Official 2013 Sony R550A series TVs (KDL-xxR550A) --- 50", 60", and 70" - Page 147 - AVS | Home Theater Discussions And Reviews
post #4381 of 4391 Old 03-07-2015, 04:34 AM
mp06011999's Avatar
Quoted: 20 Post(s)
Liked: 42
Sorry I don't have an answer for ya on the "problem", but if you happened to buy it on an American Express card the warranty should be extended a year past Sony's one year warranty.
We got our 70 inch over a year ago, but have had it on A LOT. Not kidding when I say it can be on 12 hours a day! Mostly I started leaving it on because of all the issues people seem to be having and I really wanted any issues that I may have to show up while it was still under warranty - be it Sony's or Amex's. So far so good with fingers crossed.
Anyhow, just thought to mention the Amex warranty thing because I have forgotten about that a time or two. I try to buy all my pricey electronics on it. Good luck.
mp06011999 is offline
post #4382 of 4391 Old 03-07-2015, 07:24 AM - Thread Starter
tgm1024's Avatar
Quoted: 1102 Post(s)
Liked: 1189
Originally Posted by AvidanS View Post
Yes this happens on all HDMI ports, with blu-ray, TV (antenna input) and component video-in input.
Thank you once again for all your help!
It still could be a mobo problem, but I'm just not sure. Please have a service guy check it out. It could be HUGE (corrupted panel and fried whatever and dump the TV) or small (replace a mini board with a capacitor on it). It'll require a service guy....I would start by calling Sony themselves.
Sorry I can't help better. :-/
Don't drink the Kool-Aid. And specifically for Bitcoin fanatics: Stop drinking the bong water.
tgm1024 is online now
post #4383 of 4391 Old 03-18-2015, 11:49 AM
HGN2001's Avatar
Originally Posted by BALDheadedGRL View Post
yeah its pretty crazy. here are some pictures and a short video of the issue from black ops 2.
It only does it while moving around which is crazy, the second movement slow down it stops. check out the vid.
https://dl.dropboxusercontent.com/u/...%2002%20PM.mov
Resurrecting a point made here a long time ago, I also just encountered the phenomenon and wanted to expound upon it here. Up until now, I've not had any of the common "symptoms" that have been complained about here. If I have "clouding", it's extremely mild and doesn't bother me at all. If I have blobs, I've not been able to detect any - thus I've echoed the sentiments of a few here that my set is among the better ones. I see some "lavender lips", but not to the degree that it bothers me. Bottom line - there's more "right" with this 60" TV than there is "wrong" with it.
Now, to the blue ghosting effect. In playing with settings over the last couple of years, I think I noticed it once before, but couldn't nail it down. At this point though, I think I DO have some factors nailed down.
Most of the time that I've watched this set, it's been in the "Custom" picture mode. For some reason, I recently switched to "Standard" as I was messing about with "Live Color" and sharpness settings and left it there. The other day, I ordered and received THE TWILIGHT ZONE on Blu-ray and began watching an episode or two and that's when I noticed blue-ghosting as the camera panned left or right. As soon as the camera stopped, everything looked normal again. The blue effect stood out as the program is all black & white - so any coloring effect is easily spotted.
My heart began to sink. Has my TV started down the road to degradation? Am I going to be dealing with the dreaded Sony customer service that I've seen detailed here? Has the set been in service too long for anyone to do anything about it? Can I learn to live with this blue-ghosting?
As I played with settings to try to minimize it - turning color down didn't help at all - adjusting sharpness wasn't a factor - color temperature settings didn't matter, I DID stumble upon the fact that I'd left the set in "Standard" all this time. Setting it back to "Custom" seems to have alleviated the problem. I just watched a couple of those TWILIGHT ZONE episodes and saw no trace of the blue ghost.
So, if "BALDheadedGRL" is still around with this television, or if anyone else has come upon this phenomenon, perhaps an adjustment from Standard to Custom will do the trick.
One thing I've noticed is that "Custom" tends to have a sharper picture than "Standard" and I've had to back off the sharpness control a bit to compensate, but that's easy enough to do.
Harry
HGN2001 is online now
post #4384 of 4391 Old 03-24-2015, 05:12 AM
BALDheadedGRL's Avatar
Harry
Nope my solution was to get a samsung 65F8000, which was just replaced with a HU9000 after grounding issue.
I couldn't deal with the ghosting and I was well with in my return period at test buy.
BALDheadedGRL is offline
post #4385 of 4391 Old 04-05-2015, 01:37 PM
caspermi's Avatar
I have the 70" version and am having wireless wifi connectivity issues. I cant make it through a two hour movie on Netflix without losing wifi connectivity at least a couple of times. I check the signal with a WiFi analyzer app and the signal is strong, no problem with any other wireless devices. Is anyone else having wireless wifi connectivity issues? Is there a known problem with this wireless on this set?
caspermi is offline
post #4386 of 4391 Old 04-06-2015, 09:23 AM
mp06011999's Avatar
Quoted: 20 Post(s)
Liked: 42
cable trumps wifi 4 sho
I only tried wifi early on, right after getting the set. It worked fine, but I decided to run cables to each room after realizing that I use web services ALOT. Appears my Apple router doesn't play nice with ALL others. While it was a pain crawling around in the attic, glad I cabled. So reliable now.
So sorry I can't help ya. But even if you do get it figured out, if your set-up allows, nothing like cable over wifi. Seems these non-computer devices agree. And it allows me to run Netflix HD and 3D even though my internet speeds say I shouldn't be able to. With wifi it was often an issue.
tgm1024 likes this.
post #4387 of 4391 Old 04-06-2015, 09:30 AM - Thread Starter
tgm1024's Avatar
Liked: 1189
Which category are you running? Cat5e? Cat6?
post #4388 of 4391 Old 04-06-2015, 11:14 AM
Cucuy's Avatar
I have been using wifi since I got the set. No connectivity issues I can think of related to the set. Sometimes when watching Amazon and or Netflix I see some reduction in resolution but could be my IP provider or my wireless network congestion or the set.
Cucuy is offline
post #4389 of 4391 Old 04-06-2015, 10:51 PM
mp06011999's Avatar
Quoted: 20 Post(s)
Liked: 42
I ran Cat5e. I'm on DSL with "upto" 10 Mbps. Speeds pretty consistent. So glad I wired. No more issues with Netflix Super HD or Netflix 3D since I did. It's just so much more stable and consistent.
FWIW, I had tried a Vizio 70 inch sorta smart tv. Sorta because it couldn't stream for crap. Not all wifi devices seem to work well together.
post #4390 of 4391 Old Yesterday, 06:57 AM - Thread Starter
tgm1024's Avatar
Liked: 1189
What are the specs of that port I wonder.......
post #4391 of 4391 Old Today, 08:35 AM
mp06011999's Avatar
Quoted: 20 Post(s)
Liked: 42
I ran 3 Cat5e cables from the Apple router in the home office through the attic to each of the 3 rooms that have devices normally connected to the web. In two of those rooms I added a cheap ethernet switch and have multiple devices connected at those switches (PS3, Xbox360, TV, laptop, etc.). It's so awesome to not have interference messing up the connection like I would get with wifi.
Netflix Super HD looks awesome on the 70 inch tv, but not quite good enough on the 12 foot projector. And while I could use the TV's internet ability I refer the PS3's. I've turned OFF the wifi on every device I could that is already connected via the Cat5e. This means the Sony TV's wifi is "OFF". Only portable devices in my house use wifi like phones and laptops.
I can't recall where I had heard it, but I remember someone saying to me that no matter what signal or frequency it is, if it is over the air there is ALWAYS interference of some sort. I'm ignorant of the details, but makes sense to me when you start thinking about wireless devices from wifi to cell phones to intercoms to printers to Bluetooth to remotes to over the air TV and so on. And that's just what's in your own home let alone your neighbors... and the NSA's.
Oh forgot to add.... Last night the wife actually paused the TV on a commercial and said, "I don't think the settings are right because I know his lips don't normally look like that". She was of course referring to the LLE. It has finally happened fellas. The wife is now seeing things that were once only possible by men. What have I done!?! lol
Reply LCD Flat Panel Displays
Sony , Sony Kdl 60r550a 60 Inch 120hz 1080p Led Hdtv Black , Sony Bravia Kdl 50r550a 50 Class Full Hd 3d Led Lcd Internet Tv , Sony Kdl 70r550a 70 Inch Led Hdtv
