HDR is greyed out.
Originally Posted by bryan_chow View Post
I'm a bit confused by HDR. I use the TV connected to a HTPC and Nvidia tells me it has HDR and the TV has a HDR setting as well.
Think of HDR as like turning up brightness of TV up full, but without washing out blacks to greys, rather it provides greater luminescence across entire colour range. To provide this extended range you need to have extra bits (ie going from 8 bits per RGB channel to 10/12 bits per RGB).
If display did not have ability to achieve greater level of luminescence then then none of this would matter. Like an old cathode TV with burnt out phosphor, when you have to turn up brightness to max just to get enough light to see picture.
Cheers,
Zebity.
zebity is offline
post #1352 of 1352 Old Yesterday, 06:38 PM
bryan_chow's Avatar
Originally Posted by zebity View Post
Hi BC,
I am using HDMI 2, which is the only input that supports 4K at 60 FPS (which is what I'm running it at).
bryan_chow is offline
Reply LCD Flat Panel Displays
Epson V11h475020 318 Inches Powerlite Home Cinema 710 Hd 720p 3lcd Home Theater Projector , Oppo Bdp 103 3d Blu Ray Player , Pioneer Elite Vsx 21txh 71 Av Receiver , Lg Electronics 84lm9600 84 Inch Uhd 4k , Klipsch Reference Series Rf 82
